Lumintop FW1A discussion and review
428 posts / 0 new
JCS
Last seen: 1 day 21 hours ago
Received my light and I’m very disappointed. A light that activates in my pocket is a no go and this light has already done it twice in two days. I’m hoping I can figure out how to modify the tail switch. I’ve never taken a light apart but the modification seems fairly straight forward. Could anyone provide me with a video on how to do it? I can’t seem to find one on YouTube. Also can anyone tell me the o ring size or products they’ve used? Thanks!
DarkOutHere
Last seen: 2 hours 54 min ago
Can anyone comment on the waterproof rating of this light? I definitely want one for EDC/outdoor use but if I’m going to take it backpacking or walking in the rain it needs to be reliable in all weather. I’ve never owned a Lumintop or a forum light so I don’t have a sense of the build quality. Is this a toy with nice design and specs, or a day in, day out, all-weather user?
Lumens is the GHz of flashlights
Candela is the FLOPS
jasontheguitarist
Last seen: 2 hours 44 min ago
The proper solution is to lock the light out. When the light is OFF, tap the button 4 times. The light will flash twice. Once it’s locked it’ll work in low mode only when the switch is held down, but it won’t stay on.
To unlock it tap the button 4 times.
Rayoui
Rayoui's picture
Last seen: 9 hours 17 min ago
I’d say it’s more of a toy than a rugged outdoor light. It does have o-rings and should be ok in the rain or getting splashed, but I certainly wouldn’t submerge it or anything like that. All it takes is one spec of lint on an o-ring and the seal is compromised. It’s very finicky about how the signal tube makes contact with the head and tail so if you might be dropping it or banging it around a lot, I’d probably look elsewhere.
DarkOutHere
Sounds like its not my best choice for a woods/hunting/backpacking light. Anything small and budget that you think is reliable? I’m looking at variants of the Convoy S2+ right now that would fit my needs.
BOO5TED
BOO5TED's picture
Last seen: 21 hours 50 min ago
Disassemble the tail cap, if it has a retaining ring you can remove it with snap ring plyers or the end of a binder clip. I used the binder clip because that’s what I had.
It should look something like this when done.
Remove the little “nub” (as some people call it) from the center of the rubber part of the button and replace it with the o-ring. It should look like this.
Reassemble everything without the “nub”.
I forget what size the o-ring is but I’ve heard the o-ring from inside of the valve caps on your tires works also.
"America has three cities, New York, San Francisco and New Orleans. Everywhere else is Cleveland."- Tennessee Williams
atobe
Last seen: 13 hours 23 min ago
O-ring #008, your local hardware store should have them. 3/16” ID, 5/16” OD, 1/16” Width is the spec.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
