Small head 18650 zoomy
20 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 13 hours 9 min ago
I’m looking for a compact zoomy with twist for the zooming function and removable pill.
I’ve used the Brinyte B168 which is perfect except for the bulky head compared to the lens size.
Any ideas appreciated.
Thanks in advance.
Agro
Agro's picture
Last seen: 1 min 54 sec ago
Out of curiosity, why do you prefer a twisty zoom?
Mike C
Mike C's picture
Last seen: 2 months 2 days ago
Is the Tank007 TK-737 still available? It looks fairly decent: http://budgetlightforum.com/node/2805
It’s a twisty zoom with a head that looks smaller than the B168. Don’t know about the removable pill or it’s lights availability though.
MRsDNF
MRsDNF's picture
So it cant zoom by itself when firearm mounted.
MRsDNF
MRsDNF's picture
The Tank is for sale at FT. Rather expensive. Does anyone know whether its a twist zoom?
SupFire F3-L2 Boaz mentioned in a PM. Is this a push pull or twisty zoomy. Cant find any reviews that mention it.
Thanks all.
1stein
1stein's picture
Last seen: 1 week 5 days ago
You could try Uf T20 , but the head is not much smaller: 45mm VS 54mm in B158
raccoon city
raccoon city's picture
Last seen: 2 hours 45 min ago
The Tank007 TK-737 is a twist zoom.
(I have one.)
MRsDNF
MRsDNF's picture
Thanks rc.
I have the UF T20. Just bigger than I want.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 3 hours 16 min ago
What size head do you want? Like 20mm zoomie?
MRsDNF
MRsDNF's picture
Something similar to the Brinyte B168 lens size but a more compact head diameter wise.
blitzwing has some good measurements here.
http://budgetlightforum.com/node/44106
jim48
Last seen: 1 week 14 hours ago
there is a cheap 3 x aaa , 18650 on ebay
https://i.ebayimg.com/images/g/HFAAAOSwJp1cP0gv/s-l1600.jpg
Zoomable 6000 Lumen 5 Modes T6 LED 18650 Flashlight 20000LM Torch Lamp Light BG _ eBay
$4.61 usd i wait for mine.
DavidEF
DavidEF's picture
Last seen: 1 day 8 hours ago
That is a push-pull zoomie. But it brings up an interesting subject. Most flashlights that are compatible with both 3xAAA and 1×18650 can by default also fit 21700 cells. This being the case, there are LOTS of 21700 compatible lights on the market that don’t claim to be. (Probably, they just didn’t think about it) Since 21700 is barely bigger than 18650 to our hands, but holds capacity like 26650, this is a big deal.
- The YKK Philosophy
jim48
Lightbringer
Lightbringer's picture
Last seen: 5 hours 9 min ago
Howbow a ’502 or similar drop-in?
At least in theory you can get one of these:
https://www.illumn.com/ahorton-27-2mm-aspheric-glass-lens.html
with the spacer and tweak it to as much/little as you want it focused (how far you screw down the spacer onto the pill, replacing the reflector of course).
I say “in theory” because it’s not so great from personal experience, as both lenses I got have a flattening or “bellybutton” at the top which distorts the beam. With a good lens, though…
And a ’502 (or similar) should fit fine on Picadilly rails.
MRsDNF
MRsDNF's picture
I had that thought Lightbringer but really need the twist zoom function. The torch itself will end up with a UV led in it.
amishbill
amishbill's picture
Last seen: 1 day 18 hours ago
UV in a weaponlight?
I’ve really gotta hear about your use case!
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
Lightbringer
UV? Better be UV-rated material, then, like quartz.
Plastics can turn yellow or brown, as well as block UV.
Only twist-zoomie I know of it the Cometa.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 35 min ago
Some suggestions, assuming that you will mod them! (BTW, I once tried a Nichia UV 365nm in a Odepro KL52 = Brinyte B158 and…it didn’t get much result Oops Not sure if it was my problem modding or if the UV didn’t pass well through the lens, but it didn’t go as good as I wanted…)
Push pull, compact light:
https://www.aliexpress.com/item/32873091457.html?spm=a2g0o.productlist.0...
Push pull, C8 style:
https://www.aliexpress.com/item/32820663551.html?spm=a2g0o.productlist.0...
UniqueFire Mini twisty zoomable (UF-1507)
https://www.aliexpress.com/item/32614963463.html?spm=a2g0o.productlist.0...
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Lightbringer
Just try it. Take a WK30, UV-S2+, etc., and try shining the light (in darkness) through an aspheric lens, TIR, whatever you’re planning to use.
If plain paper that’d otherwise light up like it’s on fire, well, doesn’t, then the UV light is being blocked.
MRsDNF
MRsDNF's picture
Did I say UV? Blame djozz. I should have said IR. Sorry guys. Blushing
