(sold)WTS Lumintop ODL20C with two batteries.
2 posts / 0 new
Dalamar
Last seen: 1 week 2 hours ago
Charge port doesn’t seem to work.
Batteries were green “26650 Battery Flat Top 5250mAh, Shockli IMR 26650 High Drain 30A 3.7v Rechargeable Li-ion Battery”
$50 shipped (continental usa), feel free to leave offers
I only like high CRI, I have or have had in order of pref:
Fireflies E07 219B SW45
Emisar D4 SST20 4000k frosted lens (the lack of some preset levels kinda makes me want to rate it lower though...)
Jaxman E2L 219c 5700k (indoor use only due to color temp)
Jaxman E2L 219c 4000k
Klarus Mi7
Varmint removal (throw):
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k (3200ma)
Lumintop ODL20C
Edited by: Dalamar on 07/15/2019 - 11:18
Dalamar
https://drive.google.com/open?id=1GPxFNE6lD9C7ei_w8BJ21lKHMy1JaEexSg
https://drive.google.com/open?id=1JiN0KM-QfltDL7VTZa9AbT6xc4aY9WdsEw
I didn’t verify with a multimeter if the charge port works; the light just doesnt behave like it should and as you can guess by my post history Lumintop support is even less than nonexistant. When plugged in it should indicate by light on the button that it’s full or charging, and you’re not supposed to be able to run it on anything but low while it’s charging. The logical conclusion is the charge port doesn’t work. The LEDs on the button work if you enable that glow mode manually.
Klarus Mi7
Lumintop ODL20C
