If an LED has that little plastic ring around it
7 posts / 0 new
scosgt
Last seen: 1 week 1 day ago
I forget what it is called, but Convoy for one has it.
When replacing the emitter, how do you mount that ring?
Do you use glue or?
MascaratumB
MascaratumB's picture
Last seen: 47 min 46 sec ago
Are you talking about the gaskets that are put around the LEDs?
Those are put in place by simply placing it around the led.
Make sure you have the right gasket for your LED.
Meaning : XML2/XHP50 Leds need 5050, XPL need 3535, …
Also try to see if the top diameter is for reflectors 7mm holes or with 9mm hole (diameter in the base) .
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
scosgt
Not the gasket. The small plastic washer. I saw what it is called, but forgot. Some kind of shield.
MascaratumB
So, not these?
https://convoy.aliexpress.com/store/group/Gasket-Lanyard/330416_51272365...
I can’t remember what it is then Oops
jasontheguitarist
Last seen: 9 hours 15 min ago
http://kaidomain.com/Flashlight-DIY-and-Tools/Misc-Parts/S028303-20mm-Transparent-Plastic-Insulation-Gaskets-5pcs
Like these?
I’ve only had one light use this thing, and it just sits on top of the LED MCPCB, it’s held in place once everything is put together.
Edit: I see OP did mean the centering gasket after all.
scosgt
This:
https://www.aliexpress.com/item/32575732360.html?spm=2114.12010612.81483...
How is it secured? When I took apart the L6, I had to use some force to remove from the board.
Enderman
Enderman's picture
Last seen: 16 hours 39 min ago
scosgt wrote:
This:
As you can see, it is called a ‘gasket’ and is used to align the LED in the reflector hole.
Usually they are not stuck on with anything, they are held in by the reflector.
Heat could have melted the plastic and made it stick a bit.
