FW3A Moonlight default mode
13 posts / 0 new
fogus
I’m considering buying this light soon, but I want to know if there’s a way to configure it so that it turns on to moonlight mode by default (with a single press). Is that possible? How could I accomplish that?
I have stared at the UI graphic, which makes sense to me mostly, but I don’t really get how to set a moonlight mode or how to make it default.
This will be a bedside light, so I really don’t want to blind myself by accident.
contactcr
Last seen: 41 min 34 sec ago
A long press from off will do it since it always ramps from off to moon but there is no way without changing the firmware to the latest Anduril builds.
TrueRMS
Last seen: 1 month 3 days ago
If you turn it off from moonlight (and don’t disconnect battery power) it’ll always turn back in in moonlight as well.
Geuzzz
Geuzzz's picture
Last seen: 1 month 1 hour ago
Or not. Maybe I am an idiot, but I blinded myself a few times already.
Probably should order the stuff to update firmware.
TrueRMS
I’d guess you shortcutted to moon from off? That doesn’t reset the saved level to moonlight. You have to set it to moonlight by actually adjusting it to moonlight, not by the hold from off shortcut (that doesn’t reset the memorized level).
If you’re not sure what level the light has memorized and you need moon just hold the button till it comes on and ramps up one step then release and hold again so it ramps back down that one step, this will memorize moon.
A FW update would solve it too but that’s a lot of work if you’re not already setup for it!
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 37 min ago
Memory uses the last-ramped level, so ramp to what you want. Specifically: Ramp down to moon, then turn it off. After that, a single click turns it on at moon level.
Or use the hold-from-off shortcut to access moon directly. But it doesn’t remember levels accessed from a shortcut.
Or leave the light in lockout mode, which works as a momentary moon mode.
Or in the most recent builds (which probably aren’t shipping yet), there’s a way to manually set the memorized level, so a single click from off will always go to that level.
fogus
I’m pretty technically adept. What does it take to update the form firmware? Do I need special hardware to connect?
That sounds exactly like what I want.
Geuzzz
Geuzzz's picture
Yes you would have to buy hardware. This thread is pretty informative.
http://budgetlightforum.com/node/65481
Or you could buy a D4 V2. They have the newer software installed.
fogus
Makes sense. Do you just push pins though those holes or do you need to solder them?
ToyKeeper
ToyKeeper's picture
fogus wrote:
firmware?
It might be helpful to click the Link in my signature.
fogus
ToyKeeper wrote:
fogus wrote:
firmware?
Ah, my bad. Thanks!!
Is there a version number for this feature? If someone is selling a light, how could I know if it included this feature?
Is there an updated UI diagram that includes this feature?
How low is moonlight mode for the 219C?
fogus
Perhaps this is what I'm searching for?
    #ifdef START_AT_MEMORIZED_LEVEL
    // click, release, hold, release: save new ramp level (if necessary)
    else if (event == EV_click2_hold_release) {
        save_config_wl();
        return MISCHIEF_MANAGED;
    #endif
    #ifdef USE_MANUAL_MEMORY
    else if (event == EV_5clicks) {
        manual_memory = actual_level;
        save_config();
        blip();
    else if (event == EV_click5_hold) {
        if (0 == arg) {
            manual_memory = 0;
            save_config();
            blip();
    #endif
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/view/427/ToyKeeper/spaghetti-monster/anduril/anduril.c at line 782.
ToyKeeper
ToyKeeper's picture
With a new enough version, ramp down to moon and then click 5 times. This turns on manual memory and saves the current level. Then 1 click from off would always go to the lowest level available in the current ramp.
