Sofirn SD05 XHP50.2 2550lm Underwater Diving Light 21700 Dive LED Flashlight $18.39 (Flashlight only) Coupon CodeBG13TH this code can be used for all products at https://www.banggood.com/brands-Sofirn-b-1535.html?p=R4240016492493201711&custlinkid=413292
1x 21700 or 1x 18650 Li-ion battery (Not Included)
Size
119 x 37.5mm
Weight
120g
Other specifications:
※ Magnetic rotating ring for one-handed operation
※ reverse polarity protection from improper battery installation
※ Low battery warning: the flashlight is fast flashing every minute to show low battery when the voltage is lower than 3 volt, please put new battery.
※ Automatic Stepdown: The flashlight will slowly step down to lower mode after 3 minutes operation in the high mode to prevent overheating.
※ Low voltage protection: The flashlight will turn off automatically when the voltage is lower than 2.6 volt. Please charge the battery.
Features:
Premium type Ⅲ hard-anodized anti-abrasive finish.
Magnetic rotating ring for one-handed operation.
Reverse polarity protection from improper battery installation.
Low battery warning: The flashlight is rapid flashing every minute to indicate low battery if the voltage is lower than 3 volt, please insert new battery.
Automatic Stepdown: The flashlight will slowly steps down to lower mode after 3 minutes of operation in the high mode to prevent overheating.
Low voltage protection: The flashlight turns off automatically if the voltage is lower than 2.6 volt. Please recharge the battery.
Thanks, Relampago! Remember, that code is also good for other Sofirn products at https://www.banggood.com/brands-Sofirn-b-1535.html?p=R4240016492493201711&custlinkid=413292
Opps, just noticed that’s just the light and not the kit (w/ charger and 21700). Make sure if you want the (pretty good 4000mAH/40A) cell as well to order the kit.
Not me. Finding the right dive flashlight depends on your use case. Here are some criteria for dive flashlights:
Ease of Use
Comfort/Security of Grip or Mount
Beam Size and Shape
Light Output
Power Levels
Use as a Primary Light
The Sofirn SD05 is easy to use, wide beam, bright and you can use it as an EDC when not in the water. Some prefer no USB charging port built in because they don't trust the little silicone/rubber cover.
SIZE. Beam, wise, Almost a clone of the Imalent DN35.
Apart from the 2200 against 2550 high.
Rotary via click switches. and 21000 over the 26650 cells.
If it half as good it’ll be a good light.
I have a 3 led Divers light 2 x 26650 cells.
Magnetic On/OFF only sw Magic,
Great all weather torch.
They tend to be both better made and better proofing than std ones.
