How do I explain that powerful flashlight gets hot easily at highest level is normal?
47 posts / 0 new
Barry0892
Barry0892's picture
Last seen: 1 day 4 hours ago
There are always some customers complain the light gets hot at Turbo, or complain about the step down in 3 minute so they can’t always use the highest level.
How can I make them understand it’s normal to get hot at Turbo?
Thanks
Barry
Find FREE items on my timeline.
Facebook: https://www.facebook.com/barry.lee.984991
WhatsApp: +8615773183209
chinooker
chinooker's picture
Last seen: 11 hours 22 sec ago
That is a very good question.
Unfortunately, even here we have no good answer.
Some of us still ask that same question.
raccoon city
raccoon city's picture
Last seen: 7 hours 35 min ago
I don't like it when flashlights get hot really quickly.
I like it when Turbo is a little bit hidden, like on the FW3A, that way Turbo is avoidable by people like me.
I think that is the best solution.
With a fresh battery, the FW3A gets hot somewhat quickly even on High, so I turn it down a little.
Joshk
Joshk's picture
Last seen: 9 hours 52 min ago
I’d explain that LED output is really only limited by the heat it can handle. And that turbo mostly exists for fun. High is the recommended max.
Relampago
Relampago's picture
Last seen: 1 week 2 days ago
Turbo is like nitrous.
“Electricity is really just organized lightning”
― George Carlin
mrheosuper
Last seen: 3 days 23 hours ago
How about explain it in description?
“The brighter, the hotter”
Forgot my pen
Relampago
Relampago's picture
― George Carlin
xevious
xevious's picture
Last seen: 5 hours 40 min ago
Here’s my take: High powered LED flashlights small enough to EDC are a very different class of flashlight from something like a large dedicated thrower. It’s understanding the “power profile” of the flashlight. One meant for turbo powered throw for a dozen minutes or more without becoming molten hot cannot be made in a pocket EDC form factor, because of the lack of body bulk for thermal management. Generally speaking, that’s the trade-off: sustained high throw <—> size.
bmengineer
bmengineer's picture
Last seen: 2 min 55 sec ago
I like lights to have temperature controlled turbo, with the default set to something very reasonable (50°C or so). If you know enough to go changing the configuration, you hopefully know that doing so might make things toasty.
Find all my reviews of flashlights and more gear at www.bmengineer.com
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 35 min 19 sec ago
You can’t so you some nifty marketing.
Instead of calling it stepdown for example call it SSF Sofrin safety features which keep the LED at optimal temperature for long a longer life span and give you better run times.
Best way i think use marketing wank lol. Every company has there own name for stepdown whether it be timed or thermal.
Say the all new SP70 has SS Sofirn safety built in. The SS thermal management system helps keep the light at optimal output levels at all times?
I know i know its a bit wanky but its layed out for every day people.
Rexlion
Last seen: 13 hours 9 min ago
If this is to be printed in the manual or something, how about adding a drawing of a table lamp with a light bulb, and this sentence: “Heat is a normal byproduct of lights.” I think everyone over the age of 5 knows intuitively that if you touch a light bulb it will be hot. Just a simple line drawing of the lamp and bulb, with wavy lines above the bulb to indicate heat rising, would be good; it doesn’t need to be a Picasso.
Of course, there’s also the standard yellow triangle symbol…
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 hours 20 min ago
In it’s simplest form light is just another form of heat/radiation. Whether it’s led, halogen, fluro, hid or whatever, they all produce heat. The more light the more heat.
I like Relampago’s analogy (nitrous). Turbo is for short bursts only.
Some manufacturers like to claim highest lumens possible but, of course, it’s not practical for the average muggle.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 8 hours 52 min ago
Barry, I think I have a simple yet sophisticated solution for customers who do not like hot flashlights without driving away your loyal fans and enthusiasts who prefer maximum power and output at all costs. This hint is meant for any „non-Andúril“ or „non-NarsilM“ flashlight with a simplified UI by Sofirn:
Just have a look onto my suggestions I posted here:
http://budgetlightforum.com/comment/1517487#comment-1517487
  • Please remove timer-triggered stepdowns from future drivers/flashlights. I do not see any reason to have both thermal and timed stepdowns at the same time.
  • Please allow a user defined choice of ATR thresholds (e.g. 45°C, 55°C, 65°C) just like HaikeLite did with their SC26
Thermal protection setting can be accessed by 10xclicks:
The light flashes once => turn it off to select 45 degree step-down temperature
The light flashes twice => turn it off to select 55 degree step-down temperature
The light flashed 3 times => turn it off to select 65 degree step-down temperature
Eventually, Sofirn could use 45°C as the default setting that will allow a safe and comfortable usage while flashoholics, experts, evangelists and enthusiasts can raise the threshold to a higher value they deem more reasonable, maxing out the full potential of Sofirn's powerhouse flashlights like SP70, Q8 and SP36. There will not be any trade off for customers who prefer a simpler UI than Andúril or NarsilM as they still get the chance to push their flashlights (and skin Big Smile ) to their very limits.
About the warning sign...
Rexlion wrote:
If this is to be printed in the manual or something, how about (...)
Very good idea! I could help Sofirn to integrate this in future manuals (English and German). However, there already is a part („Caution....“) included that warns customers about excessive heat when using the light on high level modes.
Geuzzz
Geuzzz's picture
Last seen: 1 week 3 days ago
You can throw some numbers as them. Numbers below are fictional, might even be wrong, but give an idea.
A flashlight on turbo is not verry efficient. Maybe 50% turns is light and 50% in heat.
3,7v * 5amps = 18 watt
0,5 * 18 = 9 watt Heat.
60 sec turbo gives 9*60=540J heat.
Q=c*m*∆T
c=0,88J/g°C for alu
The cooling mass is +-20 grams.
540=0,88*20*∆T gives a raise of 30,6 degrees so at room temperature you and up with a 50°C light.
Kiltan
Last seen: 1 week 8 hours ago
I like to think aluminum & copper metal flashlight acting like headsink for led emitter. High thermal conductivity of Aluminum ’237 W/(m·K)’ & Copper ’401 W/(m·K)’ allow it to distribute heat really fast compare to lower thermal conductivity materials such as cast iron ’52 W/(m·K)’, titanium ’21.9 W/(m·K)’, stainless steel ’14.3 W/(m·K)’ & PVC Plastic ’0.19 W/(m·K)’. It reason why both aluminum & Copper used in cookware base of pans, heatsink & heat pipe, etc.
varbos
Last seen: 15 hours 31 min ago
It’s not normal. It’s only ‘normal’ in the small enthusiast segment.
Most non-enthusiast buyers get worried when a flashlight gets very hot.
Eleziel
Last seen: 15 hours 33 min ago
Think of it like a car, just because it can drive at 200km/h doesn’t mean you should do that, but it can
mortuus
mortuus's picture
Last seen: 5 hours 3 min ago
yes the problem is like 60% or more of emitters is produced heat, rest is lumens…. if the emitter didnt produce any heat it would be wonders…. many think its a flaw when a light gets very hot quick but that is the price we have to pay sadly..
...where Frugal meets with Flashlight!
bmengineer
How hot is hot? Some Acebeam and Armytek lights get over 60°C, which is nuts to me.
P220C
Last seen: 2 months 4 weeks ago
That’s just it:
Hot to the point of burning skin is not normal.
Warm to the touch is normal.
delusional
delusional's picture
Last seen: 12 hours 36 min ago
If it gets hot QUICKLY, that’s actually better. It means the thermal path is good and it’s pulling heat away from the LED.
WalkIntoTheLight
Last seen: 3 hours 19 min ago
If they don’t understand it the first time you explain it, tell them to turn on a (incandescent) 100 watt light bulb, and then lick it after a few minutes.
At the very least, they won’t be able to verbally complain to you anymore.
Lightbringer
Lightbringer's picture
Last seen: 6 hours 37 min ago
…about sums it up.
Rexlion
Lightbringer wrote:
…about sums it up.
Along the same lines, people want the hottest new light but they’re surprised when it turns out to be literal.
Lightbringer
Yeh. They want controlled fusion in a lipstick-sized tube, then return it because “it gets too hot”.
RapidLux
RapidLux's picture
Last seen: 4 hours 59 min ago
FW3A step 4 draws 561 mA and generates 177 lm pluss heat. Turbo draws 12A. If the Leds were as effective as in step 4 the flashlight would generate 3800 lm, pluss propositional amount of heat as in step 4. For turbo you can then add 1000 lm extra light energy lost as heat energy.
Phlogiston
Phlogiston's picture
Last seen: 2 min 49 sec ago
How about:
“This flashlight has the same power as a household lightbulb. Please remember that it will get very hot at high power, just like the lightbulb. For your safety, we have designed this flashlight to reduce power after 3 minutes at high power.”
(You can write “on turbo” instead of “at high power” if you prefer.)
Don’t ask me how to make people actually read the warning, though Smile
Lux-Perpetua
Phlogiston wrote:
How about: "(...) For your safety, we have designed this flashlight to reduce power after 3 minutes at high power." (...)
No offense, but I don’t like the idea of giving Sofirn suggestions about more flashlights with timed stepdowns. A timed stepdown is the worst solution both for muggles and enthusiasts. Repetitive activation of turbo will still heat up the flashlight beyond its designated threshold unless a thermal controller is in place, too. But once you have a thermal controller (like „ATR“ called by Sofirn) in place you don’t need to have both timed and thermal stepdowns. That’s why I suggested to Barry to implement 3-4 user-selectable thermal thresholds for stepdown. Sofirn could sell their lights with a factory default of 45-50°C and put a big warning sign as well as some instructions into their manuals how to raise the threshold by hidden settings in the UI.
Firelight2
Firelight2's picture
Last seen: 6 hours 8 min ago
Say: “Powerful flashlights get hot easily at the highest level. This is normal.”
joechina
Last seen: 8 hours 15 min ago
LEDs don’t get hot.” is fake news Wink
I really like what Phlogiston wrote.
Anyway, here is what I wrote a friend on the same issue:
Turbo is per definition only for a short time useable.
Turbo means you can’t sustain this level of output forever.
Like a 50m sprint on full pace or nitroglycerin injection in a motor. If kept for longer you overheat or the motor dies.
In todays flashlight it is normally one level below high where you can use it constantly. With a normal 18650 light that is 500 to 1000 lumen, depending how it is built.
LEDs produce heat as a incandescent light bulb, but only on a lower rate, but they do.
How hot the light gets depends on the output (the brightness setting) and how good cooling is (mostly the surface area of the lamp)
I know lamps with 5 seconds turbo time and some with 15 minutes.
3 minutes are quite long to light something up.
If you want a high output for long time you must buy big lights, e.g. the size of an old D-cell MagLigte
Phlogiston
Lux-Perpetua wrote:
Phlogiston wrote:
How about: “(…) For your safety, we have designed this flashlight to reduce power after 3 minutes at high power.” (…)
Fair dues Smile
I would prefer a light with ATR-style thermal regulation too, as long as I can choose the temperature, change back to a timed stepdown, or even turn ATR and stepdowns off altogether. There are people who actually like an abrupt stepdown as a useful reminder to think about what their light is doing.
My favourite lights have no stepdown or ATR whatsoever, because I know how to use them safely.
My text was just an example. Sofirn can certainly change that last sentence to something like:
“For your safety, we have designed this flashlight with Automatic Thermal Regulation (ATR). This will reduce power if the flashlight gets dangerously hot. See page 4 of the user manual for instructions on configuring ATR.”
That way, people who don’t read the warnings can’t learn how to endanger themselves. Poetic justice Smile
Thank you, I appreciate that Beer
