Test/review of Sony Fast Charge Car Charger 4.8A CP-CADM2 B
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 20 min ago
DSC_6787
Official specifications:
  • Input: DC 12/24V 3.0A
  • Output: 5V 4.8A (2.4A on each output)
  • USB outputs: 2
  • Weight: 24g
  • Size: 28.4 × 68.6 × 28.4mm
I got it from amazon.de
DSC_6730 DSC_6731 DSC_6732 DSC_6733
DSC_6790 DSC_6791
There is a small round led behind the black plastic above the USB connectors.
DSC_6788
DSC_6789
DSC_6792 DSC_6793
Measurements
  • Power consumption when idle is 10.4mA from 12V and 9.3mA from 24V
  • Both USB outputs is coded as Apple 2.4A
  • It has a white led on the front.
  • The +5V is in parallel and there is separate current sense is in the GND lines.
  • Weight: 24.3g
  • Length: 71mm
  • Diameter: 28.5mm
Load%20sweep%2011.6V%20top
The USB output can deliver 2.7A, this is fine for a 2.4A rated charger.
Load%20sweep%2011.6V%20bottom
The other output is nearly the same.
Load%20sweep%2014.6V%20top
Load%20sweep%2024.0V%20top
Different input voltage do not change the output current.
Voltage%20sweep%202.5A%20top%20input%20current
The charger works down to 7V when drawing 2.5A
No%20load%20voltage%20sweep
The unloaded current draw is fairly independent on voltage.
Load%20test%204.8A
I did this test at rated 4.8A current and the charger could handle that.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp6843
M1: 50.3°C, M2: 42.1°C, HS1: 61.2°C
Temp6844
M1: 55.2°C, HS1: 57.7°C
10ohm
Noise at 0.5A output is 6mV rms and 79mVpp
5ohm
Noise at 1.0A output is 7mV rms and 88mVpp
2ohm
Noise at 2.5A output is 6mV rms and 70mVpp, this is very low noise.
Tear down
DSC_7470
I could not get the front of the charger and decided to cut it away.
DSC_7471
On this side we have one inductor and two capacitors.
DSC_7473
DSC_7474 DSC_7476
The LED is inside black shrink wrap to not light the USB connectors, but only give a small dot on the front.
DSC_7475
DSC_7472
At the input is a fuse (F1 ×1), the two switching transistors (Q? & Q2: Vs4020AP: 40V 60A 4mOhm), followed by a synchronous switcher chip (U1: AX3070: 40V two current limit input) with two current sense resistors (R15 & R16: 0.033ohm)
circuit
Typical circuit from the datasheet, the charger do not use exactly the same circuit.
DSC_7477
DSC_7478 DSC_7479 DSC_7480
On the front circuit board is resistors for coding, there is no auto coding IC.
Conclusion
This looks like a fairly well designed car charger with lots of current, low noise and individual port protection, but I am missing a auto code chip.
Notes
Read more about how I test USB power supplies/charger
Compare car chargers and other DC supplied chargers
