"DOUBLE REVIEW": Lumintop Tool AA V2.0 & Lumintop Tool25 [Pic Heavy]
51 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 3 hours 56 min ago
contactcr wrote:
contactcr wrote:
I’ll check and make sure I didn’t do something when modding it. It was only purchased 2 months ago from Amazon.
I looked and it appears I replaced the tail spring with a stiffer BeCu one. So now when I really crank the tail cap down it pushes out on the switch just enough to make it wobbly. If I loosen the cap just slightly it will barely stand on its own so I guess it was my own doing after all.
Glad you found what was wrong Wink
These lights have room for mods, but they need to be precise, otherwise we’ll end not having a good final result!
Hope you can solve it and make it tailstand Wink
BTW, can I ask what mod did you do? Wink Innocent
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
contactcr
Last seen: 3 hours 21 min ago
Just a new shaved LH351D LED and better tail spring, nothing too fancy.
MascaratumB
bansuri wrote:
[…] I’ll be swapping emitters and wanted to let any potential modders know that the pill has left-hand threads.
I am quoting this because a fellow member asked me about unscrewing the pill of the Tool AA (and the Tool 25 is the same)!
Please be sure that when you unscrew the pill, you use thin tweezers and you rotate it to the right, not the left!
The pills are not glued, so it is just a matter or turning it to the right!
OL Contest 2019
GIVEAWAY: 1 / 2
bansuri
Last seen: 26 min 55 sec ago
We refer to standard threads as right-hand where righty=tighty and lefty=loosey.
I will update post for those not familiar with this convention.
MascaratumB
Thanks bansuri!
I quoted your post because I remembered someone (=you Wink ) had posted that information into the thread and I wanted to make it more visible as I forgot to mention that on the text review on post #1!
We are normally used to loose the pills towards left and tighten towards right, but these 2 lights are the opposite (need to turn it clockwise to unscrew)! So thanks of the heads up, and also for the edit/clarification on your post.
Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
bansuri
Thanks bansuri!
Thumbs Up
It’s a sad day when you find out the hard way that a threaded component spins opposite of what you expect. Don’t ask how I know!
MascaratumB
Did you…ruin a part of your light because of that? Oops
Sorry if you did Sad
And I hope you have is solved yet! Wink
OL Contest 2019
GIVEAWAY: 1 / 2
bansuri
Not this one, I think I learned that lesson on a tailcap switch on another light. Now I check both ways.
Glad these aren’t glued.
Still haven’t modded, not sure what to swap to. So many choices.
Been using it as-is, tint is acceptable for a cool tint. We’ve seen worse.
MascaratumB
bansuri wrote:
Not this one, I think I learned that lesson on a tailcap switch on another light. Now I check both ways. Glad these aren’t glued. Still haven’t modded, not sure what to swap to. So many choices. Been using it as-is, tint is acceptable for a cool tint. We’ve seen worse.
Ufff, I thought you had a problem with the Tool! Oops Glad you don’t! Thumbs Up
Nop, nothing is glued, just like on the V1.0! It is very mod-friendly! Apart from those flaps in the driver/pill and the smaller diameter of the aluminum MCPCB, which are also easily modable!
The CW tint is not the worst, specially if compared to the V1.0 that had huge tint shift (and that terrible PWM)! The new versions are improved and I only wish they had no memory! I will put a new driver someday to solve that Innocent
A warmer/neutral tint will also make it better!
OL Contest 2019
GIVEAWAY: 1 / 2
Paladin007
Like this light (tool aa v2.0) apart from UI. I thought with the memory mode, I can leave it in Turbo. But when you switch off and on with in 3 seconds it will advance to next mode. Wish it has double click and triple click access in UI.
Is there anyway or mod for direct access turbo or strobe?
Mocarny
Mocarny's picture
Last seen: 10 hours 40 sec ago
Wow it’s great review! Thumbs Up
Thank you
MascaratumB
Yup, between 0-3 seconds it changes the modes if you click ON <> OFF ! Not the worst but I’ve seen better!
With this driver it is not possible to reach those 2 modes immediately. Well, the turbo only if you leave it on that mode before switching OFF…The strobe, not possible.
For that you’d need to change be the driver for a more flexible UI.
Thank you
Thank you Smile
OL Contest 2019
GIVEAWAY: 1 / 2
id30209
id30209's picture
Last seen: 55 min 29 sec ago
Finally . i’ve got my Tool25 last week. Didn’t have much time to play with but i must say i’m happy it’s easy to mod.
Several driver sizes can be squeezed in
Still waiting for ToolAA 2.0 though…
WTB Titanium 4sevens Quarks & Jetbeam TCR1
MascaratumB
Cool Wink
Yup, it is easy to mod, despite the “small” space it has! Have you decided about the driver and LED already?
I’m still waiting for the drivers of MTN to be in stock again to order some for the AA 2.0 and other lights Tired
OL Contest 2019
GIVEAWAY: 1 / 2
id30209
id30209's picture
Yeah i’m also in stand by waiting for MTN but for other stuff.
I have assembled my requirements for 2S Bistro driver 15mm so i will place an order with Lexel. And i’ll take one 15mm Bistro single cell for ToolAA
Emitters wise i’ll try Osram W1 in ToolAA and shaved 351D 5000K 90CRI in Tool25
MascaratumB
Nice Smile The Osram will look nice on that little light Wink
I will probably put the Luxeon V2 I have laying around!
For the Tool 25…I’m still thinking Oops But it is good to know that Lexel drivers will work! I will have to get some for the 2 AA lights I wanna mod Evil
OL Contest 2019
GIVEAWAY: 1 / 2
id30209
id30209's picture
Go for it! with 2×14500 you’ll have more BLING BLING!
Ryley
Ryley's picture
Last seen: 17 hours 22 min ago
Thank you for your help MascaratumB. 2 days ago I received parts from Lumintop, order reflector and centering ring, apparently they also sent the lens. Excellent after sales service from Lumintop. I installed Luxeon V2 4000K, tint is good but there’s a hint of green in the beam, this must be because of the AR lens. My Sofirn SP10B with same led showing no green.
After all, very happy that my White Panda is alive, just remember, turn right to unscrew Wink
http://imgur.com/a/pisBEXe
MascaratumB
Hey that is a nice looking head Wink
As I said in PM, you’ll get some green, and the best way to avoid it would be with a TIR optic. I used my Tool AA V1 with one because the LED (Luxeon V) was damaged and had a stain which could be seen in the beam. So I took the reflector out a put a TIR and it improved immediately Wink
Not so bright, but better Wink
I do think that the panda white with that warm colour will look awesome Wink
Glad it helped and…you now know that the pill will unscrew right Wink Beer
OL Contest 2019
GIVEAWAY: 1 / 2
MascaratumB
Some info about these flashlights’ pills and PCBs!
And…honey, I just modded the flashlight Big Smile
The Tool AA V2.0, I mean! But the Tool 25 will follow Evil
The LED was changed. I opted for a Samsung LH351D instead of tge XP-L HD CW led! Much better! It has a slight yellowish shift under an SMO reflector, but it is barely noticeable in the highest outputs!
Driver and LED installed Wink
I decided to make a gathering between the Convoy lighted switch and the On The Road tail cap (that is slightly transparent) to have a lighted tailcap Crown Oh, I also joined an Olight M1T pocket clip so that we have a great flashlight party Big Smile
See how the story ends here: http://budgetlightforum.com/comment/1612020#comment-1612020 Wink
OL Contest 2019
GIVEAWAY: 1 / 2
