XTAR PB2S
51 posts / 0 new
Klotski
Klotski's picture
Last seen: 1 hour 45 min ago
Lightbringer wrote:
The XTAR store.
Thanks
UserM4
If anyone’s interested, I did a charge comparison against a wall charger and another power bank.
https://imgur.com/a/veExc6B
SwissFlashy
Last seen: 12 hours 29 min ago
@UserM4 thanks!
The PB2S is already out of stock on Aliexpress. The owner told me the red ones should be available next week, the black ones will be delayed.
SwissFlashy
It is back in stock!
KevinZA1988
KevinZA1988's picture
Last seen: 24 min 40 sec ago
Just ordered a res one. Thanks for the heads up!
Astrolux SC01, BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L2, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
david_opp
Last seen: 34 min 17 sec ago
Does someone have first impressions of the magnetic latch? Are the magnets strong enough to hold it securely in place even when tossed in a backpack?
Lightbringer
Lightbringer's picture
Last seen: 3 hours 7 min ago
Yeah, you need to actually pry into the crease between door and body to open it. It’s not likely to just pop open on its own.
Cythras
Cythras's picture
Last seen: 6 days 5 hours ago
Illumn has been advertising QC 3.0 AND PD charging, but the official specs don’t mention a 12v output. Judging from the OP, I suppose it doesn’t actually support PD?
Funtastic
Funtastic's picture
Last seen: 10 hours 37 min ago
https://www.candlepowerforums.com/vb/showthread.php?461497-Test-review-o...
Check out this review as it talks about the 12v output
Texas Ace Lumen Tube calibrated with maukka lights
Funtastic
Funtastic's picture
The cons are high parasitic drain, inaccurate display, batteries must be able to handle 2A charging
Mishanchik
Mishanchik's picture
Last seen: 9 hours 40 min ago
that’s not all the cons:
https://lygte-info.dk/review/Review%20Charger%20Xtar%20PB2S%20UK.html
5V-2,7A
9V-1,7A
12V-1,2A
Not full compatible with Quick Charge 3.0
Funtastic
Funtastic's picture
I knew I forgot something.
fran82
Last seen: 3 weeks 21 hours ago
Also expensive
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Funtastic
Funtastic's picture
fran82 wrote:
Also expensive
I purchased from here – https://s.click.aliexpress.com/e/Md0YloN2
Message the seller and he’ll send you a $5 USD discount coupon
bmengineer
bmengineer's picture
Last seen: 23 min ago
FlashPilot wrote:
Hopefully Xtar has a copy in its way to HKJ for detailed analysis.
It appears they did indeed. HKJ has now posted his review .
I’ve posted my review on my site as well.
Find all my reviews of flashlights and more gear at www.bmengineer.com
chinooker
chinooker's picture
Last seen: 3 hours 51 min ago
The Rofis protected 26650 (69.6mm) fits, butt the Rofis protected 21700 (75mm) does not.
Lightbringer
Yep, that’s how I charged my Cometa in a pinch.
Using the scientific miracle of a small wad of Al foil, I was wanting to charge a 14500 yesterday, too, but stopped when I saw it was charging at close to 2A. Didn’t want to cook it. Laptop port, too, so was hoping it’d be limited to 500mA.
Klotski
Klotski's picture
!{width:100%}https://i.imgur.com/i2KuGuo.jpg!
So how does it work on smaller devices or did they screw the pouch again
bmengineer
I tested it in my review with 0.1A and it worked just fine.
chinooker
chinooker's picture
Yes, the low current mode, accessed by holding the side switch, will charge my MP3 player and bluetooth headphones. The display blinks to indicate you are in low current mode.
