Reference for Germany users: Amazon.de
Reference for UK users: Amazon.co.uk
Reference for Canada users: Amazon.ca
Reference for USA users: https://amzn.to/2NGi42P
So here i list their questions and my answers , much appreciated for other useful advice, questions, or answers from TLF or amazon buyers for this item. Thanks very much.
Regarding how to change the mode function or charge current:
1)The moment when you put the battery in the charger bay and you can press the “CURRENT” button to choose. Once the function mode is setting and fixed ( after 8 seconds with no any operation), the “CURRENT” and “MODE” button
will not work, only the “DISPLAY” button can work.
2) If the mode function is fixed. There are three ways that you can change the current:
A. if you want to change function or current one by one— short press the number button ( for example button #1 ) — short press the ” MODE” button to change the function — short press the “CURRENT” to change the current. Then you will finish the current change for channel 1. Other channel are same operation steps.
B. if you want to change function or current for all charge bays — long press the “MODE” button for 3~4 seconds till the LCD content is flashed — short press the ” MODE” button to change the function — press the “CURRENT” to change the current. All channels will be changed at one time.
C. if you want to change the current or function for all charge bays — put all batteries in four bays all — disconnect the power adapter —- re-connect the power adapter—-short press the “CURRENT” button and change the current.
Regarding the suitable charge current for AA and AAA batteries:
- base on battery size— AAA size and AA size :
—We advise to charge the AAA batteries by small charge current— 200mA will be the best, 500mA will be Okay if you want to change it fast. 700mA or 1000mA will be the special chooses when you have no time to wait a long time charge.
— For AA batteries, 500mA is the best, 700mA is Okay for quick charge. 1000mA will be the special chooses when you have no time to wait a long time charge.
2) base on battery capacity—
— if the battery capacity is near or smaller than 500mAh, the best charge current is 200mA
— if the battery capacity is from 1000mAh~1500mAh, the best charge current is 500mA
— if the battery capacity is bigger than the 1500mAh, the best charge current is 500mA, but 700mA also is Okay for a quick charge.
— 1000mA charge current is the emergency choose when you have no time to wait the full charge.
