Test/review of PowerFalcon PD laptop charging cable
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 15 min 15 sec ago
DSC_7861
This is a cable to charge any laptop with about 20V charge voltage from a USB-C PD charger.
DSC_7809 DSC_7810 DSC_7829 DSC_7812
DSC_7813
It arrived in a cardboard box.
DSC_7866
It is a cable.
DSC_7868
One end is a USB-C connector, that must be connected to a USB-C PD charger that can deliver 20V
DSC_7867
The other end is a replaceable laptop power connector. This connector can only be connected one way, there is no risk of wrong polarity.
DSC_7862
DSC_7863
DSC_7864
DSC_7865
Eight of them in a nice strip, the last is on the cable, this means a total of 8 different connectors.
08_EN
This is the official compatibility list.
Measurements
  • Uses PD mode: 20V 3A
  • When correct PD mode is missing it will enable 5V
  • Uses about 16mA for its internal electronic
  • For testing I used the G plug (5.5/1.7mm) it fitted nicely into a 5.5/2.5mm socket.
PowerFalcon%20PD%20laptop%20charging%20cable%20load%20sweep
The voltage and maximum current depends on the USB-C PD charger, because the cable is using 3A mode my charger shuts down a bit above 3A.
PowerFalcon%20PD%20laptop%20charging%20cable%20load%20test
I did a 1 hour test at 3A to see if anything got hot, the photos below are taken after about 45 minutes.
Temp7013
M1: 33.8°C, HS1: 36.7°C
Not surprising a rolled up cable gets hotter when the different turns can heat each other, but nothing serious. The cable is thick enough for 3A charge in rolled up condition.
Temp7014
HS1: 42.0°C
The USB-C plug gets a bit warm, but again nothing serious.
Temp7015
The laptop plug has some temperature increase also, but again it is perfectly acceptable.
Conclusion
The cable works nicely, but requires a fairly powerful USB-C PD charger.
Notes
I got this cable from reader “Mostly Melbourne”
For testing I used this USB-C charger
Shadowww
Last seen: 2 hours 16 min ago
Would 20V be an issue for a laptop that normally takes 19V? I’d assume not, but I don’t want to risk it myself Silly
HKJ
HKJ's picture
I would not expect any problems with that.
Barkuti
Barkuti's picture
Last seen: 45 min 1 sec ago
There shouldn't be any problems, just shouldn't.
I once tried a genuine HP 19V 90W (PPP012L-E) power supply on a Dell Vostro 2520 (stock supply 19.5V 65W) and on boot up it complained of a weak power supply. Of course that was wrong and due to the slightly lower supply voltage.
The Light Innocent I am
qwertsun
Last seen: 1 week 6 days ago
Thank you for reviewing this. I have always been interested in such a cable and intially, wanted to get Innergie’s 60C + their laptop cable, just to realise the cable will only work with their charger,
Binford
Last seen: 7 hours 37 min ago
interesting cable, reminds me of the block power supplies of the 1980s where you had adapters for each device.
Barkuti
Barkuti's picture
Remarks:
The above connectors' image has an incorrect aspect ratio at the given size (866 × 576) due to stretched height. It looks about correct at 866 × 480:
HP uses a big tip whose dimensions are 7.4mm × 5.08mm outer/inner diameter, with a center pin. It looks quite close to the leftmost plug in the following picture:
However, I cannot find a direct match for it in the above table (other than the 6.5 × 1.4mm Sony/Samsung reference, I mean).
Seriously?
