Eizfan Lux S4 LCD Touch Screen Smart Charger, Analyzer - my favorite UI in a charger
30 posts / 0 new
tatasal
Last seen: 2 hours 5 min ago
I had this Eizfan S4 Touch Screen charger/analyzer for several months already, but never found the time to put it to test. Now here it is, from a BLF member, not HKJ mind you!
Edit: More photos in post # 12
Currently available here: NEALGADGETS (use discount code: efans4 )
At the back is the input port for the cables with probes for Internal Resistance (IR) test:
Video on IR test measurement: ( tested are Samsung 18650-30Q and and a used Samsung 21700-48G)
Charging, Discharging, etc.:
Nice touch in its UI:
Take note I chose ‘Discharge’ mode the 21700 in bay two. The bargraph changed color, then it starts to move right to left, as opposed to left to right when charging.
Specifications:
*Touch Sreen Intelligent Charger
*MAX.CC 2 Amps
*Battery Charging & Discharge testing & Capacity Grading & Battery Resistance Testing
*Built in cooling fan with two temperature sensors
*Compatible with
IMR/3.7V Li-ion/3.8V Li-ion/LiFePO4/1.2V Ni-MH/Ni-Cd
32670 26670 26650 22650 21700 20700 18650, 18490, 17500, 18350, 14500, 10440, 16340(RCR123)
Ni-MH / Ni-Cd
AA AAA AAAA SC C D etc
Adjustable 4 (0.5A*4/1A*4/1.5A*4/2A*4) optional charging modes for different capacity battery.
Features:
1.Micro-programmed control unit, intelligent implementation of touch control, four slots operate independently and support the hybrid charging mode.
2.Using constant current, constant voltage charging mode.
3.Using DV control technology to reach higher charging efficiency.
4.Color LCD display screen instantly shows charging progress, battery voltage,current, time,capacity,charge-discharge curve and display diagram of internal resistance testing.
5.Compatible with Ni-MH /Ni-Cd/ LiFePO4/ Li-ion 3.7v/Li-ion 3.8v battery for any capacity.
6.Fit in rechargeable cylindrical battery which diameter below 32mm,height 34-73mm.
7.AC 100V – 240V DC turn into 12V input mode (or DC 12V 5A vehicle-mounted input)
8.Functionality includes charging, discharging, capacity grading & battery resistance testing
9.All the discharge current is set to 0.5A.
10.Protection of opposite connection: corresponding battery slot showing “Battery Error” if battery reversed.
11.Protection of short circuit: corresponding battery slot showing “Battery Error” if battery short circuit.
12.Automatic activation function: automatically activate the “zero voltage” lithium battery.
13.Intelligent temperature control: built-in cooling fan will be according to the two temperature sensors, to detect machine internal temperature which rise to 60 degrees Celsius automatically open, drop to 40 degrees Celsius automatically stop, ensure the charger has good working condition. Avoid spontaneous combustion or ignition in high-capacity batteries during high temperature on the charge and discharge process.
Edited by: tatasal on 09/09/2019 - 22:48
mrheosuper
Last seen: 2 days 12 hours ago
strange, the IR probe uses 4 wire i assume, but the tip is only 1 wire, that will make the measure wrong
Forgot my pen
HKJ
HKJ's picture
Last seen: 3 hours 6 min ago
I did look at it, but it is some time ago: http://budgetlightforum.com/node/61831
tatasal
I have several chargers, ranging from first few ones that I got when I joined this hobby: iCharger 106B hobby charger, the Pila IBC and the Powerex Maha C9000.
Then came the Nitecores, the Xtars and my first analyzing charger with 4 bays, the Opus BT-C3100 V2.0/2.1, 2.2.
Then the new kids on the block that can cater to long cells and high amperage/auto current charging like my Miboxer C4-12 and their other models, all the way to the C8.
I also have the SkyRC MC3000, which I regretted to this day due to its complexity to use relative to simplicity of my other analyzing charger/analyzers.
This Eizfan S4 is a breeze to use, has very clear color LCD screen that you just tap to choose what you want, whether you want to charge, choose current, discharge on the next cradle while doing other sorts of modes in a combination of different cell chemistry (lilo, lipo4, nimh), all simultaneously, just like the Opus but without the Large color LCD Touch Screen that the Opus lacks.
No more memorizing of procedures, etc. or making a list or cheat sheets like the SkyRC.
Of course its price is quite a bit on the high side at $119 (with code)…but I tell you, once you actually get to use this thing hands-on, you’ll wonder why they only came up with this design now.
It’s just like using your smart phone by tapping on the screen, but without connecting it via cumbersome Bluetooth, data cable, etc.
Trail Trek
Trail Trek's picture
Last seen: 1 month 1 week ago
Love this UI, the one thing i dislike about my Nitecore SC4 and UMS4 is the 2 button approach to the UI
This is much more intuitive to me. Shame about the price but very interesting, thanks for the post and info.
Nev
Last seen: 11 months 1 week ago
What voltage are the cells when measured straight after it says full(preferably using a fluke mm)?
fluke
Last seen: 1 hour 8 min ago
Can not for the life of me find it on Nealsgadgets.
shirnask
shirnask's picture
Last seen: 4 hours 12 sec ago
Here
fluke
Thank You.
cayman
wow, what a complex, nice and huge charger. I am astonished how many features it has, and what a nice display.
Nev
I’m not sure if no response is telling me it falls short of 4.2volts.
tatasal
At the moment, I am testing/charging one partially discharged 30Q. (Actually, my first time to fully charge a cell, so I don’t know how it terminates!)
Here are the initial photos:
Tapped the #1 bargraph, then this screen appears to choose charging rate. I tapped 2a, it’s highlighted, albeit poorly!
When “type” is tapped, screen will show the auto detection of cell chemistry, in this case the 30Q is Li-ion 3.7 ( the Li-ion 3.8 is for some special cells that terminates at 4.35v)
Screen showing starting point:
At 1 minute elapsed time, 2a rate:
34 minutes later:
After 40 min:
After 56 min:
100% after 1hr., 4.20v
4.20v @ 100%, (graph not shown)
Nev
Ok thanks ,I like the touchy screen ,but what’s important to me is accuracy & consistency.
tatasal
You have the photographic answer in my post # 12.
Nev
Thanks very much for taking the time to show this Thumbs Up
But I was more interested in confirming that the actual battery voltage is accurate by using an accurate multimeter to see if the chargers idea of 4.2volts is really 4.2 volts.
In other words is the charger calibrated properly.
tatasal
While most modern, well-designed chargers of today terminate @ 4.20v, almost all batteries, if not all, almost immediately go to their ‘natural’ resting voltage of below 4.20v anyway, for me, I have no practical purpose of checking about exact voltages to the thousandths of a volt.
Sarah Efan
Sarah Efan's picture
Last seen: 9 months 3 weeks ago
Hello friend, for more exact datas, pls kindly check the HKJ review of Eizfan S4: http://budgetlightforum.com/node/61831
Sarah Efan
Yi Fang TECHNOLOGY CO.,LTD
Efan(Eizfan) li ion/IMR battery & charger, Around 10 years professional manufacturer
Email: sales55@efanbattery.com
Web: www.yifangpower.com
Alibaba: https://yi-fang.en.alibaba.com
www.efantech.en.alibaba.com
Skype: efan.sales5
Facebook: Sarah Efan
Wechat: efantech4
Nev
I’m not sure if this post is aimed at me ,I think it may be so I’ll reply,
I’ve read HKJ’s review , he’s very good & I highly rate him,
But I’m not sure if he has time to verify each test with a multimeter because he’s very busy with the amount of stuff he tests , so I’m sure he’s talking the termination volts from the chargers display, I have bought & use charges he’s tested & ive bought because he said this or that charger terminates at 4.2v but when I’ve tested them they usually fall a bit short eg 4.16 ,4.17 etc , or maybe if he has got time to verify that it terminates at a real 4.2 then it’s possible manufacturers may cherry pick before sending to him because their credibility is on the line. Shocked
Sinical old me..
BlueSwordM
BlueSwordM's picture
Last seen: 22 hours 59 min ago
Most chargers do terminate at 4,20V.
However, for the cell to stay at 4,20V, it needs to be overcharged a little, or termination current needs to be lower.
There’s almost no measurable capacity difference between 4,13V-4,20V if the cell charges correctly.
Nev
Yes I agree with you BUT I’m not talking about a cell staying at 4.2 v ,it is obviously going to settle to around 4.18 after a while , I’m actually talking about cells leaving the charger STRAIGHT after the charger says full @4.2.
If it’s actually terminating at 4.17 v verified with accurate multimeter but charger reports 4.2
Then the cell will settle at something like 4.14-4.15v ,I hope that’s made it clearer to understand.
HKJ
HKJ's picture
Nev wrote:
I’m not sure if this post is aimed at me ,I think it may be so I’ll reply, I’ve read HKJ’s review , he’s very good & I highly rate him, But I’m not sure if he has time to verify each test with a multimeter because he’s very busy with the amount of stuff he tests , so I’m sure he’s talking the termination volts from the chargers display, I have bought & use charges he’s tested & ive bought because he said this or that charger terminates at 4.2v but when I’ve tested them they usually fall a bit short eg 4.16 ,4.17 etc , or maybe if he has got time to verify that it terminates at a real 4.2 then it’s possible manufacturers may cherry pick before sending to him because their credibility is on the line. Shocked Sinical old me..
My curves are made with a 6½ digit multimeter and I read the termination volt from them (From the curve, not from the logfile).
Termination voltage is highest voltage while current is on, as you can see on all my curves voltage drops immediately when current is turned off.
Nev
I’ve stoped using the all88 charger with lithium ion because if I check the voltage a day after charging the voltage is 4.13 -4.16 (the gyrfalcon isn’t consistent on all slots) but if I charge on mc3000 they read about 4.18 v a day or so after charge ( I set termination to 4.2v )
Hey HKJ ,Do these manufactures know you are going to publish your tests on forums
Is there a chance these are cherry picked for reviewers ?
Do you actually get mainstream production units ? I’ve noticed you sometimes don’t get the retail boxes
Maybe it’s the luck of the draw & some chargers of the same type are accurate & some not so!
Well anyway I’m very happy with my two mc3000’s ,my opus (after modifying) &my xtar vc4 they all terminate at a verified 4.2 ,the rest stay in their boxes.
HKJ
HKJ's picture
When I say the charger is supplied by the charger manufacturer, like the Xtar, Eizfan, Golis chargers. When I buy the chargers or they are supplied from a shop the manufacturer will not know it.
Nev wrote:
Is there a chance these are cherry picked for reviewers ? Do you actually get mainstream production units ? I’ve noticed you sometimes don’t get the retail boxes Maybe it’s the luck of the draw & some chargers of the same type are accurate & some not so!
Mostly no, I do sometimes get defective chargers for review.
Missing retail boxed is either early production units, from Ebay or from a reader.
The charge voltage will vary for copy to copy of a charger, how much depends on the quality of the parts used and if they do calibration.
Nev
Thanks HKJ that’s what I suspected Thumbs Up
Mishanchik
Mishanchik's picture
It seems to me that everything is very simple. If you want the voltage on the cell to be as close to 4.2 V as possible, choose a charger that is as low as possible with a cut off current and, as a result, a longer charging process.
For example:
MiBoxer C4-12 – cut off 60mA. 18650 taken out of the charger – 4.195V.
d_t_a
Last seen: 49 min 48 sec ago
For example:
I think the C4-12 sometimes shows 0.06A and sometimes 0.05A (to verify) end-charge current before it indicates “Full”.
And you’re right, when I use a DMM to test the battery voltage (right after it becomes “Full”), then the battery voltage is really really close to 4.20v (oftentimes just +/- 0.005v from 4.20v, so like 4.195-4.205v)
Kajman
What is now top 26650/18650 cells charger? My MC3000 died yesterday and now I think what to buy, 4 or more slots? And maybe what as spare 4 slot charger? Should I buy next mc3000 or s4 or something else?
d_t_a
I think the MC3000 is still one of the most advanced charger (if you like custom programming the charging currents or have a need to adjust the ending voltages, either for charging or discharging tests). Otherwise for charging only, I like the Miboxer C4-12 (although they seem to have a slightly high failure rate in some slot, at least per my experience).
ChibiM
ChibiM's picture
Last seen: 19 hours 22 min ago
Kajman, that is interesting. Mine has problems in the second slot and I am looking for an alternative, and the first charger I thought of was this exact same one. With display etc. Not sure "how good" it is though, compared to the MC3000. Shame on SkyRC when they break within 2 years. Mine was a 2018 model.
Kajman
Mine died after 9 month, bought from China, so no warranty. First I got mcp3424 error, I changed chips, but keyboard had still no function, later magical things happened with display and it died. It seems,that it is middle quality, inside looks not much better than my old li500. And I never discharged cells with it, I use rc chargers for this purpose. Ehh, but if there is no other, I will buy mc3000, but locally with 2 years warranty Smile
