Test/review of Blackube AA 2250mWh USB (Black)
35 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 26 min ago
DSC_8633
Official specifications:
  • Voltage: 1.5V
  • Energy: 2250mWh
  • Output current: 1800mA
  • Charging current: 5V/500mA
  • Charging time: about 1.5h
  • Cell type: Li-polymer
  • Life time: 1000-3000 cycles
  • Weight: 16.3g
Blackube%20AA%202250mWh%20USB%20(Black)-info
This is a USB charged 1.5V battery, there is a LiIon cell, a buck converter and a charge circuit inside.
DSC_8630
DSC_8632
DSC_8634 DSC_8635
DSC_8636
DSC_8637
DSC_8638
DSC_8639 DSC_8640
Behind the black dot on the front is a red and green led, it shows red while charging and green when finished.
DSC_8641
Included with the batteries is a 4 way USB charging cable, i.e. any 2A USB charger can charge four batteries simultaneous.
Blackube%20AA%202250mWh%20USB%20(Black)-Capacity
The capacity depends a bit on the load current, but output voltage is stable.
Discharge%20capacity%20Blackube%20AA%202250mWh%20USB%20%28Black%29
At low current the capacity is also lower, because the internal regulation also needs some current. The battery can last for months at low current draw.
Blackube%20AA%202250mWh%20USB%20(Black)-CapacityTime
Blackube%20AA%202250mWh%20USB%20(Black)-CapacityTimeHours
Blackube%20AA%202250mWh%20USB%20(Black)-Energy
Blackube%20AA%202250mWh%20USB%20(Black)-Charge
Blackube%20AA%202250mWh%20USB%20%28Black%29-Pulse-1.0A-10-10-0.7V-IR
The electronic circuit makes the internal impedance look strange.
Test%201A
The voltage from an electronic circuit is not as stable as battery voltage, with some equipment it will affect performance.
Spectrum%201A
It looks like the buck regulator runs at about 1.4MHz
Conclusion
These batteries has less capacity than normal NiMH, but run at a higher voltage. This makes them ideal for most equipment that has trouble with NiMH batteries. They also weight considerable less than NiMH, this can be significant in some circumstances. There is one disadvantage: Battery meters do not work with them.
The USB charging makes it very easy to find a charger for them.
Notes and links
The batteries was supplied by Blackupe/roca-sup.com for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Superstocker
Superstocker's picture
Last seen: 2 hours 29 min ago
Thanks HKJ! This is a very interesting cell.
LightObsession
Interesting. Thanks for the review.
Might be a good option for the Lumintop Tool’s that I gave away a few weeks ago, since they’ve got the USB charging.
djozz
djozz's picture
Last seen: 8 hours 3 min ago
I can’t help noticing that in that case inside the battery the voltage of the li-polymer battery is bucked down to 1.5V and then by the flashlight driver boosted up again to the led voltage.
LightObsession
They’re using alkaline now.
Pete7874
Pete7874's picture
Last seen: 4 hours 16 sec ago
So, these cells cannot be charged in a typical NiMH charger, correct?
HKJ
HKJ's picture
Correct, they need USB power to charge.
L4M4
L4M4's picture
Last seen: 1 month 4 days ago
man those discharge curves are sexy AF Big Smile
Couchmaster
Last seen: 11 hours 41 min ago
flydiver
Last seen: 14 hours 55 min ago
One of the big problems with these batteries is the misunderstanding and ignorance of the purchasers.
They can be useful but have a fairly narrow band of optimal uses. They work, but aren’t very cost effective for most very low drain applications, nor do they work well in high drain uses. The voltage converter heats up. Not good for camera flashes/strobes.
Some devices that really seem to require the 1.5v and have modest drain do well. Some small devices work better: battery operated beard trimmer, nose hair trimmer, electric toothbrush and the like.
I now have 12 of a brand called [Tenavolt], and generally like them….so far. Long term use to be determined.
Only buy them on special at about $2.50/cell. Full price is exorbitant.
Fox
Last seen: 2 weeks 6 days ago
Thanks for the review… but I doubt I will buy and use with this chemistry. I try to avoid any Li based rechargeable battery. I only trust Ni-Mh
The most ugly place in the world! Surprised
Pete7874
Pete7874's picture
Do you own a cell phone? A tablet? A laptop? A camera?
Venom
Venom's picture
Thanks for the review HKJ !
Can these batteries be drain low before its need a recharge?
HKJ
HKJ's picture
They contain protection that will disconnect the output when they are empty, they will not drain the internal LiIon cell dangerous low.
Venom
Venom's picture
Thanks for the reply!
mrheosuper
Last seen: 2 days 21 hours ago
can we do teardown on this battery ?
Forgot my pen
HKJ
HKJ's picture
I may do that later together with a few other of same type.
flydiver
He’s done a very similar cell before: https://lygte-info.dk/info/BatteryDisassembly18650usb%20UK.html
Pete7874
Pete7874's picture
Is this LED only used during charging?
Can it be used to indicate remaining capacity at all?
Given the flat voltage curve, I’m guessing it’s not easy to tell how much juice is left in it.
HKJ
HKJ's picture
The led is only for charging, there is no way to see how much energy is left in the cell.
Pete7874
Pete7874's picture
The one thing about these Tenavolts cells is that they don’t have a usb port, so you’d better not lose the supplied charger, but if you have 12 of them, then I guess you already have 3 of their chargers as well. Smile
flydiver
Easy to get another ‘charger’. Do you lose your chargers? Wink
An advantage, If you want to call it that, is it only takes one USB connection to charge 1 > 4 cells. Personally I think I prefer that over the USB direct connection.
The charger is a box barely larger than a storage pack for AA. If you buy it with the charger, that’s what it gets shipped in. I guess you could store them in it. Don’t know if there is a low grade drain, but I think not.
Pete7874
Pete7874's picture
A single usb cable that comes with the Blackube cells can charge 4 cells as well.
flydiver
A splitter cable, good idea.
Seems then that it comes down to preference, IF you care to bother with these. The USB port adds one more bit of electronics to the cell, which is a pretty cramped space.
By my measurements using a ZB206B+ (an FET discharger, not resistance) I get about 140mAh more than HJK for the Blacktubes. 0.5A and 100mAh for 1.5A. I think the difference may be that port. I didn’t push beyond that since it’s evident the buck converter seems to overheat and fail. I had hoped to use them for underwater strobes and it became evident it was not a serviceable idea.
If they are a tech that works for you, either would seem to suit. Not sure how they’ll show themselves for the long haul. Thus, the purchase and experiment. I’ve got a bunch of Eneloops going on 12+ years old that need replacing so thought I’d try these out for ….some…..uses.
Pete7874
Pete7874's picture
Yup, I ordered some Tenavolts just for S&Gs since they were on sale. Still don’t know what I’m going to use them in.
flydiver
They’ll work in almost any application under 1.5A. I find the best uses is a travel Sonicare that takes AA. It was lame on NiMh, almost as good as the lithium power ones on Tenavolt. Similarly a nose trimmer and a beard trimmer both work with more punch. Also a bunch of LED night lights I have around the house. They don’t dim, and the battery is a tad smaller diameter so pops in and out of the slot much better.
Haven’t bothered to try them in very low drain applications. Don’t see that as their best use.
Pete7874
Pete7874's picture
Curious what their self discharge is like compared to LSD NiMH cells.
Pete7874
Pete7874's picture
FYI, I did a quick write-up on these, in case anyone is interested:
http://budgetlightforum.com/node/68974
fluke
Last seen: 3 hours 1 min ago
Trying to get them here in the UK is a pain.
Anyone got any links to them?
leslie0678
Blackube battery is available on Amazon.UK
sil
Last seen: 1 week 6 days ago
Hi, do you know how these battery would react over time if charged very often ?
Here is my use case :
A device is adapted to fit in a charging station with magnetic connectors using this battery.
During the day, the device would be regularly used during 15 minutes and returns to a charging station between each use (could be 5min to 2h).
During the night, the device would stay in the charging station.
I can eventually program the plug of the charging station so that it is not always on.
I wonder if the battery would support such a use-case, what do you think ?
Thanks for your help,
SB
