Does USB charge flashlight is safe for unprotected battery?
8 posts / 0 new
radiodus
Last seen: 1 week 5 days ago
I have MHVAST TS70 and ACEBEAM EC65, which have USB-C charge (2a) mechanism.
I will order unprotected high current battery(Golisi S43 IMR 26650, Molicel P42A 21700) for those flashlights.
But I can’t trust usb charge flashlight’s mechanism.
Does usb charge flashlight’s mechanism is safe as external charger?
Or should I use external charger when I charge unprotected battery?
Edited by: radiodus on 09/05/2019 - 12:10
Lightbringer
Lightbringer's picture
Last seen: 4 hours 21 min ago
Generally, they all use the same chips to do the charging, whether in a separate external charger or in the light itself. Of course, variances in resistance, etc., will prod one to (over)charge to 4.25V and another to a nicer 4.15V.
Best is to just try it. Charge the cell ‘til it’s topped off (green light or whatever), then immediately pull the cell and measure its voltage with a meter.
Those variances exist in “protected” cells, too, and might not cut off charging ‘til the cell’s horrendously overcharged anyway, so that “protection” doesn’t really buy much. Just keeps the cell from bursting into flames.
BlueSwordM
BlueSwordM's picture
Last seen: 5 hours 44 min ago
@radiodus, these flashlights have been tested to safely charge any lithium-ion cell safely.
SJSHINE
The same way to use a unprotected battery. Usually manufacturers recommend you using protected ones as there is more risks in using unprotected ones.
Some flashlights are even not compatible with unprotected batteries.
BillyBobJoe
Last seen: 3 hours 19 min ago
SJSHINE wrote:
The same way to use a unprotected battery. Usually manufacturers recommend you using protected ones as there is more risks in using unprotected ones. Some flashlights are even not compatible with unprotected batteries.
Really? It seems like I see more lights that are not compatible with protected batteries than the other way around.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 day 5 hours ago
Usually becuase protected are usually a few mm longer than regular 18650…instead of 50mm long they are like 53-54mm long
SKV89
Last seen: 44 min 14 sec ago
Most lights are not compatible for protected and even if you can fit it in, there’s a high likelihood the springs will get pushed in so much that there will be permanent deformation resulting in less pressure against unprotected cells and less output. However, the EC65 is one of those rare lights that are designed for protected cells and Acebeam is a premium brand. I really like how small the EC65 is considering it is made for the super long Acebeam protected 21700 and comes with USB-C charge. Only thing I don’t like is the tint on the Nichias. Too green.
Scallywag
Scallywag's picture
Last seen: 13 hours 9 min ago
WarHawk-AVG wrote:
Usually becuase protected are usually a few mm longer than regular 18650…instead of *65*mm long they are like *67-69*mm long
My corrections in bold. 18 is diameter in millimeters, and 650 is the length, in tenths of a millimeter. The same holds true for cells like a CR2032, it is 20mm in diameter and 3.2mm in “length”
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
