[M4D deal updated] Lumintop EDC18 $35 (FW3A in a classic body)
462 posts / 0 new
varbos
Last seen: 2 hours 37 min ago
Nice video. No bad surprises. I am happy to order. Would be nice if it was few mm shorter but not a deal-breaker.
JasonWW
JasonWW's picture
Last seen: 1 hour 4 min ago
wle wrote:
Why is it longer than FW3A ? Seems like with a side switch it could be shorter..
A side switch takes up a bit more room around the driver area. So you basically just shift the space from the tail to the driver area. Net result is about the same length.
This light has an extra few millimeters in length to accommodate the longer battery. You can use 70mm while FW3A was limited to about 66mm or so.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
JasonWW
JasonWW's picture
Interested.
Dzeric
Last seen: 18 hours 52 min ago
Interested
middle age man
Last seen: 10 hours 41 min ago
A couple of questions: is the magnet removable and is there a hole for a lanyard to attach?
Helios azimuth
Last seen: 11 hours 23 min ago
Would like the XP-L HI (5000k) please.
JasonWW
JasonWW's picture
See here.
M4D M4X wrote:
Speadge wrote:
Any idea if magnet from tail cap is easy removable?
NO
seems to be glued behind the tailcap/spring PCB
Nicko69
Last seen: 15 hours 42 min ago
Interested.
JCR1904
Last seen: 5 hours 51 min ago
Interested.
Gunga
Gunga's picture
Last seen: 1 hour 34 min ago
It’s a bit bigger than I was hoping for, the button sticks out a lot and the clip is kinda meh. It seems like more direct competition for an emisar d4 v2.
That said. Still looks interesting at a good price point.
panagis
panagis's picture
Last seen: 2 days 10 hours ago
interested…
rost333
rost333's picture
Last seen: 6 min 14 sec ago
interested
candor
Last seen: 17 min 58 sec ago
I see several comments hating on the clip. I get that this light is being billed as comparable to the FW3A, which has a really nice clip, but do folks dislike a deep carry clip? Or is it simply because it’s not a collar type clip?
JasonWW
JasonWW's picture
You can’t please everyone. No matter the light or the design there will always be people picking it apart and hating on the choices that were made. I try to ignore the negative opinion posts.
Tally-ho
Tally-ho's picture
Last seen: 4 hours 54 min ago
It’s not “hating”, it’s probably more a matter of preference for secure clip and for myself, a lassitude to see this lazy way of making pocket clip : making groove(s) on battery tube + clipped pocket clip.
So concerning this pocket clip, first I think that it should not rest halfway in the groove but sit flat on the tube, a bit like this :
But maybe it was just a prototype and they fixed this on the production version.
Second they could make a pocket clip with a complete ring (not photoshopped below) with two way positions like this :
Forever
Forever's picture
Last seen: 45 min 34 sec ago
What I have learned over the years reading about flashlights and knifes is that people get very picky about their clips. People often get after market clips to suit their needs. I personally do not like pocket clips and would not buy a flashlight if it could not be removed. The clips never make it out of the box on my gear.
candor
My apologies for using the imprecise slang “hating on.”
Tally-ho, nice observation on where the clip rests in the groove instead of on the body. That is potentially unfortunate. Hopefully the clip is just flexible enough that it won’t cause any trouble engaging. And, perhaps resting partially in the groove will add the right amount of purchase on the pocket. I have no idea; just trying to be optimistic. I suspect it wasn’t purposefully designed this way but it could work out beautifully. Or not.
Regarding the double loop clip design—I just realized that I’ve never tried this type. I don’t think I would like it as much with the extra material exposed outside the pocket. But, I concede that it would be more robust reversible-clip solution.
Personally, I never reverse my clips. If I don’t use them for pocket carry, I remove them. I only wear a hat to keep the sun off my head so attaching a light to my brim never comes up.
Tom E
Tom E's picture
Last seen: 4 hours 1 min ago
I signed up on your GB page.
This is what I've been waiting for - a compact Lumintop side switch flooder w/deep carry. Still love the SD Mini for a compact thrower, though it's a little bigger. 95 mm length is still very compact in length, and narrow head for.
Dunno for sure for good it is, but I've always liked their anodizing quality.
dragunbayne
Last seen: 3 weeks 22 hours ago
Personally, the clip doesn’t have to be a collar type. I just want it fixed when attached and not capable of changing position. The S1R II is a good example. The groove being machined to perfectly fit the clip was a big improvement from the OG S1 Baton which I was always having to reposition the clip because it turned.
JasonWW
JasonWW's picture
Martin, do you know if the FW3A clip will fit this EDC18?
It’s not likely, but who knows? Maybe Lumintop can offer just the clip for sale. (I have a black clip, but would like to buy a silver one)
M4D M4X
M4D M4X's picture
Last seen: 28 min 41 sec ago
list updated
18350 is likely to happen Beer
but keep on wanting!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
cdjaney
cdjaney's picture
Last seen: 3 weeks 5 days ago
Martin,
Any way to get some kind of comparison on how quickly the EDC18 steps down in Turbo and high modes compared to the FW3A? ( in other words, is the heat management and transfer about the same…or does the EDC18 handle it a little better?)
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
Johm
Last seen: 1 week 1 day ago
The EDC18 will definitely handle turbo and heat better than the FW3A, this is why:
- Surface area is larger (bulkier + heat fins)
- Weight is more, although not yet announced I estimate the weight of EDC18 to be at least 65 grams (probably even 70 grams)
- Software is the same, ANDURIL, so no change there.
Friendlyfodder
Last seen: 1 hour 32 min ago
Interested
Qwertus
Last seen: 1 month 1 week ago
Interested
MascaratumB
MascaratumB's picture
Last seen: 1 min 45 sec ago
M4D M4X wrote:
list updated
Updates on this will probably be determinant for me to buy this light, so I will wait Wink
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Tony_I
I am definitely interested, and filled out the email form.
Thanks!
Tony
Gunga
Gunga's picture
Martin, have you tried opening the bezel up? Did it come with a glass lens to allow for us to use our own optic?
M4D M4X
M4D M4X's picture
as said - my early sample is press fit, but lumintop assured me that the production light offer the possibility to change the optics
JasonWW
JasonWW's picture
M4D M4X wrote:
as said – my early sample is press fit, but lumintop assured me that the production light offer the possibility to change the optics
I hope it will be threaded so that it can apply proper pressure to the MCPCB and not burn the LED’s.
