[review] Wurkkos WK30 white/red/UV light
264 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 46 min 42 sec ago
I don’t see even a hint of AR coating, which is fine with me.
Yeah, it discolors the beam, generally greenifies it and makes it yicky.
If you’ve got an Angry Blue™ light anyway, the extra green just makes it more aqua or whatever. Might not even be that bad. True neutral white would probably show it up more, definitely green-hued vs, well, neutral. Warm white would tend towards pus-yellow instead of rosy.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 7 hours 39 min ago
Sorry, I don’t have any clue which coating is best or which reflective coating has the least impact on the tint shift.
Lund1660
Last seen: 11 hours 58 min ago
For those that swapped emitters is their three separate mcpcbs or just one? Just purchased one off amazon. I want to change the uv to sst-20 or sw45k.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 3 min ago
Lund1660
Thanks! Do you think the uv is a standard 3535 footprint?
Nachtfeuerzeug
I was quite astonished he didn't RUN!
d_t_a
Last seen: 37 min 11 sec ago
I ordered the Wurkkos W30 and it just arrived today.
I’m testing it out. Noticed some things. The UV isn’t 365nm (already mentioned above). I notice that it will not make certain ‘markings’ on our country’s currency glow, unlike when I use the Convoy S2+ with Nichia UV365 or Convoy S2 with LG UV365 LEDs.
Another thing is, I’m not sure if this has been pointed out in the earlier pages — it might be a bug:
- this occurs after going the alternating white+red strobe mode of the red light mode; what I think s a “bug” is that both the red and white LED will be lit up at the same time after following the sequence below)
1) from Off, double-click to operate Red light
2) double-click again to operate Strobes mode of Red light (flashing Red only)
3) single-click to advance to next strobe mode (alternate flashing Red + White)
4) now when the light is actually flashing the White LED, do a double-click (what this does is go back to the regular Red light mode)
=> the bug is that, now in regular Red light mode, use single-click to advance to next higher Red brightness level; when the Red is on High mode, the white LED will also be lit up (in Low brightness).
Normally, when in regular Red mode, single-click will advance the Red light brightness, but will not turn on the White LED. But following the above sequence, it appears to trigger the Red + White LED being turned on at the same time (the White LED becoming On while in Red light doesn’t seem to occur all the time, but it seems to get triggered more often when doing the ‘double-click’ while the flashlight is in Alternating Red+White and the light is actually flashing White at the time of the Double-click).
Anyone tried the above?
Lund1660
Tried it with my light, couldn’t get mine to do what you described.
saypat
saypat's picture
Last seen: 1 day 3 hours ago
me neither
Streamer
Streamer's picture
Last seen: 3 weeks 4 days ago
Mine neither. sounds like yours has a resistance leak on the white led’s high mode switching Question
1stein
1stein's picture
Last seen: 6 hours 6 min ago
Yep, here
MacLee
Last seen: 3 weeks 3 days ago
oh, we will test it again , the sample in my hand white LED not shows when in red light mode.
d_t_a
It doesn’t always occur, but doing it a few times will trigger the white LED also lighting up with the Red LED (on High).
The trigger is: while the flashlight is in the “alternating Red + White strobe modes”, do a double-click while it is flashing white LED. This will go back to regular Red mode, but cycling the Red to High will also light up the White LED.
Mentioned above is “resistance leak”, just wondering is this easily fixable?
klrman
klrman's picture
Last seen: 21 hours 8 min ago
Got my WK30 today.  Impressive little light, didn't know red had three levels and that it would throw so far and bright.  Any idea what brand of battery is behind the wrapper?
Lightbringer
No idea, but it seems pretty decent. My “5000mAH” cells (both) clocked in at 5380mAH or thereabouts on my Opus, which is pretty awesome. The light’s not all that high-strung, so you won’t be needing a 30A cell or anything, so it should do just fine.
Hey, I’m still tickled about ‘em. LOL
Lightbringer
Lightbringer wrote:
Mmm, I may have to try a coupla those universal holsters…
https://www.fasttech.com/products/1539801
“NaitHawk”? Who named it that? Tommy Wiseau?
Okay, I finally got these. Not bad at all. They’re crapping velcro and elastic all over the place, so they’re really adjustable, even the length of the flap! “Universal” is right. The only drawback is sheer bulk.
Lens-down, the bottom “cup” is a bit too tapered, so the light won’t slide down all the way, but lens-up, it bottoms out nicely. Like I said, even the flap-length is adjustable, just wedge your finger in the hole to separate the velcro, then slide the flap longer/shorter as you’d want it, then squeeze it together again. No belt-loop, but 2 velcro(!!) molle-type straps so you can attach it to a bag or whatnot. There’s also a hangy-loop up-top for maybe a D-ring or carabiner if you want, too.
And the ’30 fits into it (lens-up) with the switch and usb port almost perfectly above the edge of the material, as if made for it. Not bad at all.
I think I’ll still keep my SP32A on my bag, as it’s lower-profile and not nearly as bulky, but damn, if I wanted to, now I can hang my ’30 on it, too or instead.
And it’s got that Wiseau thing going on, too. Gotta love it…
Hey, for <4bux a pop, go for it.
klrman
klrman's picture
Lightbringer wrote:
No idea, but it seems pretty decent. My "5000mAH" cells (both) clocked in at 5380mAH or thereabouts on my Opus, which is pretty awesome. The light's not all that high-strung, so you won't be needing a 30A cell or anything, so it should do just fine. Hey, I'm still tickled about 'em. :))
5380mAH seems not bad at all.  I have to say this is one of those fun lights that I would never think of selling.
riffraff
riffraff's picture
Last seen: 3 days 7 hours ago
I just now ordered one. I’m hoping it’s all you guys say it is. Big Smile
Lightbringer
Pffft. This is one of those lights where you buy a few spares so that you never have to do without no matter what. LOL
Lightbringer
I think it’s safe to say you’ll be tickled with this light.
klrman
klrman's picture
^ I'm going to ask Wurkos if they would consider making the same light as well in two more versions, one with a deep emerald green and another with a royal blue instead of red.  I'd like to collect these.  Was a little disappointed when I first turned on the red light until I figured out it has a L-M-H on it and then was blown away at how strong it was.  This little light is a real winner.  Also really like that the button turns from green to blue to let you know you have the uv light on, that was a nice touch.
Lightbringer
Umm, you do know that UV has low and high brightnesses, too, right?
klrman
klrman's picture
Yes, noticed that with the uv right away.
Streamer
Streamer's picture
I’m hoping for a knurled version of this light as was alluded to earlier. Fingers crossed but not holding breath. Big Smile
azj
Last seen: 1 week 3 days ago
Damn you..I’ve been trying to save money…
Nachtfeuerzeug
I discovered my light has the solid red and white 'mode' too. I say mode because it's kind of like having additional modes. I can then single click back to low red, medium red and then red and white (and that equals more light). We're always wanting more light, right? Lol!
Lightbringer
I tried a few times to get into Bug Mode, and no joy.
Is that repeatable with youse, or just may-or-may-not happen?
(Or just think of it as white with a nice high R9 value…)
Nachtfeuerzeug
It's repeatable.  I might've found another 'mode'. I clicked 4 times and it went into a slow blinker but I couldn't get out until I unscrewed the tail cap. Unfortunately, I didn't have a chance to do it again.  I gave the light to family visiting from out of town. Doubt I'll see it again. Once I showed them what it does,  they loved it. Maybe it'll come up on sale again.
riffraff
riffraff's picture
I’ve gotten into the steady red/white mode, the flashy alternating mode, and some other weird mode I don’t remember now. I should start paying more attention to button-clicks. Beer
Lightbringer
Damn, I feel almost left out. Big Smile
