POLL: USB charging on Foursevens lights or not?
21 posts / 0 new
Got Lumens
Got Lumens's picture
Last seen: 1 day 6 hours ago
Love it
39% (15 votes)
Hate it
39% (15 votes)
Take or Leave it
21% (8 votes)
Total votes: 38
Neutrālisflashaholic
Got Lumens
Hey gang,
Just doing a quick poll on USB charging preferences. I have a bias, but I wanted to do a poll before expressing it
I'd appreciate it if you'd also make a brief comment about why you love/hate USB charging. This feedback will affect the next gen MMX and MMU-X3 lights.
Cheers
Jason
Got Lumens
I don't care for USB charging.
#1 It always requires a proprietary cell to function as designed.
#2 You almost always cannot safely charge proprietary cells in an existing charger without risk.
#3 Goes with #2, it becomes difficult to carry spare cells when the only charger is the light.
LloydV
Last seen: 2 weeks 4 days ago
for my personal use, hate it for the reasons you have already stated.
however, when giving flashlights as presents, they do serve a purpose (for me, specifically).
then there are things like the LT1, which technically isn’t a flashlight, which can be hooked up to a solar charger when you’re out camping for days.
neo71665
neo71665's picture
Last seen: 1 month 6 days ago
Take it or leave is but I lean towards hate it for the reasons stated
Henk4U2
Henk4U2's picture
Last seen: 8 min 45 sec ago
Hate it. Most of them come with a rubber flap that gets lost sooner or later.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Gj
Gj's picture
Last seen: 6 days 8 hours ago
Mostly I hate that I can’t find the switch in the dark. I always find the rubber charging port cover first, even if it isn’t already pulled open and flopping around. I really hate that. Then, of course, all of the above reasons, plus it’s another possible point of failure and it may make it more difficult to mod or service the light.
djozz
djozz's picture
Last seen: 25 min 26 sec ago
I voted I love it because USB charging is a really really handy feature.
Unfortunately it is hardly ever done well. Many “hates” are not the feature itself but are caused by bad implementation, that interferes with basic flashlight qualities like waterproofness, robustness, compactness and good looks.
I do not have the magic solution but stay away from silicon flaps that look cheap and break off over time.
And stay away from those cheap micro-USB sockets that break off the driver board after a few months use Facepalm , USB-C is superior but even then make those sockets bullet-proof.
Batteries with USB ports are a clumpsy and fragile solution.
I have a weak spot for how the USB port of the Zanflare F1 is covered by a screw ring, but I’m sure that can be designed a bit more subtle.
contactcr
Last seen: 2 hours 26 min ago
I don’t like flaps or the added size so voted for hate it. Also makes DIY mods harder.
Scallywag
Scallywag's picture
Last seen: 23 min 9 sec ago
It’s very hard to do right. I hate most implementations.
If the light remains moddable, and the cell is not proprietary, and the charging system is relatively compact, it’s pretty good. Even better if it’s behind the threads of the head or tail (see lights like Klarus Mini One)
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
samgalax
Last seen: 5 hours 22 min ago
I voted that I like it.
Hope all flashlights were usb rechargeable. Preferably with magnetic connectors instead of ormal plug cables
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
Scallywag
Scallywag's picture
I’m not a fan of proprietary magnetic connectors, nor of the exposed contacts associated with them. I’m remembering a light with a fire hazard…
fran82
Last seen: 1 week 16 hours ago
+1000000000
I love them. Specially the klarus rs-1a that I have. No matter the propietary cable/connector with exposed contacts
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
SKV89
Last seen: 11 min 54 sec ago
I love usb-c charging because it is convenient since everyone has a usb cable at work, at home, or in the car and it makes for great gift lights. I only gift lights with usb charging to muggles. Also please don’t use proprietary charging, as it defeats the purpose of convenience and universal availability and compatibility to charge anywhere. Please use USB-C and not micro USB as USB-C is more robust. I also dislike USB-charging in the battery since I don’t want to constantly unscrew the threads and get thread grease on the contacts. After a while output can drop 20-50% on so many occasions that I’ve tested and I have to clean the contacts with alcohol to restore the peak output.
Many USB rechargeable lights are very small. The Acebeam EC65 21700 light with USB-C is about the size of an average 18650 light. It is also easy to take out the mcpcb. To me, if the stock driver is good, I see no point of changing drivers. Just being able to change the emitters is good enough.
Agro
Agro's picture
Last seen: 1 hour 32 min ago
I love it when it comes with a powerbank capability, in lights large enough for it to matter (18350 and more).
Otherwise – it depends, for some uses I require it for other I avoid it.
lightwonder
Last seen: 2 months 1 day ago
I like usb charging built in if its well done, but i do wonder how much they effect the waterproofness.
will34
will34's picture
Last seen: 2 min 2 sec ago
Depend on the size of the light… on keychain and compact pocket lights with <18650 batteries it’s a handy feature since they discharge fast and otherwise I’d need a low current charger.
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 2 days 23 hours ago
Most built in USB chargers i have tested do not produce enough voltage to fully charge 18650 or 26650 ok if you’re happy with an 80-90% charge but i prefer 100% standalone charger for me thanks, its also nice to know how many MAH your batteries took and guarantee they are properly balanced in multi cell rigs
The concept itself would get a like from me if it was properly implemented
tempo
Last seen: 4 hours 14 min ago
Got Lumens wrote:
This feedback will affect the next gen MMX and MMU-X3 lights. Cheers Jason
How can you say that?
Are you the Jason from Promethues Lights?
Kindle
Kindle's picture
Last seen: 1 day 10 hours ago
I tend not to be a fan, primarily because it means additional size & one more point of failure. It also hurts when (as others have pointed out) many of the implementations of integrated charging have been less than ideal.
That being said I do think it has it’s place and can be a useful feature under the right circumstances.
Nord
Nord's picture
At this point I am really only interested in lights with USB charging. It just makes sense. I am leaning towards a philosophy that a light must either take primary cells, or feature onboard recharging.
We don’t charge our cell phone or laptop batteries outside the device anymore. (I would always want removable/replaceable common batteries however, unlike most modern consumer electronics.)
As someone said above, the issue is in implementation. Many companies need to improve how it’s implemented. Only a few do it right.
When done right it adds little or no more bulk and minimal complication. Hell most 18650 lights already have wasted space or superfluous material bulk equal to or greater than what USB charging would require. It’s a matter of design.
Look at the new Thrunite T1, it’s smaller than most 18350 lights and has USB.
False. Almost never has such a requirement. And if so that is an engineering choice and not a mark against USB charging.
You don’t need proprietary cells to have USB, so point is mute.
See above.
It doesn’t have to, again that is about engineering choices. See Eagle Eye X2R mods here.
Nord Dictatorship:
Flashlight design violations-
Long press for off - Death Penalty
High ride clip - 35 years hard labor
Protruding side switch - 15 years in prison
Memory mode only after X seconds - 12 years in prison
Only offering outdated Cree emitters - 10 years in prison
*Latest Statutes*
"Two-way" clips - 25 years in prison
Further legislation underway
