CRX Brass KnuckleHead III
11 posts / 0 new
CRX
CRX's picture
Last seen: 36 min 50 sec ago
CRX Brass KnuckleHead IIICree XP-G2 1A
Noctigon MCPCB
16mm ARC glass
Single mode, Secondary Red
Tail Clicky Switch/ Tail Twisty (Red)
Magnetic tail
GITD details
Max - 312lm
Length – 52mm
Width – 24mm
Weight – 117g (With 16340 cell)
CRX KnuckleHead Runtimes:CRX KnuckleHead RuntimesMade from some old brass plumbers compression pieces & other bits n' pieces.CRX Brass KnuckleHead III
CRX Brass KnuckleHead IIIThe main LED is operated by a tail clicky switch, the secondary red LED is operated by twisting the tail section.CRX Brass KnuckleHead III
CRX Brass KnuckleHead I CRX Brass KnuckleHead I
CRX Brass KnuckleHead IICRX Brass KnuckleHead II
Edited by: CRX on 08/07/2019 - 13:35
Binford
Last seen: 2 months 2 days ago
wow, this looks stunning. great skills!
moderator007
moderator007's picture
Last seen: 3 hours 30 min ago
CRX is at it again, amazing job as always. Thumbs Up
A light made just for plumbers. Big Smile
MascaratumB
MascaratumB's picture
Last seen: 45 min 46 sec ago
Hat This one would be taking the hat off if he had some arms!
Great even being small Wink Beer
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Scallywag
Scallywag's picture
Last seen: 1 day 22 hours ago
CRX, may I ask how you constructed the head on this?
I see a resistor on the MCPCB. When I think about it, you could have a simple resistor in place of the “driver” (or if you were feeling cheeky, direct wire), and a simple plate for the positive contact (electrically insulated from the body)… And then, yes I think I see it, a bridge from the LED- to the body. Eliminating the need for a driver, a real pill, or more complex wiring.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Rusty
Rusty's picture
Last seen: 3 hours 24 min ago
Sublime work pal, wish I had the time, patience and skill Beer
Icing on the cake being the choice of fitting, I did my apprenticeship and 16 years as Electrical Maintenance Technician at Yorkshire Fittings in Leeds Thumbs Up
CRX
CRX's picture
Thanks guys Thumbs Up
Scallywag wrote:
CRX, may I ask how you constructed the head on this?..
Yes, just about exactly right.
There was no space at all for a driver and a clicky switch so what we have is, for the pill, a cutting of threaded brass with the MCPCB soldered directly to it and three layers of kapton tape on the underside of the Noctigon.
A piece of 0.3mm copper sheet shaped & formed around the Noctigon to make the positive cell contact and serve the MCPCB +pad, also coated in kapton.
This is held in place with JB weld with a clear space made for the cell+.
I used a 1ohm resistor between the copper sheet contact that’s bent around & sitting on top and MCPCB positive to give a respectable 800mA startup current draw, DD is a bit much.
The MCPCB- is just soldered over to the pill.
I made a very simple light with scavenged parts, BLF style Wink
Cool, thanks.
Here’s another wee light I made from 20mm brass conduit bushes Smile
Scallywag
Scallywag's picture
Thanks CRX, works of art as usual. Or as always, actually.
I think I came up with a better question: How do you work with JB Weld? I can only ever get it to stick to things near my workspace, and not what I’m using it on! Facepalm
clientequator
clientequator's picture
Last seen: 1 month 1 week ago
CRX, this is very beautiful. Thank you for sharing with blf community! Does this mean this is ‘direct drive’ flashlight?
Rexlion
Last seen: 1 week 2 days ago
Looks intriguing. Not sure it is quite floody enough though… Evil LOL
CRX
CRX's picture
Practice!
Yeah it can be messy stuff, you get the hang of it after using twenty tubes or so.. Big Smile
Thumbs Up
Pretty much yes, with a current limiting resistor.
Planning on a larger version with reflector, driver and tail switch Wink
Added secondary red LED, magnetic tail and GITD details.
