Sailing around the world need a distance safety light
40 posts / 0 new
2flit
Last seen: 3 weeks 2 days ago
Location: sailing around the world on a High SpeedTrimaran
I’m on a fast cruising trimaran sailing around the world; presently near Bora Bora on Tahaa. Looking for a good light to illuminate distant objects on the shoreline or to navigate between obstructions. The boat can be very wet at speed so the light needs to be good in the salt water environment. Budget would be around $350 USD. We already have four 18650 batteries aboard but would consider another type battery pack if necessary. We are after reliability…. rock solid dependability in a wet environment; rather than features.
Can you help us out and offer a few suggestions? I appreciate the help, Thanks!
Geuzzz
Geuzzz's picture
Last seen: 1 hour 53 min ago
I’d say thrunite tn42.
http://www.thrunite.com/tn42-led-searchlight/
What kind of 18650 do you have?
Edit: go for neutral white, works much better if are in doggy wheather.
Edit2: you could also go for the TN40 a bit less reach, but more overall light output.
http://www.thrunite.com/tn40s-led-searchlight/
2flit
I have 3500mAhr Fenix batteries Part Number ARB-L16-3500U.They go with our Fenix headlamps P/N HL60R
Henk4U2
Henk4U2's picture
Last seen: 5 min 7 sec ago
The batteries of a multi-battery flashlight need to be matched. Same batch, always used together.
Most certainly not: something old, something new, something borrowed, something blue.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Geuzzz
Geuzzz's picture
Those should be fine as long as they are bought together and used about the same amount.
Always fully charge all the batteries. Don’t use a half empty ones with a full ones.
2flit
It sounds like the the TN42 does not have a BMS within their battery holder to protect the individual 18650 cells.?? If this is true then I should/would buy all new 18650’s for this pack and operate them as a set and charge as a set in the flashlight.
I should add that we have limited charge source charging capability aboard….. 12VDC, 0.8, 1.0, & 2.2 amp USB, and 300 watts of 120VAC 60hz available onboard to charge with.
As a side note; The Trimaran uses LiFePO4 batteries for the main house bank. They are 400A-Hr 12V. We operate without any BMS by bottom balancing.
Marc E
Last seen: 4 hours 19 min ago
Firstly, bon voyage!
Secondly:
2flit wrote:
Looking for a good light to illuminate distant objects on the shoreline or to navigate between obstructions..
I’m not a sailor so have no experience of the situations you encounter but that sounds like 2 different requirements to me, one requiring a a focused beam that covers a lot of distance with minimal spill to avoid reflections from the water, and the other a wider beam to illuminate as much as possible in a couple of hundred metres in front of the boat.
Does that sound right?
For spotting objects on the shoreline, what kind of distance do you need?
I was thinking a fixed aspheric might be more suitable than a reflector light, or a LEP like this:
http://budgetlightforum.com/node/64194
but the beam might be too narrow to be able to easily identify landmarks.
Edit:- Actually, the Acebeam W30 has more throw and is advertised with being waterproof up to 100m.
You can clearly see how narrow the beam is in this review: http://budgetlightforum.com/node/67500
SKV89
Last seen: 1 hour 39 min ago
Acebeam W30 hiCRI with the warm white beam to cut through fog and no spill to prevent pupil constriction. It’s also the farthest throwing retail LED LEP flashlight
nobody
Last seen: 29 min 54 sec ago
SKV89 wrote:
Acebeam W30 hiCRI with the warm white beam to cut through fog and no spill to prevent pupil constriction. It's also the farthest throwing retail LED LEP flashlight
This. Just watched a video on this. Distance can’t be beat. One battery. Have something else for closer and for flood.
2flit
Marc, I am not familiar with beam scatter from humidity or reflection off the sea, and how this would impact my choice in light. Is being blinded by reflection off the water a big issue with these types of normal beam spread lamps? I can imagine what you are concerned about. Are you saying that the extremely narrow beam of the laser/phosphor light would be needed to sight objects on shore at a distance between say 400 and 800 meters?
You asked…..
Spotting on shoreline would mostly be between 400 and 800 meters (something up to 1,500 meters would certainly be welcome though beyond my wildest expectations)
Navigation (in good visibility) between objects would require a beam that would illuminate the area up to 400 meters with excellent detail such that we would not miss a navigation marker, and up to 200 meters such that we would not miss a 1 meter wide dark colored rock near the surface. We don’t mind having to pan the beam back and forth a bit to cover the area ahead of us.
Our primary need is the Navigational one and secondarily….we are hoping to be able to visualize objects on the shore up to at least 800 meters. We do not need to use the light at a ‘pointer’
Does this help answer your question?
contactcr
Last seen: 3 hours 47 min ago
I was using my BLF Q8 (reflector light) on a white bay boat at night and the reflection from the boat was terrible. The more I cranked the light up to see further the more blinded I would get from reflection off the boat. A fixed aspheric light would be good but I have no suggestions outside of a modified one.
Granted this boat I was on I am sunk down in the hull having to hold the light in my hands. Your situation may be different if you have a raised platform or something to use.
Nichia
Nichia's picture
Last seen: 4 min 54 sec ago
U want reliability?? Then choose malkoff! USA made fully potted. I don't recommend thrunite
Nichia!
Nichia
Nichia's picture
Nichia!
2flit
I would be standing on deck holding the light above my head (I’m 6’6” tall) probably at the bow while the crew steers. So reflection from the boat itself would be minimal.
contactcr
If you want a traditional flashlight that would be a bit more versatile and less money I would suggest this one:
http://www.acebeam.com/t27
The upper end of your range (800 meters) will be pushing it with that light.
If you want an even larger/heavier traditional light:
https://maxtoch.com/maxtoch-x-pro-1900m-beam-distance-78mm-head-newest-f...
And finally the laser phosphor option suggested above if you want a true pencil beam. Lots of warnings about shining this in people’s eyes and it seems pretty niche for its uses though:
http://www.acebeam.com/w30
Deputy Dog
Deputy Dog's picture
Last seen: 2 hours 47 min ago
I would check out the Olight Javelot Pro https://www.olightstore.com/javelot-pro.html Mainly because of how long the run time is. It does have enough throw. 1080 meters
LIGHTING LEVELS
LEVEL 1 (lumens) 2100
Run-time LEVEL 1 2100 lumens (~1000lm); 10 mins/ 130 mins
LEVEL 2 (lumens) 600
Run-time LEVEL 2 5hours.
LEVEL 3 (lumens) 150
Run-time LEVEL 3 23hours.
LEVEL 4 (lumens) 15
Run-time LEVEL 4 8days.
Adhara
Last seen: 49 min 7 sec ago
My Maxtoch LEP outhrows my W30 LEP.
Igor
Igor's picture
Last seen: 3 hours 34 min ago
Nichia wrote:
U want reliability?? Then choose malkoff! USA made fully potted. I don’t recommend thrunite
Yes but they can’t throw 800 meters…
The darkness is afraid of us.
Flashlights are cheaper than therapy.
Igor
Igor's picture
LIGHTING LEVELS
LEVEL 4 (lumens) 15
1080 is the theoretical throw, you can guess half of that of usable throw.
sgt253
Last seen: 18 hours 53 min ago
Nicolicous
Nicolicous's picture
Last seen: 1 min 41 sec ago
Is it dangerous to sail around the world?
What about encountering pirates ?
Nico -.-
emarkd
emarkd's picture
Last seen: 3 hours 33 min ago
You won’t be illuminating objects on a distant shore with it, but if I were headed into that sort of environment I would absolutely have an HDS with me. Rock solid, super reliable, built to take a beating in all sorts of environments. The guy who makes them is a caver and built a flashlight he can trust his life to. I’d probably want something else too, something larger and more powerful, but the HDS would definitely be with me too.
raccoon city
raccoon city's picture
Last seen: 55 min 51 sec ago
What about encountering privates ?
I'd rather encounter those than pirates!  :THUMBS-UP:
Nicolicous
Oops
Auto corrections on phone hahah
Nico -.-
Geuzzz
Geuzzz's picture
After al suggestions above I still think you would be most happy with a thrunite tn40 or 42 and maybe the C version if you want to charge in your light.
The lep lights have a far to narrow beam. You will be waving it around like a lightsaber to see something.
JoeH12.81
Last seen: 3 hours 12 min ago
Adhara,
How is the tint on the Maxtoch with no filter? Is it as blue/ saber like as the W30? (I love the saber look, yet my eyes choose warm > neutral > cool every time). Any difference in diameter/size of beam? The distances we are talking about are so far anyway, I don’t believe a small difference in throw would make any impact on my buying decision, unless that difference is significant. I love the W10 CRI beam tint posted in another thread…looks so nice! Now seeing the W30 is out there in high CRI, the tint feels like it could be the deciding factor. I am also seeing a premium for the CRI edition, narrowing the cost gap between the Xsword and W30 CRI. I’m interested in your take.
Thank you kind sir!
Joe
Lightbringer
Lightbringer's picture
Last seen: 11 min 3 sec ago
On the plus side, you could make the “fwooom fwooom” sound effects while doing that…
Still, “two is one, one is none”, especially out on the ol’ briny, so I’d get a WEP for looooong-distance throwing, a pair of big zoomies (Cometas/Z1s, Brynites, etc.) for medium distance throwing, and even a big honkin’ Q8 for closer more general-purpose use.
Rexlion
Last seen: 1 week 2 days ago
Could you clarify this? The Maxtoch web page Contactcr linked to says the light has an LED, not LEP, with 1900m throw. The Acebeam claims 2400m throw. Which model Maxtoch do you have, is it different from the linked one?
contactcr
teacher
teacher's picture
Last seen: 2 hours 32 min ago
contactcr wrote:
Maxtoch LEP
https://maxtoch.com/maxtoch-xsword-l2k-2000-meters-thrower-p0018-p0018.html
Help me out please, I am confused. Facepalm
What does “LEP” stand for or mean??
I clicked the link & find no mention of “LEP”.
What am I missing??
contactcr
teacher wrote:
contactcr wrote:
Maxtoch LEP
What am I missing??
Here’s an explanation from Weltool who also has a LEP light:
https://www.weltool.com/News-page1?article_id=69
