slot #2 error on "Upgraded Miboxer C4-12" (got replacement unit..)
11 posts / 0 new
d_t_a
Last seen: 5 min 26 sec ago
I decided to try out the new upgraded Miboxer C4-12 (2-button version).
  Just received the charger about a couple of weeks ago, and have been using it lightly only.
Suddenly the slot #2 displayed an error while I was starting to charge up some batteries today.
I did a little bit of troubleshooting by checking the voltage.
Slot #1, 3, 4 (the slots still working) have an open voltage (ie. when no battery is inserted) of 5.0 volts,
but the non-working slot #2 has an open voltage of 12 volts.
Video below shows my test:
Hopefully Miboxer can point out what is the problem and offer a solution.
Edited by: d_t_a on 08/19/2019 - 05:44
hank
hank's picture
Last seen: 1 day 3 hours ago
Yeek! Failing to a higher voltage is not good.
hasddie293
hasddie293's picture
Last seen: 1 hour 23 min ago
Mine work fine on all slots…no err shown…
But I cannot be 100% sure, haven’t had a test…but will check later on… Shocked
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Mishanchik
Mishanchik's picture
Last seen: 10 hours 58 min ago
New Miboxer C4-12, use 2 weeks – all excellent.
Mishanchik
Any news from Miboxer? Did they repair your device?
Petr J.
Petr J.'s picture
Last seen: 9 hours 34 min ago
Probably punctured the power output transistor.
d_t_a
Sent video to Banggood, who has shipped out a replacement unit. Not sure if it’s the whole unit or just the charger… still in shipping status.
snakebite
snakebite's picture
Last seen: 4 hours 41 min ago
can it source any current through the cell in the error state?
if it is trying to charge at 12v this could get ugly.
Mishanchik
Please, write on the result.
d_t_a
Received replacement unit. Will need to try charging batteries to see if any errors still occur.
The unit that developed slot #2 error was originally functioning normally (I was trying testing different batteries, and they seem to charge properly), but the slot 2 error suddenly occurred. At first I thought I inserted battery incorrectly (reversed polarity will also show the same “C2 err” display), but when I double-checked, the battery was inserted properly, and the slot #2 suddenly developed that error, under normal usage scenario (only a few days test charging several batteries)..
Anyway, will still observe the replacement unit to see how it goes.. Appreciate all the responses.
I wonder if there’s a way to fix the “C2 Err” on the original unit…
snakebite
snakebite's picture
its probably just an infant mortality failure.
as for a repair open it up and you should see 4 identical stages one at each position.
you are likely looking for a shorted mosfet.
and you have 3 good stages to look at and compare readings.
