Emisar D1sV2 respectively Noctigon K1
251 posts / 0 new
Pavlo
Last seen: 4 hours 20 min ago
Hank, what kind of regulated driver?
Hank Wang
Last seen: 4 hours 5 min ago
There are actually two versions.
One is the 5A Linear regularted driver for the Osram, SST-20, XP-L LED.
The other is the boost 2A/12V driver which is for the XHP35 LED.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Hank Wang
JordanZHP wrote:
Hank do you have any thoughts on the different types of Osram leds in this light,
such as White Flat 1mm (CSLNM1.TG) vs White Flat 2mm (CSLPM1.TG)?
Yes, of course, I have tested both of them.
Pavlo
Stoked to see the boost driver! Thanks Hank
Majoroverkill
Majoroverkill's picture
Last seen: 3 weeks 1 day ago
500kcd!!! Take my money interested! Big Smile
Doug S.
BillyBobJoe
Last seen: 1 month 4 days ago
I’m in for this one. Love it, can’t wait! Thanks for the update.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 min 42 sec ago
Hank Wang wrote:
Yes, we do the customs build, bascially, any 3535 footprint, 3V based LED can be put into it.
Hank, can you offer a custom build with Osram Ostar Projection Compact LE R Q8WP (625nm) with up to 700lm of red light at max. 5A i.a.w. the datasheet
I have this LED installed in theAmutorch New VG10 (bought from Neal) and it makes an amazing bright red thrower. This LED installed into the Noctigon K1 would be great and should perfectly fit to the driver specs.
zak.wilson
Last seen: 5 days 17 hours ago
I’m a little sad this isn’t buck/boost or at least buck. I actually find myself contemplating XHP35 over SST-20 now.
Ceilingbounce – flashlight testing and runtime graphs for Android
lightdecay
Last seen: 6 hours 29 min ago
Looks great!
P33
Hank Wang wrote:
There are actually two versions. One is the 5A Linear regularted driver for the Osram, SST-20, XP-L LED. The other is the boost 2A/12V driver which is for the XHP35 LED.
I’m hoping for XHP35 HI CRI version then Cool
SKV89
Last seen: 9 min 11 sec ago
XHP35 3000K or 2700K hi cri for penetrating the fog would be great
Anthon
Last seen: 22 hours 20 min ago
I guess it doesn’t use Anduril because of the buck/boost driver, does it?
SammysHP
SammysHP's picture
Last seen: 2 hours 40 min ago
Hank Wang wrote:
Anduril UI, yes, fully regulated driver (not DD) with Anduril UI.
Th558
Th558's picture
Last seen: 2 hours 13 min ago
Hank Wang wrote:
id30209 wrote:
Would you consider SST90.2?
I don’t think so, as far as I know, the SST90.2 willl need 20A+ to push it to the maximum
performance, the stock driver can not deliver such high current.
Yes it will only make sense on direct drive. The NI40 SBT90 pulls 22 with a 40T. Would really appreciate it if you could make a FET/DD SBT90 version LOL
Could also make it regulated but have turbo in direct drive.
bmengineer
bmengineer's picture
Last seen: 4 hours 22 min ago
Hank Wang wrote:
sp5it wrote:
UI? Should be on/off Smile
Mike
That driver sounds great. Now put it in a right angle headlamp next, please. Smile
Find all my reviews of flashlights and more gear at www.bmengineer.com
gregor
gregor's picture
Last seen: 1 hour 22 min ago
BlueSwordM wrote:
Here, the 50E is your best bet.
Do you know where can I buy this battery for lowest price?
Delivery to EU.
Thank you
Kind regards
TexasToasted
TexasToasted's picture
Last seen: 17 hours 15 min ago
Looks like I’ll be getting 2 lights Big Smile
I sure hope these will come in green and blue to match my other Emisar lights.
DB Custom
DB Custom's picture
Last seen: 53 min 10 sec ago
Looks great Hank, a real eye opener that I will surely have to buy as soon as it’s listed! Somebody PM me when it goes on sale please so I don’t sleep through it. C? Wake me up man! Lol
Klayking
Klayking's picture
Last seen: 3 months 1 hour ago
So the Osram emitter will be getting around 1.5km throw, which is incredible. What kind of throw (and lumens) will the XHP35 HI version have?
Ryzbor
Ryzbor's picture
I’d love a 3000K XHP-35HI version.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
Pavlo
If the Osram/SST20 version was buck / boost, I would have had a hard time deciding which to get.
Based on the two options, the decision is easy for me, XHP35 all the way.
I hope Hank offers the XHP35 version with warm white 80 and 90 CRI options.
As others have mentioned, warm white penetrates fog so much better. I also find it adds contrast and definition.
Looking forward to see the numbers on throw and lumens. I suspect the XHP35 will be about twice as bright (lumens) as the 3V version, with similar throw.
adam7027
Last seen: 1 day 22 hours ago
Hank Wang wrote:
JordanZHP wrote:
Hank if you see this thread we would love an update on this project Smile
Yes, we are still working on it, here is the prototype photo, it’s not called D1SV2, it’s called Noctigon K1,
with fully regulated driver, it should reach 600+kcd with CSLNM1.TG LED, there will be green/red
beam version, as well as XP-L HI/HD LED with different color temperature.
This is lovely !
F.i.l.a.s wrote:
Hank, could you add an SST20 95CRI (3000k or 3500k or 4000k) as stock light option? A lot of people is interested in this version, as I am. Big reflecter and regulated driver makes all sence for this Hi CRI throwy led.
+1
For 2700K, the SST-20 version could be the best bet, as it has deeper reds, than XHP35 HI (I would still take a 2700K XHP35 HI 90CRI, if it were offered).
For 3500K and 4000K, SST-20 has again strikingly good tint. I have SST-20 3500K and 4000K in Convoy C8 at 3.5A, and the tints I got for these CCT are definitely greenish/yellowish, when driven at low currents, but at 3.5A and above, even these can improve a lot, and they can be feel as almost spot on BBL with reflectors (with TIR, the situation would not be near this good).
If there could be a buck driver for the 3V LEDs instead of a linear driver, then these variants could have noticeably better runtimes on the highest setting, before temperature regulation starts to kick in. It is another question, that maybe a good buck driver around 4.5-5A could be more expensive – personally, I could justify 7-10 extra $ per unit, if I could buy these with a buck driver.
Regarding only efficiency (as of current driver options), I would also vote for the XHP35 HI variants (one 3500K 90CRI and one 4500K 90CRI for sure) – if I take throw/heat ratio, the SST-20 should win, but I guess, not with a linear driver.
Yokiamy
Yokiamy's picture
Last seen: 41 min 10 sec ago
Personally i dont like SST20, i prefer tge XHP35 variant.
And ofcourse the Osram for a laser beam Wink
maukka
maukka's picture
Last seen: 1 day 2 hours ago
And please make the crowd favorite, XHP35 HI 4500K CRI80 (XHP35A-H0-0000-0D0HC445E), an option.
SKV89
Maukka, has anyone tested that variant? What is the DUV?
Klayking
Klayking's picture
Yes, that’s the XHP35 HI I think most people would like to see. Fantastic tint.
Pavlo
I have it in my Zebralight sc600w Hi and it is indeed really good!
contactcr
Last seen: 3 hours 38 min ago
http://budgetlightforum.com/comment/1560964#comment-1560964
Low to High:
Ambient = 1065.7 Lux, CCT = 4199K (Duv 0.0026)
Color Rendering Index (Ra) = 80.0 [ R9 = 13.0 ] R1 = 78.9 R2 = 82.6 R3 = 86.5 R4 = 81.4 R5 = 79.3 R6 = 77.3 R7 = 85.2 R8 = 68.9 R9 = 13.0 R10 = 60.6 R11 = 81.6 R12 = 61.7 R13 = 78.5 R14 = 92.6
Ambient = 6972.3 Lux, CCT = 4429K (Duv 0.0048)
Color Rendering Index (Ra) = 78.5 [ R9 = 3.9 ] R1 = 76.4 R2 = 81.1 R3 = 86.3 R4 = 79.8 R5 = 77.2 R6 = 75.4 R7 = 84.9 R8 = 66.6 R9 = 3.9 R10 = 57.5 R11 = 79.3 R12 = 58.7 R13 = 76.3 R14 = 92.7
Ambient = 36717.2 Lux, CCT = 4390K (Duv 0.0051)
Color Rendering Index (Ra) = 78.4 [ R9 = 1.8 ] R1 = 76.0 R2 = 81.3 R3 = 86.9 R4 = 79.5 R5 = 76.7 R6 = 75.4 R7 = 85.3 R8 = 65.7 R9 = 1.8 R10 = 57.8 R11 = 78.4 R12 = 57.7 R13 = 76.0 R14 = 93.1
Ambient = 98188.8 Lux, CCT = 4684K (Duv 0.0025)
Color Rendering Index (Ra) = 78.8 [ R9 = 0.7 ] R1 = 76.3 R2 = 82.6 R3 = 87.8 R4 = 79.0 R5 = 77.0 R6 = 76.2 R7 = 85.7 R8 = 65.6 R9 = 0.7 R10 = 59.6 R11 = 76.7 R12 = 57.6 R13 = 76.8 R14 = 93.8
In addition, it’s super hard to get a reading because there’s a slight tinge of yellow in the hot spot and I guess my hand is not steady enough to not have “inconsistent reading” like 3/4 of the time.
SKV89
Thanks for the info! With such a high duv, it’s going to look too yellowish eventhough I like 4500K. I wish there was an A or D tint XHP35 HI 80CRI.
Low to High:
Yokiamy
Yokiamy's picture
That would be SWEET !
