Measuring m43 mcpcb at 4v and emitters dont turn on, help!
6 posts / 0 new
trailhunter
Last seen: 3 weeks 2 days ago
Hi all, going through a reflow. I tested each emitter on the mcpcb by touching the anode and cathode side, all emitters individually light up but when I touch the leads to the mcpcb, none of them light up. Is there a short in the mcpcb or do I need to up the voltage when testing the mcpcb directly?
bilakos10
bilakos10's picture
Last seen: 11 hours 56 min ago
Measure the resistance between the mcpcb's positive and negative pads. If there's a short, you should be getting a reading.
Also, I am speculating that you might have soldered the emitters in reverse polarity. In that case, the emitters should light up after you reverse the leads.
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
trailhunter
Dale helped clarify in another thread. I was only testing the mcpcb at 3v. I bumped up the power to 6.9v and all 12 emitters showed a faint light, just enough to test my reflow. Thanks for circling back so quickly bilakos! Love how people are very active here Smile
bilakos10
bilakos10's picture
Ah, I totally missed the fact that the meteor is wired in series Smile
Good for you that you figured everything out!
DB Custom
DB Custom's picture
Last seen: 6 hours 37 min ago
Some of us are maybe TOO active, look at my post count…. Facepalm
raccoon city
raccoon city's picture
Last seen: 1 hour 30 min ago
Congrats on 20,000 posts!  :BEER:
