Convoy 17/22 mm SST40 Driver temperature protection removal
57 posts / 0 new
fluke
Last seen: 2 days 13 hours ago
oweban wrote:
I might do a runtime test of my S11 w SST40 that I’ve taken to 7.2A…
Cant wait, will do mine once resistors arrive.
Already removed NTC.
oweban
oweban's picture
Last seen: 1 hour 53 min ago
I left the NTC on…. it gets pretty hot at 7.2…..
fluke
Also did S2+ M3 M21A M21B.
I’ll risk it, much improvement in output?
oweban
oweban's picture
300-400lm I think – I’m basing it off this:
http://budgetlightforum.com/node/58900
My lumen tube isn’t quite ready Sad
Yokiamy
Yokiamy's picture
Last seen: 20 min 45 sec ago
I gained around 300 lumen with an R050 on the SST40.
The FT03 is still brighter, its driven quite hard
Barkuti
Barkuti's picture
Last seen: 54 min 16 sec ago
Anthon wrote:
We’re near, I’m from Molina de Segura, Murcia Big Smile
KnHawke wrote:
Barkuti wrote:
Overaggressive throttling? Could you or someone else explain this a little bit better?
In what reviews I spotted of the SST40 based S21A, when you engage Turbo Mode, it almost immediately starts stepping down, pretty much negating anything useful of that mode.
Wow, so bad?
I have to replace the driver in my nephew's S2+, torch predominantly used with the short tube, guess I won't mess with thermal throttling in that one. The other driver, though, is another story.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
kinhcan55
Last seen: 8 months 1 week ago
Hello guys
What about the Convoy M3 driver ?
How can i remove it?
Yokiamy
Yokiamy's picture
Maybe this thread helps, driver might be sonewhat different though
http://budgetlightforum.com/comment/1551077#comment-1551077
kinhcan55
The M3 has different driver, I’m not sure I find it correctly =((
kinhcan55
I think i found it =D
EasyB
Last seen: 5 min 12 sec ago
Good info. I just ordered a few of these and I’m sure I will do this mod.
These drivers with the stepped modes look like constant current linear mode FET drivers like led4power’s. Is the other ‘ramping’ driver from convoy mentioned above also this type of driver? The description and UI seem strange. Is the current limited to 8A?
jacc
Last seen: 1 hour 13 min ago
Barkuti wrote:
Satan@103TFS wrote:
@Barkuti what do you think if I just bypass “5mΩ” with the wire to run XHP50.2 3V I’m not sure if it a good ideal.
If you do that the driver won’t be able to regulate at all. This means no ramping and no modes. I haven’t tried it, though.
You still need to tweak the sense resistor stack value for it to work. You could try an R004 on top, it could work well or it may not. Add some heatsinking to the thing in such a case, as you’ll be above the maximum power rating for single 1206 resistors (a couple stacked one doesn’t changes this significantly). A good mound of thermal glue above sense resistor and MOSFET could help.
oweban wrote:
… I assume R010?
So what I’m understanding is that more resistance = higher amperage… Now to work out the right number to hit ~7.5A Smile
If the driver uses R010 for 6A this means sense voltage is Vsense = R × I = 10mΩ × 6A = 60mV. If you want to add 1.5A, you need Rextra = V / I = 60mV / 1.5A = 40mΩ or an R040 in parallel with the existing R010.
I have not measured how that driver behaves actually but if you really want to be sure to hit 7.5A, add some more conductance is my advice. I’d look for an R030, which would raise the maximum current to 8A theorerical (6A + 2A), albeit it would leave the actual figure in close proximity to 7.5A effective due to MOSFET heating, imho.
Hi Barkuti & folks,
Can I ask, where is the sense resistor on this board to be sure?
https://nl.aliexpress.com/item/33024197621.html
I have ordered the 20mm board 6A version which I supposed is the same as the 17mm/22mm one. Would you be so kind to show me where it is? thanks
Funtastic
Funtastic's picture
Last seen: 24 min 16 sec ago
Look at your link picture and it clearly shows R010
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Barkuti
Barkuti's picture
https://www.aliexpress.com/item/33024197621.html
The sense resistor is that big R010 chip resistor onboard, down there in this photo:
That looks to be 2010 imperial size.
jacc
Thanks for the reply, Guess what? I have bought the 1210 sizes and its on its way! Haha, I read it off other threads of the similar driver but in a 17mm size I think?
Since 2010 size is 5mm x 2.5mm and 1210 is 3.5mm x 2.5mm, I suppose this allows me to join two resistors serially to lower the output (which was my main objective anyway).
I actually do see another R010 on the board, at the left side of the 10pin IC. Could that be the sense resistor as well? Regs
oweban
oweban's picture
The sense resistor is the small black one at the very right of the board in that pic; “north east” of the MCU
jacc
Oh thanks for the double confirmation. Looks like I will be having a tough time trying to fit 1210 resistors there Big Smile
Funtastic
Funtastic's picture
I don’t think you’re correct. Barkuti has modified these boards before so I’d be more inclined to trust his answer
oweban
oweban's picture
Oops sorry I was thinking about the thermal resistor. Brain dead lately.
Apologies everyone, barkuti is right. I’ve done the mod on those sense resistors myself.
Funtastic
Funtastic's picture
Anyone know which component is the thermal resistor on the 17mm driver of post #6? (bottom picture). There’s two components within the drawn cicle
Barkuti
Barkuti's picture
The upper one Funtastic. I could also say the rightmost one, and so it is valid for both top (∅22 mm) and bottom (∅17 mm) driver pictures.
Funtastic
Funtastic's picture
Awesome, many thanks
jacc
20mm driver: https://www.aliexpress.com/item/33024201368.html
AON 7220 Mosfet: http://www.datasheet-pdf.com/PDF/AON7220-Datasheet-Alpha&OmegaSemiconduc...
Strange though, when looking into the datasheet of the MOSFET, it seems like the big R010 resistor is connected to the Source terminal of the MOSFET (the first 3 pins of the MOSFET are tied together). The Gate pin on the other hand is not connected to the R010, it goes under the MOSFET (or under) to another location. We can see that all the remaining pins on the right side of the MOSFET (4 pins) are connected together as the Drain terminal, which means the datasheet is correct to the MOSFET used here.
I m not good at electronics. Does the Gate terminal connect to the “sense resistor” to bias the Vgs?
polarweis
polarweis's picture
Last seen: 1 day 42 min ago
Can i just remove the temp thingy with a soldering iron? Do i need to bridge something after removing it?
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
icpart
Last seen: 18 hours 3 min ago
Yes sense resistor is connected to the source, the linear driver is exact the same as typical Electronic load circuit https://www.codrey.com/electronic-circuits/simple-electronic-dc-load/
Yokiamy
Yokiamy's picture
1 Yes you can
2 No do dont
