Test/review of Keeppower 18650 3600mAh P1836J (Black) 2019
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 22 min ago
DSC_6884
Official specifications:
  • Capacity min.: 3450mAh
  • Capacity typ.: 3550mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20+/-0.05V
  • Standard discharge cut-off voltage: 2.50V
  • Standard charge current: 1800mA
  • Charge termination current: 50mA
  • Max. continuous discharge current: 8A
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-info
This is a protected high capacity cell from Keeppower.
DSC_6883
DSC_6885 DSC_6886
DSC_6887
DSC_6888
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-Capacity
The discharge curves tracks nicely and the protection kicks in when drawing too much current.
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-Temp-5.0
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-Temp-7.0
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-CapacityTimeHours
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-Energy
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-PowerLoadTime
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-TripCurrent
Keeppower%2018650%203600mAh%20P1836J%20(Black)%202019-Charge
Keeppower%2018650%203600mAh%20P1836J%20%28Black%29%202019-Pulse-1.0A-10-10-2.8V-IR
Conclusion
This is some of the highest capacity 18650 batteries on the market, but they have about the same capacity as 3500mAh rated batteries.
It is a good cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Barkuti
Barkuti's picture
Last seen: 1 hour 54 min ago
Totally looks like an overrated Samsung 35E rewrap with protection circuitry.
I see the label says “Cell & IC made in Japan”, for which the former I find I bit dubious.
Thanks.
Superstocker
Superstocker's picture
Last seen: 6 hours 15 min ago
Thanks HKJ!
mrheosuper
Last seen: 1 day 7 hours ago
Thanks.
or maybe NCR18650B, a quite common choice
Forgot my pen
Barkuti
Barkuti's picture
Too low capacity, the NCR18650B barely does 3300mAh without a protection circuit, much less with one attached.
The shape of the discharge curve does not match with that of an NCR18650B. It matches accurately with the one of a Samsung 35E.
If HKJ were to dismantle cell rewraps some nice information we would obtain.
SubLGT
Last seen: 5 hours 20 min ago
Over at Illumn.com (who is the North American distributor for Keeppower batteries) the cell for #P1836J is listed as the Panasonic NCR18650G:
https://www.illumn.com/batteries-chargers-and-powerpax-carriers/batterie...
But when I look at the 1A and 5A discharge curves for the P1836J and the Panasonic G, they do not look very similar.
