Strongest DIMMABLE Flashlight?
35 posts / 0 new
PropsGuy
Last seen: 6 months 1 week ago
Hey,
New to the forums. Looking for a small torch for an FX shot in a film. Was looking at the beautiful Acebeam X80. BUT, I need the torch to be dimmable. Any ideas? Looking into modifying the X80, but I’d be open to any other dimmable torches anywhere to within half the brightness of the X80 – say, half the lumens.
Any counsel anyone can provide would be greatly appreciated.
BlueSwordM
BlueSwordM's picture
Last seen: 21 min 32 sec ago
What do you mean by dimmable?
Do you mean infinitely variable brightness?
PropsGuy
Referring to a potentiometer, or dimmer switch to yes, control brightness.
BlueSwordM
Ah ok then.
Wouldn’t it be better to build something like this:
https://www.youtube.com/watch?v=kh9j5mDU_hA
With a high CRI COB LED like this:
https://www.digikey.com/product-detail/en/bridgelux/BXRC-50G2000-C-24/97...
Should be relatively easy to build, and provide quite a lot of flood, along with being able to use a reflector/lens to direct the beam.
Or this one from one of our members:
http://budgetlightforum.com/node/66369
mortuus
mortuus's picture
Last seen: 2 hours 12 min ago
...where Frugal meets with Flashlight!
Lick
Lick's picture
Last seen: 13 hours 11 min ago
F3WA or anything with a ramping mode
PropsGuy
That Youtube link is dead.
Definitely better to get pre-built – this is a film prop so bending and hacking are faster and cheaper than R&D cycles or hiring engineers.
That link of a user’s unit is nice but i have no way to evaluate it without seeing it in action. also, didnt see specs on dimensions.
wle
wle's picture
Last seen: 20 hours 59 min ago
anduril firmware is ‘dimmable’.
the FW3A uses it, so it is.
It is also in several ‘big lights’.
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
raccoon city
raccoon city's picture
Last seen: 10 min ago
The Youtube link works for me.
If the FW3A is bright enough, it's a very nice budget light.
Geuzzz
Geuzzz's picture
Last seen: 1 month 5 days ago
All the emisars would work for you. Just pick the size you want.
And they are available in the us at mountain electronics.
http://www.mtnelectronics.com/index.php?route=product/category&path=80
Lightbringer
Lightbringer's picture
Last seen: 35 min 37 sec ago
If you need to dim/brighten at different rates (faster/slower), you might not even want to get a light with a ramping UI. You’d have to (typically) brighten before dimming, you might get the top-/bottom-of-range blink, etc. Also, some have horrible profiles, zipping from lowest to what seems like full power in a second or two, then slooooowly getting brighter to its true 100% setting. (Ie, it’s not “visually linear”.)
You can get a light with a slider or ring that directly controls brightness, like the DV-S9.
Want a hacque? Whatever bright light you end up using, use diffusing film on the front glass, to blend the hotspot and spill and remove any artifacts from the beam. Maybe even 2/more layers, as you only lose like 2% light per layer.
Mount the light somewhere as needed, and slide a small sheet of metal in front of the lens to varying degrees to get as much/little light as you need, like an iris or shutter. That, you’d have to figure out the best way to do it.
Easier hacque? Workshop lamp (plain lightbulb in a brushed metal “bowl” to reflect light) and a plain ol’ light dimmer.
Like this, but the older style:
wle
wle's picture
anduril ramping (emisar, FW3A) is very easy to control the dimming
i know what you mean about some of them [thorfire, especially] though.
wle
-Greg Lemond.
Pete7874
Pete7874's picture
Last seen: 37 sec ago
Are you just looking for a light that has multiple brightness levels, and not necessarily infinitely variable? If so, pretty much any flashlight can do that.
Boaz
Boaz's picture
Last seen: 1 day 2 hours ago
I'm assuming you want a light with a super long throwing tight beam that will show a thin beam of light being projected vs, a floody light like the FW3A.
look at this thread and pick a light that uses Narsil ,ramping IOS or Anduril
http://budgetlightforum.com/node/67518
PropsGuy
Okay, I’m back.
Looking for INFINITELY VARIABLE BRIGHTNESS or as close as I can get.
Lightbringer: hacque? …..
Ultrafire DV-S9 = not nearly bright enough. Need Lumens > 10,000. Workshop lamp? Unworkable due to power source, portability, cord, and prop needs. Also, mechanical solutions like an aperture are unworkable.
Main feature is portability. The prop is carried in scene. It sits on the ground like a lantern. Shines straight upward in a reveal shot. That light coming to full brightness needs the tension of ramping, vs immediate switch from dark to light. The prop is portable, small, and has to function without a noticeable cord or actor interaction.
Hope that gives folks a clearer view of what I’m going for here.
Brightening before dimming is also a no go. Action = no light ramping to full light.
BlueSwordM – that’s a really cool light. But, can’t wait three weeks for parts and it doesn’t run off a battery, so requires more engineering.
Best case scenario = off-the-shelf unit + minor bending = done. The reason I chose a flashlight is for size and configuration.
Emisar D18 Flashlight looks like it might work. FW3A is also too small.
Boaz – I don’t need the tightest beam. The body of the prop will provide some flagging at the edges to tighten the look of the beam.
FW3A is def too small. Thanks for that link – checking them over now..
mrheosuper
Last seen: 14 hours 59 min ago
Haikelite mt09r iirc it has stepless dimming
Forgot my pen
PropsGuy
Looks promising, thanks!
It also looks like I might have to bypass some switch circuitry.. Tired
Lightbringer
Ugh.
Not to get preachy, but I see this over and over and over again. The damned thing should be made a sticky if not a must-read.
Someone posts a quick short question, then there are lots of suggestions, lots of shoot-downs, then finally a “What I really need is…”, with the result being lots of wasted suggestions and ideas, and lots of frustrated people muttering to themselves, “Y’know, you should’ve just said so in the first place.”.
The same thing happens when people leave their location field blank. “Where can I buy…”, people suggest Amazon and other places, then get, “Oh, I live in X, and there’s no Amazon there.”, or, “They don’t ship Y to my country”. Like, wtf??
The key to getting useful answers is asking a useful question which keeps people from needlessly spinning their wheels.
Firelight2
Firelight2's picture
Last seen: 7 hours 15 min ago
Do you want it to go from dim to bright while sitting on the ground without being touched by an actor?
If so something like an Emisar D18 would work, but you might need custom firmware programmed for it.
Anduril firmware is open source, but you might need to program in a special mode. Something like you press the button then after a set period of time it starts ramping until it hits max and stays there. That way it would work without being touched.
Henk4U2
Henk4U2's picture
Last seen: 26 min 12 sec ago
My old math teacher always said that by fully understanding the question you are about halfway the answer.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
lawallac
lawallac's picture
Last seen: 1 hour 24 min ago
What type of beam are you looking to get? That x80 is very bright but it’s not going to give you much of a defined beam. There always seems to be a bit of a trade off lumens vs lux.
teacher
teacher's picture
Well said by you both!! And the “old math teacher” also…. Wink . Thumbs Up . Beer
Relampago
Relampago's picture
When it comes to props, the hard part is limited budget and buying your own equipment. I get the attempt to narrow down to a precise purchase. Maybe the new Astrolux M18.
“Electricity is really just organized lightning”
― George Carlin
nightlyfe27
Have you made a decision?
I used KC Lights on my pickup just to test how it'll go for long drive. I am pleased with its performance.
PropsGuy
Lightbringer wrote:
Ugh.
That’s really helping me. Angry
I didn’t come here to fight with the community, but you’re coming off as a jerk. The reason I didn’t give a blow-by-blow of the action is to avoid people coming in trying to tell me how to make a film, how to light, how to do ALL kinds of things I DON’T need advice on. Like questioning the flood or focus, how many lumens, size, etc. Saves having to explain everything to people who don’t know much about film production. I have three forums active on these issues right now and I’m working 16 hour days so forgive me if I’m not as thorough as you’d like. Flat Stare
I need a small torch at that lumen strength that I can make dimmable from dark to full brightness – that’s it. I certainly don’t need a lecture. Thank you.
Relampago – muchas gracias.
It’s looking like we will probably go with the Emisar D18. Now I need to deep dive Anduril and see about custom scripts before we pull the trigger.
This thread is deteriorating, so I’ll just go ahead and say thanks to everyone who responded, you’ve all been a great help to the effort. I’ll be posting more asking about Anduril, and I’ll post a final production thread with the finished product once it’s complete.
Relampago
Relampago's picture
I’ve got a D18, it’s a killer light. It’s quite bright and the craftsmanship is excellent. Anduril is my favorite ui, the lightning mode is awesome. Could be useful on other projects as well.
― George Carlin
PropsGuy
Awesome! Have you messed around with altering firmware, or flashing updates to the chipset? That’s the next stage of the project. Starting another thread to work on stripping down the UI to a single function – ramping, and port the controls to a remote.
Let me know if you have any insight!
Relampago
Relampago's picture
I haven’t messed with the firmware but the creator is ToyKeeper and she’s on the forum. You could probably send her a pm and she’ll most likely help you out.
― George Carlin
PropsGuy
Cheers, yeah, I wanted to wait on that. I’m sure TK is very busy and I’d like to get a feel for how it all works before I approach her, so I don’t waste too much of her time.
scosgt
Last seen: 16 hours 31 min ago
$25 on Amazon
Ramps up and down and super bright. Comes with batteries and charger.
Not fancy. Just works
https://www.amazon.com/gp/product/B07NVBV7R7/ref=ppx_yo_dt_b_asin_title_...
korpzgrinda
korpzgrinda's picture
Last seen: 47 min 44 sec ago
Location: Eastern Woodlands in the Wilderness of North America
those batteries look suspect, is the kit working well for you?
