Test/review of Vapcell INR10440 320mAh (Green)
24 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 18 min ago
DSC_7974
Official specifications:
  • Model:INR10440 320mah 3A
  • Size: 10.1*43.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 320mAh (0.2C discharge)
  • Min capacity: 290mAh (0.2C discharge)
  • Weight: Max:10g
  • Internal resistance: Max:60mOhm AC 1kHz
  • Standard Charge: 250mA,CCCV 50mA cut-off
  • Quick Charge Current:500mA
  • Max Continuous Discharge Current: 3A
Vapcell%20INR10440%20320mAh%20(Green)-info
This LiIon size is similar to AAA cells, but with up to 4.2V
DSC_7973 DSC_7980
DSC_7975 DSC_7976
DSC_7977
DSC_7978
DSC_7979
Vapcell%20INR10440%20320mAh%20(Green)-Capacity
The discharge curves for the two cells are fairly similar and the cells can handle up to 3A, this means more than 9 watt of power from this small cell!
Vapcell%20INR10440%20320mAh%20(Green)-Temp-3.0
Vapcell%20INR10440%20320mAh%20(Green)-Temp-5.0
Vapcell%20INR10440%20320mAh%20(Green)-CapacityTimeHours
The 9 watt is only for 5 minutes!
Vapcell%20INR10440%20320mAh%20(Green)-Energy
Vapcell%20INR10440%20320mAh%20(Green)-PowerLoadTime
Vapcell%20INR10440%20320mAh%20(Green)-TripCurrent
Vapcell%20INR10440%20320mAh%20(Green)-Charge
Vapcell%20INR10440%20320mAh%20%28Green%29-Pulse-0.5A-10-10-2.8V-IR
Here I am pulsing 0.5A on and off to measure internal resistance during discharge.
Conclusion
There are not many 10440 LiIon cells on the market, this is a good and rather high power one.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Edited by: HKJ on 06/24/2019 - 06:49
Geuzzz
Geuzzz's picture
Last seen: 1 month 1 day ago
Thanks for testing. And confirming yet another good cell from vapcell.
Superstocker
Superstocker's picture
Last seen: 10 hours 34 min ago
Thanks HKJ!
CRX
CRX's picture
Last seen: 1 hour 11 min ago
Looks good, thanks Thumbs Up
Scallywag
Scallywag's picture
Last seen: 17 hours 7 min ago
Thanks. Good stuff coming from Vapcell lately.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
CalvinIS
CalvinIS's picture
Last seen: 2 weeks 4 days ago
Have you re-tested the Efest 10440 lately? I do some testing on the side for inventory verification and think they've taken a sharp downturn in recent batches.
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
HKJ
HKJ's picture
CalvinIS wrote:
Have you re-tested the Efest 10440 lately? I do some testing on the side for inventory verification and think they’ve taken a sharp downturn in recent batches.
No.
contactcr
Last seen: 10 hours 24 min ago
Sometime last year I got one (the “350mAh/3A” one) from another vendor and it was bad. It measured like half the label capacity with high resistance. Ended up getting a replacement that was much closer to spec. I think it arrived with very low voltage though so not sure if it was due to storage or just a poor specimen all along.
djozz
djozz's picture
Last seen: 18 min 24 sec ago
Thanks for the test, I was waiting on this one! Smile
Comparing this test to the old Efest 10440 tests gives a mixed impression. At the lower currents the Efest actually gives a higher voltage at the same capacity, at 2A they are close, and at 3A the Vapcell keeps its capacity while the Efest does not.
CRX
CRX's picture
All newer Efest 10440 cells I have received have had much poorer performance than when they first appeared.
chinooker
chinooker's picture
Last seen: 35 min 41 sec ago
Well, is there any source for these???
I’d like to retire a few Efests.
CRX
CRX's picture
toobadorz
toobadorz's picture
Last seen: 4 weeks 9 hours ago
The flat top version of this Vapcell battery appears good, but the button top version performed, however, poorly. I purchased 16 pieces last month for my ACEBEAM UC15 and tested them:
Apparently this is a completely different cell from the flat top one. They simply performed similarly to those poor button-top 10440’s seen in the market. I reported this issue to Vapcell, hoping they could find a truly identical button-top 10440.
chinooker
chinooker's picture
CRX wrote:
https://www.aliexpress.com/item/Free-shipping-Vapcell-INR10440-320mah-3A...
Ordered 6 from here yesterday. Today I received a refund to Paypal.
BIV777
BIV777's picture
chinooker wrote:
Well, is there any source for these??? I’d like to retire a few Efests.
https://liionwholesale.com/collections/new-products/products/vapcell-104...
Barkuti
Barkuti's picture
Last seen: 37 min 44 sec ago
HKJ wrote:
The discharge curves for the two cells are fairly similar and the cells can handle up to 3A, this means more than 15 watt of power from this small cell!
Did you mean 9 watt?
Thanks.
Cheers Smile
The Light Innocent I am
HKJ
HKJ's picture
Thanks.
Cheers Smile
Yes, it is fixed now
chinooker
chinooker's picture
Ordered some here, thanks for the link.
vapcell Dennis
vapcell Dennis's picture
Last seen: 2 days 6 hours ago
Thanks for the test Thumbs Up
TexasToasted
TexasToasted's picture
Last seen: 6 hours 25 min ago
I had that problem with the gold Vapcell 14500, 1000mAH cells. The welds holding the button tops were so bad, I popped the buttons right off with my thumbnail. After I removed the buttons and rewrapped the cells, they tested great.
toobadorz
toobadorz's picture
I know Vapcell can add button tops for ordered cells upon request. And to my experience on their 18650’s, these button tops are by default simply fixed by the insulation stickers, not welded. Later they told me that was because some customers would like to remove these button tops in some situation. However the conductivity is really poor that way and makes the whole resistance much higher, especially when their cells are mostly high-drain ones.
But for this 10440 cell, Vapcell told me their button tops are installed directly by the cell manufacturer. Vapcell sourced these cells and rewrapped them, without any modifications.
So it appears that the cell manufacturer simply sent Vapcell another product without ever notice.
Agro
Agro's picture
Last seen: 50 sec ago
Thank you HKJ for testing this nice cell. Smile
HKJ wrote:
Thanks.
Cheers Smile
There is still “The 15 watt is only for 5 minutes!”.
SKV89
Last seen: 25 min 59 sec ago
Are these the best 10440 cells on the market? I’m getting ready for the release of the Lumintop GT Nano.
SamHaLeKe
SamHaLeKe's picture
Last seen: 1 day 1 hour ago
SKV89 wrote:
Are these the best 10440 cells on the market? I'm getting ready for the release of the Lumintop GT Nano.
Thumbs Up
- SAM -
