Test/review of Keeppower 18650 3500mAh P1835J (Black) 2019
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 58 min 16 sec ago
DSC_6834
Official specifications:
  • Capacity min.: 3350mAh
  • Capacity typ.: 3500mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 1500mA
  • Charge termination current: 50mA
  • Standard discharge current: 3400mA
  • Max. continuous discharge current: 8A
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-info
This is a 3500mAh protected 18650 battery from Keeppower.
DSC_6833
DSC_6835 DSC_6836
DSC_6837
DSC_6838
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-Capacity
The two cells match very nicely. At continuous 7A the protection trips before the batteries are empty.
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-Temp-5.0
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-Temp-7.0
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-CapacityTimeHours
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-Energy
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-PowerLoadTime
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-TripCurrent
Keeppower%2018650%203500mAh%20P1835J%20(Black)%202019-Charge
Keeppower%2018650%203500mAh%20P1835J%20%28Black%29%202019-Pulse-1.0A-10-10-2.8V-IR
Conclusion
This is very good quality protected batteries and one of the highest capacity 18650 batteries available.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
MascaratumB
MascaratumB's picture
Last seen: 5 hours 46 min ago
Thanks for the review HKJ! I went to check you comparator and comparing this KP with the Samsung INR18650-35E 3500mAh (Pink), the Samsung still beats this one in terms of capacity and drain (low and high Amps).
Would you considerer it “the best” 18650 regarding to capacity? Or will the Sanyo “beat” it?
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
HKJ
HKJ's picture
MascaratumB wrote:
Thanks for the review HKJ! I went to check you comparator and comparing this KP with the Samsung INR18650-35E 3500mAh (Pink), the Samsung still beats this one in terms of capacity and drain (low and high Amps). Would you considerer it “the best” 18650 regarding to capacity? Or will the Sanyo “beat” it?
The Samsung will have higher voltage when drawing current, because it is unprotected.
The cells are very similar, at least when new.
Superstocker
Superstocker's picture
Last seen: 5 hours 35 min ago
Thanks HKJ! Your work is very appreciated. Looks like another solid offering from KeepPower.
