[Preview] EDC18 by Lumintop - FIRST LOOK of a Anduril sideswitch EDC flashlight
160 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 4 hours 58 min ago
Hello my dear friends!
Today i preview the Lumintop EDC18 for you - a 18650 powered sideswitch flashlight, driven by toykeepers great Anduril UI.
A reverseable deep carry clip, the tail magnet and the illuminated switch are big improvements of the FW3A idea while keeping the good points of it.
JOIN THE GROUPBUY: https://m4dm4x.com/lumintop-edc18-groupbuy/
if you are interested in a optional 18350 tube vote here: https://forms.gle/dx9mTG1TNvSR2QJu8
THANKS to banggood for the early (preproduction) sample!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
M4D M4X
M4D M4X's picture
Unfortunately the LUMINTOP EDC18 that was reviewed by me here is different in another point than those mentioned in my review!
THE FINAL BATTERYTUBE IS SHORTER THUS THE EDC18 CANNOT BE OPERATED WITH PROTECTED CELLS!
roguesoul
We’re all clamoring for dimensions, or do I have to watch the video…
aswang
Last seen: 56 min 14 sec ago
Thanks for the video. Finally, something I can give my partner without worrying so much. She wants my Anduril lights because of candlelight mode but I can’t trust her with unprotected cells. Hopefully it will come in different colors in the future.
M4D M4X
M4D M4X's picture
roguesoul wrote:
We're all clamoring for dimensions, or do I have to watch the video...
~27mm head
25mm tail
98mm length
roguesoul
Sept 9th! Kind of wish it came with a warm white emitter. My FW3A with Cree XP-L HI 7A 3300K is so good.
avservice
I can not understand how a spring friction fit clip is an improvement over one that is attached to the body that can not come off on its own?
I am carrying the FW3A over the D4V2 just because of the clip.
JasonWW
JasonWW's picture
Last seen: 12 hours 9 min ago
Two things, it is reversible and it is deep carry.
Click this to go to signature links.
middle age man
Last seen: 1 hour 33 min ago
Is the magnet removable and is there a hole to attach a lanyard?
JasonWW
JasonWW's picture
Max has said the magnet and tail pcb are glued into place.
Mocarny
Mocarny's picture
Last seen: 7 hours 47 min ago
Can you check if this diffuser fits on FW3A?
M4D M4X
M4D M4X's picture
it does not Sad
avservice
I got that part but what I meant to convey is that I have never had one of those clips that would not unclip without my permission.
So I try to avoid them at all cost.
JasonWW
JasonWW's picture
I’ve only had that happen when I carry the light on the outside of my pocket. You can take a weak clip and bend it so it holds on to the body tighter. Nowadays my clips are mainly just to prevent it from rolling away. Lol
Chatika vas Paus
Last seen: 1 hour 44 min ago
Lumintop is LAZY.
Why did they use the driver design from fw3a? It has been designed for use with tail switch flashlights.
By designing a normal driver they could improve heat dissipation from AMCs.
edit.
At the beginning I was interested, but now when I look at this outlier button I dunno that I want this light…
Martin, how hard is this button? Can you compare to something?
M4D M4X
M4D M4X's picture
harder than Emisar D4
JasonWW
JasonWW's picture
Chatika vas Paus wrote:
Lumintop is LAZY.
Look closer, it is designed differently. There is no inner ring. They kept the same FET+7+1 architecture and software because it works just fine. I don’t think there is a problem with AMC’s getting hot. They can handle over 250°C during reflow. I have not heard of heat being any kind of issue. Have you seen reports of heat being a problem for the AMC’s?
jimahi
Last seen: 2 days 21 hours ago
I’ve seen nothing anywhere that answers the following:
1. Is the side switch illuminated?
If so,
2. Can the side switch be controlled by Anduril?
3. Is the side switch only one color LED, or is it multi color?
4. Can the side switch be used as a locator?
Anyone know the answers to these questions?
Thanks!
JasonWW
JasonWW's picture
If so,
Thanks!
1 yes
2 yes (seems possible, have to wait for confirmation)
3 single
4 it stays on, so yes.
jimahi
Great, thanks!
I felt kind of dumb asking the question since it seems like such an obvious bit of information that would be posted on the product page or otherwise readily available.
Just curious so I know where to look next time before I ask… where did you find that info?
Johm
Last seen: 1 hour 24 min ago
@M4D M4X
Can you please weigh the EDC18 when you get a chance?
I feel the 53g spec on Banggood is incorrect, copied over from the FW3A specs.
JasonWW
JasonWW's picture
jimahi wrote:
Great, thanks!
I am familiar with the pinouts on the Attiny85 and the Anduril code.
I did not find this info about the EDC18, but I can deduce it based on the hardware.
M4D M4X
M4D M4X's picture
Johm wrote:
@M4D M4X Can you please weigh the EDC18 when you get a chance? I feel the 53g spec on Banggood is incorrect, copied over from the FW3A specs.
my kitchen weight gives me 75g (prototype)
M4D M4X
M4D M4X's picture
jimahi wrote:
I've seen nothing anywhere that answers the following: 1. Is the side switch illuminated? If so, 2. Can the side switch be controlled by Anduril? 3. Is the side switch only one color LED, or is it multi color? 4. Can the side switch be used as a locator? Anyone know the answers to these questions? Thanks!
have you watched my video?
1. yes
2. i am not sure
3. yes (green bunny)
4. its on in "standby" so: yes
JasonWW
JasonWW's picture
M4D M4X wrote:
jimahi wrote:
I’ve seen nothing anywhere that answers the following: 1. Is the side switch illuminated? If so, 2. Can the side switch be controlled by Anduril? 3. Is the side switch only one color LED, or is it multi color? 4. Can the side switch be used as a locator? Anyone know the answers to these questions? Thanks!
1. yes
2. i am not sure
4. its on in “standby” so: yes
Concerning #2, Anduril can certainly control the switch light with options like off, dim, bright and blinking. We see this with other side switch lights using the same driver parts and Anduril. I see no reason why Toykeeper would disable this function in Anduril. There is no reason to. I have to assume it is controllable. (Better to assume it’s not controllable, waiting for confirmation)
I don’t know if your prototype can do it, but try this. From Off, do 7 fast clicks and see if the switch light changes. To cycle to the next option, repeat with 7 fast clicks.
Here is the newest Anduril cheat sheet.
You can try the color change as well, but I doubt they installed multi colored LEDs for the switch. 7H means 7 fast clicks and Hold the button on the last click (iirc).
christoph
Last seen: 1 day 9 hours ago
Got in on the preorder thanks. Not that I need another light Big Smile
Chris
M4D M4X
M4D M4X's picture
I think the bunny is wired to the battery
it's not controlled by Anduril
Fireflies also had only 2 of 4 leds in the switch controlled by the UI
(also my sample only has one Lockout brightness)
christoph
So what did I preorder?
Chris
jimahi
1. yes
2. i am not sure
Yes, I did watch the video M4D M4X. Thanks for putting that video together. However, it didn’t cover what the switch light actually did. It looked like it was illuminated.
Sounds like there is still some confusion on exactly how the illuminated switch function works.
M4D M4X
M4D M4X's picture
i hope i get one of the first sale version lights to clear all questions
Watermanchris
Last seen: 2 hours 33 min ago
I got in on the preorder! Thanks for the code!
