Lumintop FW1A discussion and review
428 posts / 0 new
id30209
id30209's picture
Last seen: 2 hours 36 min ago
I was also thinking about White1^^^
But i’d say option of SMO or OP reflector should available also
WTB Titanium 4sevens 2xAA tube
mattlward
mattlward's picture
Last seen: 5 days 8 hours ago
scosgt wrote:
I have been looking for the thread about different optics for the FW3. I think you can narrow the beam. I agree, for the same approximate output the FW is very very floody and the E01 gives a pretty nice throw, without a real defined hotspot. Does anyone know where I can find the differences in the optics for the FW3?
I don’t pocket carry because my pockets are full with gun, shield case, change, car fob etc. The FW3 in a small case is almost idea for EDC. The E01 does carry slightly bigger, but I find it to be a much better all around light.
I set up one of my FW3A’s this weekend with LH351D 3500k’s and I found the beam to be way to wide. I had a Carlco narrow spot optic sitting in the drawer, that was the key! It is much better, would like it to be a little tighter, but Carclo does not make an ultra-narrow optic.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 13 hours ago
will34 wrote:
I’ve been thinking about the benefits of EDC’ing a single emitter version of the FW3A long before they made a sample, as there wasn’t much of a difference between it and the D4 (performance wise). More throw is always useful for anything further than 10 meters away.
But a reflector version would also remain a shelf queen for the same reason I didn’t ever EDC any of the many S2+, X1R, A6 or similar tube lights I’ve owned or modded, that beam gets boring and unexciting over time no matter the emitter choice. There simply isn’t going to be any magic with a 20mm reflector. The best tube light reflector I’ve ever seen was in a eagletac D3C, it was clean very throwy but even then I still sold it.
Now optics is a whole new unexplored world, after having the FW3A as EDC for a few months, I think the perfect setup would be either a XPL HI V4 or a 1mm2 in a very tight optic, stonewashed titanium body, which paired with the current FW from TK will deliver amazing thermal regulation,
I have recently played with various 20mm 3535 Yajiamei Optics, and various LED’s. SST-20, 219C, XP-L HI, XP-L HD, LH351D. So many different beams from just one optic, and add another 8 different optics on top of that and you’re having a great time. Going out in the field for a night? Easy, just pop in a 10 degree optic. Want a smooth beam at your house? Easy, just pop in a 30 degree beaded optic.
I don’t have a problem with the light being released with a 20mm reflector, because that would give us the option to install 20mm optics.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
thisnameisvalid
thisnameisvalid's picture
Last seen: 1 week 2 days ago
Mine has 5D XP-L HIs with a 10507 and it’s pretty much perfect; it gives it a pretty focused beam (for a multi emitter light). The SST-20 is even more focused with the narrow spot, noticeably so compared to the HIs
jasontheguitarist
Last seen: 6 hours 32 min ago
Before the FW3A thing went live I built an LH351D triple. The other day I swapped that LH351D board into one of my FW3As and I feel the same way. The XPL-HI and SST-20 beam works way better with the 10511 optic. I have the LH351D behind a 10507 in my S2+ triple now and it’s better suited to it. I’ve thought of desoldering all those LH351Ds from that board to use for something else and picking a different LED for the triple.
dmsoule
Last seen: 27 min 36 sec ago
Can’t wait for this one. The FW3A has the best form and UI of any light I’ve used or seen, but you just can’t beat a traditional single emitter with reflector. Even with the narrowest Carclo option, beyond a few meters the result is a big wall of light. That can be nice at times, but I’d gladly sacrifice two-thirds of the lumens for a little more beam distance. Just makes a more useful, all-purpose light, in my opinion.
Tubercle
Last seen: 13 hours 32 min ago
Henk4U2 wrote:
Some people would like to have an ultra flooder like the A6 and some want a much more throwing light. And the last will be a challenge if the dimensions are (already?) fixed to roughly 100mm length.
So I would suggest a TIR optic for the FW1A.
My experience with TIR optics is that the beam is almost always quite good (intensity distribution, tint-shift).
And within the size limits even a thrower would be in reach if we use a clear narrow optic (8 degrees or less).
IMHO a FW1A with a short OP reflector would be nothing more than a crippled version of the FW3A.
Just my 2c.
The D1 variants are w/ reflectors and seem to do very well and people like them. The extra length and mass help w/ heat dissipation.
scosgt
The E01 from FireFlies does not have a reflector and it has a nicely focused beam with a very very nice throw.
justanotherguy
Last seen: 12 min 30 sec ago
subbed
Chinaheart
Chinaheart's picture
Last seen: 3 days 12 hours ago
has any one tried FW3A  XPL HI 3D compare to Nichia 219C 4000K and SST20 4000k.
What is recommended for flood light and EDC
Thank you for the input...
Kulumatic
Last seen: 2 weeks 4 days ago
Very interested in FW1A!
id30209
id30209's picture
Neale said over PM that FW1A should be available in a week!money-mouthmoney-mouth
Edindevon
Last seen: 7 months 4 weeks ago
Pretty excited about this. Any information on emitters or finishes?
id30209
id30209's picture
No clue! I’d be swaping emitters anyway so actually don’t care.
Only if they add 351D then i might leave this FW as is LOL
bmengineer
bmengineer's picture
Last seen: 2 hours 5 min ago
I agree, LH351D or 219C would be best. I expect this will come with an XP-L Hi, but we’ll see soon.
Find all my reviews of flashlights and more gear at www.bmengineer.com
hodor
hodor's picture
Last seen: 1 hour 51 min ago
Holding page is up on Neal’s site!
New web page for FW1A
id30209
id30209's picture
hodor wrote:
"Holding page":https://www.nealsgadgets.com/collections/blf/products/tlf-blf-fw1a-grey-... is up on Neal's site!
Yeap and accessories will be available around September 30. (18350/18500 tube and SS bezel)
MascaratumB
MascaratumB's picture
Last seen: 34 min 15 sec ago
This part of the shorty tubes also applies to the FW3A, right? Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Neal
Neal's picture
Last seen: 1 day 1 hour ago
Thanks
FW1A is available to order
link:FW1A
COUPON CODE: BLFFW3A 20% off
same as the FW3A/FW3T coupon
ActiveAl
ActiveAl's picture
Between the XPL HI 3D @4750k and SST20 4000k LEDs, which would provide the greatest amount of throw? Both of these LEDs, as well as the XPL HI 1A @6500k, will apparently be offered by Neal in the FW3A.
flightless22
flightless22's picture
Last seen: 3 hours 43 min ago
Neal that was fast.
Very nicely and I’m interested but as I understand the head of FW1 and FW3 have interchangeable bodies, correct?
If that’s true, than would it be feasible for you to sell just the head portion separately and perhaps exclude the led and driver if it will cut down the costs?
hodor
hodor's picture
Hi Neal! Any chance it will be available in different colours and finishes (e.g. raw)?
hodor
hodor's picture
id30209 wrote:
SS bezel
Ooooooo
bmengineer
Updating the first post now!
Chinaheart
Thanks Active A1 for the info.
Unheard
Last seen: 1 min 44 sec ago
MtnDon wrote:
I need someone to describe why they prefer a single emitter light over the three.
Tailcap switch makes sense when holding the f/l raised the “tacical way”. I’m doing this to reduce shadows, usually to being able to light up something distant. For floody lights, I don’t want anything else than a sideswitch or magnetic ring, therefore the D4V2 won the race (for me!) If there was a FW1 with maximum throw in this class of lights (no OPR), I’d likely buy it … after extensive beta testing [by its customers, as usual].
vaidd
Last seen: 3 weeks 1 day ago
Looks like the choices are:
Luminus SST-20 4000K
Nichia 219C 4000K
Cree XPL-HI 1A (CW)
Cree XPL-HI 3D (NW)
Cree XPL-HI 7A (WW)
id30209
id30209's picture
I went with XPL 3D. Later easy swap with 351D and when SS bezel show up, the whole section will go to titanium FW3T
cabfrank
Last seen: 5 hours 41 min ago
ActiveAl, according to the specs, the XPL has more lumens and more throw.
id30209
id30209's picture
Tint and CRI is what am after. For throw i'll put White1 in
