Test/review of Keeppower 18650 3500mAh P1835K (Black) 2019
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 28 min ago
DSC_6853
Official specifications:
  • Capacity min.: 3350mAh
  • Capacity typ.: 3500mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 1700mA
  • Charge termination current: 50mA
  • Max. continuous discharge current: 8A
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-info
This is a 3500mAh protected 18650 battery from Keeppower.
DSC_6852
DSC_6854 DSC_6855
DSC_6856
DSC_6857
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-Capacity
The two cells match very nicely. At continuous 7A the protection trips before the batteries are empty.
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-Temp-5.0
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-Temp-7.0
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-CapacityTimeHours
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-Energy
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-PowerLoadTime
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-TripCurrent
Keeppower%2018650%203500mAh%20P1835K%20(Black)%202019-Charge
Keeppower%2018650%203500mAh%20P1835K%20%28Black%29%202019-Pulse-1.0A-10-10-2.8V-IR
Conclusion
This is very good quality protected batteries and one of the highest capacity 18650 batteries available.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
mcfarlie6996
mcfarlie6996's picture
Last seen: 3 weeks 19 hours ago
Considering this is (assumingly) a 10A battery underneath, I’m a little disappointed that it tripped at 7A, especially since it’s claiming 8A continuous. They should have programmed it to not trip until 9 or 10 amps to get more possibilities of uses in individual flashlight models. Aside from that, still an excellent battery in all other aspects. Thank you for your review!!
