Test/review of Samsung USB 5V 0.7A ETA0U10EBE
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 16 min 13 sec ago
DSC_5925
Official specifications:
  • Input: 100-240V 50-60Hz 0.15A
  • Output: 5V 0.7A
  • Made in Vietnam
A reader got this charger with his phone, i.e. it is a original and it is fairly old.
DSC_5927 DSC_5931
DSC_5930
DSC_5928 DSC_5929
Measurements
  • Power consumption when idle is 0.07 watt
  • USB output is coded as USB charger (DCP)
  • Cable resistance is about 0.3ohm for each connection, i.e. 0.6ohm total.
  • Weight: 24.9g
  • Size: 65.3 × 44 × 19.5 mm
Samsung%20USB%205V%200.7A%20230V%20load%20sweep
The charger can deliver a bit above 0.8A, this is fine for 0.7A rated charger.
There is some cable compensation or the voltage would have dropped significantly when loaded.
Samsung%20USB%205V%200.7A%20120V%20load%20sweep
And it can deliver exactly the same on 120VAC
Samsung%20USB%205V%200.7A%20230V%20load%20test
And the charger has no problem delivering rated current for one hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6649
HS1: 57.2°C
HS is the rectifier diode.
Temp6650
HS1: 54.1°C
Temp6651
HS1: 50.8°C
On this side HS1 is the transformer.
Temp6652
HS1: 56.0°C
Temp6653
HS1: 55.5°C
10ohm
At 0.5A the noise is 30mV rms and 358mVpp.
Tear down
DSC_6235
I mounted the top of the charger in my vice and gave it a whack with my mallet, then it was open.
DSC_6236
On this side there is a fusible resistor (F1) at the mains input and a inductor (L1) between the two mains smoothing capacitors (C1 & C2). The mains switcher transistor (Q1) is a small one.
DSC_6238
DSC_6239 DSC_6241
DSC_6240
DSC_6237
On this side is the bridge rectifier (BD1), the mains switcher controller (IC1) and the rectifier diode (D2).
DSC_6252
DSC_6242 DSC_6243
The distance between mains and low volt side is about 5.5mm, this is slightly low.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a fairly weak charger with only 0.7A charge current, when the low current is enough the charger works fine.
Notes
The charger was supplied by a reader for review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
cayman
Last seen: 4 months 1 week ago
great review, thank you for taking the time to publish it.
samgalax
Last seen: 1 hour 8 min ago
Thanks for your reat review, as all of you have made.
0.7Amps is looow…
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
