Q8 XHP50.2 3v MCPCB upgrade (with leds in place) Group buy?
37 posts / 0 new
RoboEgg
Last seen: 9 months 3 weeks ago
Just wondering how many members would be interested in a Q8 XHP50.2 3v MCPCB group buy. I have the led power blank MCPCB but I don’t have any experience of reflow soldering. A custom XHP50.2 3v would be a lot easier.
TMaxxJJ
Last seen: 8 hours 35 min ago
I’d be interested. I’d also be interested in a UK source (or EU) of the bare emitters. The shipping from Cutter just kills it at the moment.
Yourrid
Yourrid's picture
Last seen: 11 hours 17 min ago
I definitely would be in for 1!
RoboEgg
A UK source of XHP50.2 3v emitters would be good. I got my last two from Ali express. Shipping was pretty quick.
DavidEF
DavidEF's picture
Last seen: 1 day 19 hours ago
Do you mean that you have the led4power board? I’ve used a couple of those. I’m not really experienced in reflow either. But those boards do require a lot of heat, so a solder iron alone is definitely going to be just a frustration.
What I ended up doing is putting the board in the clamps of my helping hands, and pre-heating the bottom with a turbo lighter. Then I used my soldering iron to add a little solder to each LED pad. Then I put some fresh liquid flux on the LED pads, and added the LEDs. After that, I heated the board some more with the lighter underneath until I could see the LEDs settle into place. I was moving the lighter around under the board, so it was pretty evenly heated, except I kept it mostly under the LED pads, so they were just a bit hotter than the rest of the board.
After the LEDs were soldered down, I used some cotton swabs soaked with alcohol to clean the flux off the top of the board. I also alcohol cleaned the domes of the LEDs, since some BLF members have had LEDs burn up when they forgot to clean them after soldering.
EDIT: led4power has Luxeon MZ quad die 3V emitters, and he makes this claim:
Quote:
Luxeon MZ is the highest output compact 3V LED.
- The YKK Philosophy
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 7 hours ago
The Luxeon MZ isn’t the king anymore.
DavidEF
DavidEF's picture
Ah, okay. I guess he needs to update his listing information then. Anyway, if enough people committed to buying them, he might be talked into sourcing some 3 volt XHP-50.2 emitters. Then, members could buy them from him already reflowed on his board and no group buy needed. He currently has no CREE emitters listed on his site.
Blinkinglights
Last seen: 1 week 19 hours ago
XHP35 is the way to go on the Q8, I love mine.
If you cant do 35hi’s then 50.2 is the way to go.
Me love lights lonng tyme!
Pwsmith
Last seen: 6 months 1 week ago
I would definitely be in for one.
Caleb
Caleb's picture
Last seen: 1 month 2 days ago
In for one or two if neutral CCI.
Is the even a neutral 50.2?
BlueSwordM
Yes, but only down to 5400k.
I’ve actually been meaning to do a group buy of the XHP50.2+BLF Q8 upgrade kit, but I first need to ship every order in my own GBs, and find the time. Sad
Dioda
Last seen: 1 week 10 hours ago
What maximal lumen output can be expected with the upgrade kit – 4x XHP50.2 ?
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 18 min ago
Mine at turn on with VTC5A’s 16000+lm on my calibrated T/A Maukka 4” tube. YMMV
With 20S 17000+lm
My X6 Copper 21700 30T with lens… 4800lm
X6 with out lens…. 5000+ lm
Would like to see what 4×30T’s would do… Blushing
KB1428 “Live Life WOT
Tom_182
I would be in. Depending on price of course.
AguassissiM
AguassissiM's picture
Last seen: 10 hours 59 sec ago
I will take one, hopefully it will be less than Q8 itself.
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
Marc E
Last seen: 18 hours 24 min ago
Kaidomain have the bare 6000K and 6500K LEDs, free shipping to the UK but takes a little while.
TMaxxJJ
Thanks for this. But I much prefer neutral/warm tints (4000k is favourite), so even at 5400k it’s pushing it a bit.
TMaxxJJ
KawiBoy – Have you modified or upgraded your Q8 in any other way to get those numbers? Other than the XHP50’s and spring bypasses I presume?
KawiBoy1428
No not that I can remember Tinergy 18awg bypass’s on the springs, 18awg leads…
Remember you have to open the emitter holes in the reflector a bit…
I just chamfer the emitter holes to just fit around the emitter pad to keep it centered with out bang it around or use centering rings…
Here are some of my bit(s) I use… some use tapered reamers?
I might of changed the FET to an Infineon? I do that because of the cloned/fake/copied FET and 7135’s that are out there now… I only buy the important stuff from Arrow, Digikey or Mouser… I don’t remember having to do that on the Sofirn Q8…
TMaxxJJ
Thanks KawiBoy!
Dep668
Last seen: 2 weeks 1 day ago
I’d be in for a pair for sure. Have been looking to upgrade my q8 somehow.
RapidLux
RapidLux's picture
Last seen: 5 days 18 hours ago
How much will sustainable lumens increase with 3V 50.2? If I’m not wrong the original Q8 stabilises around 1500 lm.
Dioda
I also wonder about the beam profile. With stock XPL HDs the Q8 has nice balanced beam with some usable throw. Wont XHP50’s change it into all out flooder?
Also did anyone consider swapping the stock LEDs with SST40 5000k? That would be a an interesting build.
djozz
djozz's picture
Last seen: 8 hours 51 min ago
A bit more, maybe 2500, because the 50.2’s are driven in a more efficient current for this output.
djozz
djozz's picture
I do have a Q8 with Luxeon V’s which has comparable output but a bit lower Vf, it does a bit under 8000 lumen. Maybe with SST40’s it will be close to that?
Unloco
Last seen: 8 hours 31 min ago
Interested.
Dutcheee
Last seen: 1 week 20 hours ago
I have the led4power board at home and awaiting a single 50.2 3V 6000K from kaidomain.
I’m planning to reflow it on my B-158 and see if the tint is acceptable. (I prefer warm white)
Thereafter dedome and see what it does to tint & throw. Not sure what the dedoming of a 50.2 will do to it. LEDs usually drop a bit in K due to the tint shift, which might be a bonus.
If satisfactory, I will order 5 extra’s for the Q8.
If a better tint and easier ordering process comes along, I’m definitely interested. The Q8 needs the 50.2s rather sooner than later!
DavidEF
DavidEF's picture
I swapped in 4x SST-40 in a Sofirn Q8 and changed the springs to dual BlueSwordM springs, and it was noticeably brighter than the stock Q8, but I have no way of measuring.
Dioda
How was the beam profile with SST40s?
contactcr
Last seen: 4 hours 14 min ago
I’m going to go out on a limb and say reflowing the emitters on the board is actually just as easy or easier than any other step in the mod.
  • Open the reflector holes (easy too but maybe delicate process and requires a bit you might not have)
  • Find/make a new metal plate and screw to hold MCPCB in place (this could be easy or hard depending on what you find)
  • Get new centering rings (easy)
  • Reflow MCPCB with stove top (easy)
  • Solder wires to MCPCB (easy with flux and clean iron but harder than above probably, lol)
Yokiamy
Yokiamy's picture
Last seen: 18 min 13 sec ago
I have bought the same emitter from KD, the tint is a typical cree one, with a yellow greenish corona.
After i accidently broke off the dome (which was actually a rather good but lucky dedome) the tint clearly improved.
Somewhat warmer, less blueish, and i got rid of the ugly color of the corona
