18650 branding plastic came off.
16 posts / 0 new
Lightfreak101
I had a thrunite 18650 3400mah. The plastic came off and I was left with what the linked picture shows. Which is a LG variant of cell. My question is, does this mean this cell is unsafe now the plastic is removed, or are they talking about the purple barrier? https://pasteboard.co/IspUSb3.jpg
Edited by: Lightfreak101 on 08/12/2019 - 19:24
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 9 hours ago
The cell is still safe, but I’d still rewrap it to protect the protection circuit just in case.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 17 min ago
Unless it’s needed, I’d just (carefully) pull off the protection circuit and have a perfectly fine nekkid cell.
I imagine the sense-strip running down the side is exposed, eh? That would be a Bad Thing if it shorted against the battery-tube inside the light.
Lightfreak101
I’m not aware of any strip going down the side, just this purple coating. So without brand name plastic over it should it be okay to use. I see what your saying about the protection circuit on top. Here’s two additional photos for better perspective https://pasteboard.co/Isqi0ie.jpg https://pasteboard.co/Isqigxd.jpg
Lightbringer
Then maybe it’s actually an unprotected cell, or the connection to negative is around the rim of the pointy end.
varbos
Last seen: 12 hours 19 min ago
This design has the PTC on the anode. There is no strip running down the length.
http://i50.tinypic.com/2znob2s.jpg
https://cdn.practicaldatacore.com/batteryjunction/mod_productReviews/use...
Personally I would rewrap before use.
How did the entire wrapping “come off” ? If you are the rough or careless type, you should consider switching to safer AA type flashlight.
wle
wle's picture
Last seen: 10 hours 15 min ago
could you recover it in electrical tape or something?
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
amishbill
amishbill's picture
Electrical tape is going to be too thick for some tubes, and likely to make a sticky mess.
If you can give me a good measurement of the cell length, I can cut & send you some shrink tube that will/should fit. A hairdryer will shrink it down. You’ll just have to remember that your fingertips are not fireproof.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
Lightfreak101
What’s the purpose of the branding plastic? Its all just a plastic sleeve with company names and battery specs. Advertising aside, what does the plastic function as? I do not mind to wrap it back up. Question is though, can it be used in its current state safely?
tempo
Last seen: 3 weeks 2 days ago
it cannot imho
you could take measurements with your DMM to verify
Barkuti
Barkuti's picture
Last seen: 7 hours 4 min ago
  1. To re-brand the cell. Battery re-wrapping companies' business.
  2. Protection. The cell body is polarized (negative).
  3. You can use it as it is, at your own risk. I guess it may short-circuit inside a flashlight tube due to the exposed metal, so better rewrap it.
Fasttech sells some slightly longer wraps (75 versus 72 mm) which may fit more or less nice (or you can buy some roll). Example: https://www.fasttech.com/product/9633946
Use BLF at checkout. Wink
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts or at least trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Lightfreak101
Sounds like the answer is wrap it up lol. Thanks for all the info!
Lightfreak101
So if anybody wants this battery, because honestly I don’t feel like wrapping it. I will send it to you for free lol. Just let me know. So, I have never sent a battery by mail before. I read some rules on US mail website wow. Kinda took the fun out of it, what’s everyone else really do when they send these?
BlueSwordM
It’s actually really easy.
What you need:
18650 battery wrap.
Hairdryer.
SIGShooter
SIGShooter's picture
Last seen: 6 hours 55 min ago
If you really don’t want it I’ll take it
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
amishbill
amishbill's picture
What you need:
18650 battery wrap.
Hairdryer.
…. and I even had an envelope, stamp and roll of blue shrink waiting on the length of the battery.
