Titanium 18650?
32 posts / 0 new
fogus
Titanium 18650?
I’m brand new here.
I’ve been searching for something like the Astrolux S41S with the extension tube for the 18650 but in titanium.
I’ve searched around and found the “Reylight” and I found that it’s not for sale currently. Can someone point me in the right direction for signing up to get info for when it goes live?
Any other recommendations for 18650 titanium lights?
Firelight2
Firelight2's picture
Last seen: 1 hour 10 min ago
FW3A in titanium should hopefully be released soon. That will probably be the best one to get.
m0nk33
Last seen: 6 days 22 hours ago
You can contact Rey through here(username ReyLight) or on Instagram(https://www.instagram.com/reylight_lan). Pretty sure he has some titanium Dawn 2.1s available.
f0xx
f0xx's picture
Last seen: 33 min 38 sec ago
Are you looking for a multi-emitter light with an e-switch/ramping UI?
I know there are some Titanium/copper Emisar D4’s out there, but you’ll have a hard time finding a new one (especially on a budget). I believe the FW3A will have a Ti version too. Either of these will run off an 18650, and you can get an 18350 tube for the D4.
Between these, the FW3A (actually an FW3T) would be the easiest to source if they are indeed making one. Emisar might make more Ti D4’s at some point because they just released the D4v2.
Scallywag
Scallywag's picture
Last seen: 6 hours 15 min ago
I'm not actually aware of any fully-titanium 18650 lights.
The Emisar D4Ti was available for a while. It had all titanium except for a copper head.
Amutorch has, I think two or more models with titanium bodies (AT40 and X9), but to my knowledge both have aluminum heads. I feel like I remember another of their lights using the titanium tube from the AT40 with a different head, but I haven't tried to go figure it out.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 4 min ago
Yeah.
Fully titanium lights would not be a good head.
Since titanium has lower thermal conductivity than aluminium and lower mass per volume than aluminium, it has very poor thermal characteristics.
You’d probably kill the LED on turbo mode without you even feeling it.
Firelight2
I have a fully titanium 18650 light I got from CN Quality Goods years ago. I don’t remember the brand name.
It’s quite small. Looks like a slightly longer DQG Tiny 18650, made entirely out of titanium and with knurling on the head but not the body tube. I plan to mod it someday since unlike the DQG it does not use an integrated driver/star.
fogus
I’d be perfectly fine with a copper head. I do NOT want heat issues. I want slim and durable. Not too pokey (comfy in pocket). Knurling or no knurling. Trit inserts preferred.
I don’t want aluminum though. I have several good aluminum lights, but for my EDC, I want to spring for titanium.
I would like the initial turn on mode to be moonlight, or at least programmable to moonlight.
I’m interested in building my own, but I’ve never done that for a flashlight. I’ve done a lightsaber before though, so that’s somewhat similar, I think.
The Mechforce looked perfect until I realized it was only an 18350. And then there’s the heat issue, but it says it’s on a copper PCB and has a “radiator”, so maybe that’ll help? But I want the more substantial 18650 feel in my hand.
I really do want to be confident that I won’t burn the light out. Whatever protection is available to prevent that: I want it.
Firelight2
For what you’re looking for I think your best option is to wait for the titanium FW3A. It hit’s all the bases:
  • copper head with rest of the light titanium
  • shortcut to moonlight for initial turn-on.
  • up to 2800 lumens output
  • Very small and compact for an 18650 light with a great UI.
  • Looks gorgeous.
It’s not out yet, but I’m keeping fingers crossed that hopefully it’s available in a month or two. Here’s one of the pictures that was posted in the FW3A thread of the prototype:
BOO5TED
BOO5TED's picture
Last seen: 15 hours 43 min ago
That looks great besides the copper section, maybe if the knurling on the tail was copper it would look better.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
fogus
That looks fantastic as far as specs. I’d prefer a stone washed appearance, but that’s just me.
What do you think the trit options are?
Firelight2
The FW3A has no built-in trit slots on the outside of the body. However, it can use a Carclo 10507 optic, and I know that Neal is selling such optics with 3 trits pre-installed for $30 each.
Some people have also modded the tailcaps in their aluminum FW3As to add room for a trit. That’s probably the only other place to put one.
If bezel trits aren’t bright enough for you, Lexel has prototyped an aux led board. When installed, you get a colorful glow behind the bezel when the light is off from 12 tiny colored LEDs. These are typically much brighter than any trit.
Firelight2
The copper section is the head. It’s a single piece that contains the shelf for the star (the board with the LEDs on it), and the driver.
Titanium is a relatively poor conductor of heat. It’s common for titanium hot-rod lights like this one to use copper for the section with the star on it for just this reason. Copper is an excellent conductor of heat and helps remove the heat from the LEDs.
The FW3A is quite a small light for producing around 3,000 lumens. It is 25mm wide at the head and 92mm long. It’s one of the most compact available 18650 lights.
BOO5TED
BOO5TED's picture
I get that, it just looks out of place with that being the only copper part of the light. Rear tail section or possibly a copper pocket clip would make it more visually appealing to me.
fogus
That LED idea sounds cool. As long as it doesn’t run down the battery too quickly and isn’t so bright I can’t sleep at night… Do you have a link to it? How can I learn more?
emarkd
emarkd's picture
Last seen: 2 days 17 hours ago
There are titanium lights out there with copper heads (for heat) and matching copper tail (for looks). Here’s one of mine, a FocusWorks Eryx F1.
I also have the ReyLight Dawn already mentioned, solid titanium. Its a great light, but it does not shed heat well. In fact one fateful evening I wasn’t paying close enough attention to how hot the head was getting that it melted its own polycarb optic. Luckily its a $2 part…
That’s not to discourage you from the ReyLight, its a great flashlight. But it does require some careful handling. Its not one I’d hand to my kids…
BOO5TED
BOO5TED's picture
I’ve wanted a Dawn for a while but interested in the new Gemini coming out more.
fogus
I’m going to have a hard time justifying going much over $300, but I’m glad to see options above that.
For the FW3A, what price range should I expect?
Waiting a few months is no big deal for this purchase. I’m looking for a light that really hits everything I’m lacking in the S41S, so I’m willing to wait for that.
Enderman
Enderman's picture
Last seen: 30 min 23 sec ago
fogus
The price on that makes me a tad nervous. I’d expect to pay at least $150, but I won’t say no to keeping my money. Not a huge fan of the design. I’ll be watching to see what people say about reliability for this one.
fogus
I searched for this but did not find it.
Also, that FocusWorks Eryx F1 looks fantastic. A bit out of my price range. I’d take a simpler stone washed exterior to save money if possible (hoping to keep below US$300).
moderator007
moderator007's picture
Last seen: 13 hours 11 min ago
Sunwayman makes a titanium 18650 light, I dont own one, so I couldn’t tell you much about it. Doesn’t look like it has a moonlight though. https://www.batteryjunction.com/sunwayman-c25c-ti-xm-l2.html
There’s a Reylight triple dawn on ebay also.
https://www.ebay.com/itm/ReyLight-Triple-Dawn-Titanium-Stonewashed-Cree-XPL-HI-6000K-LED-Flashlight-NEW/383024343964??
BOO5TED
BOO5TED's picture
https://www.instagram.com/p/BzEMRY5nPI2/
https://www.instagram.com/p/By67qtiH8LY/
fogus
I found the Sunwayman C25C Ti Thrones, but it has no moonlight mode, same for the Sunwayman M25C Ti Titanium, and for the Luckysun 18650. Moonlight is my primary use.
I also found the https://intl-outdoor.com/emisar-d4ti-high-power-flashlight-p-927.html light recently. Looks fantastic, but no stock.
Why does it seem like the whole world is out of stock of titanium 18650 flashlights?
BOO5TED
BOO5TED's picture
Because people want them lol.
fogus
Does anyone know of any lists I could throw my name on to so I get an early notification? As long as I can subscribe to something, I can jump on it when it comes available. Preferably, I’d join several lists to be notified of any new Ti lights. How can I do that?
Also, on a bit of a whim, I ordered this:
LED 18650 Flashlights – Ochoos AT40 4x Ochoos 219C/2x XP-G3 1200LM 3Modes Memory Function Convex Lens Professional Floodlight Titanium Alloy EDC Flashlight – (Design: 4x Ochoos 219C) https://www.amazon.com/dp/B07FY1MYYG/ref=cm_sw_r_cp_apa_i_SA7fDb7NG0WJZ
I’m not sure what output modes are available or what the reviews are or what the modification options are.
I also got this recommendation, but the head is a bit bulky for me. Great for another purpose (not a pocket light).
https://skylumen.com/collections/v54-lights/products/fireflies-e07vn-cu-...
Tally-ho
Tally-ho's picture
Last seen: 1 day 14 hours ago
Copper is too soft without rigidity, a copper pocket clip will bend pretty easily.
Henk4U2
Henk4U2's picture
Last seen: 2 hours 1 min ago
There used to be an Olight S30 baton in two versions, polished and bead blasted.
Nothing revolutionary, just a very expensive 18650 tube light.
That was about the same time as the above mentioned SWM C25C was available.
EDIT: some time later, I read about a really limited edition M20 Warrior
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 42 min ago
You can search for Amutorch AT40 that is the original name of that brand. There are some reviews or at least impressions around here.
About the FireFlies they are also talked here on the forum!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger /// Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1
Scallywag
Scallywag's picture
I tried to find this on his site, but gave up. Do you have the direct link to this listing?
trakcon
trakcon's picture
Last seen: 30 min 27 sec ago
