Single LED 21700
29 posts / 0 new
KnHawke
KnHawke's picture
Last seen: 1 day 14 hours ago
Single LED 21700
Hey guys.
Rather new here, came across this forum thanks to Adventure Sport on Youtube and thanks to the rabbit hole that I’m gleefully tumbling down, I’ve gotten an itch to construct my own light(s).
Already have picked up a few Sofirn SP31v2 and C8Fs, the latter I’ve become very unhappy with, likely because of the fat head that it has, but am happy with the body tube size, which lead me to the Convoy S21A Host kit and that can handle 20mm Drivers and MCPCBs no problem…
Which leads me to my predicament: I’d like a single LED which can max out to 1800 to 2000 Lumens and a Driver board that can push it.
Been debating between the Cree XHP35.Hi, the XHP50.2 (3V,6V, and 12V) and the SST40. Cannot seem to decide between them, and like to have a clean white light throughout the powerband.
Also thinking about at one point LED4Power’s LD-4 series drivers, MTNElectronics seems to be out of everything…
If I have to construct and flow my own boards, not a problem, I have access to all the SMT equipment thanks to where I work, even Loneoceans GXP172 Driver doesn’t make me blink but I don’t think that would be advisable for a first build right now…
Before I ramble on any further, asking for some help at this impasse Smile
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 1 hour 38 min ago
I’d worry about beam profile before setting an arbitrary number for how much total ouput you need. Those emitters all have VERY different beams and tints.
LED4Power’s drivers have a very limited range of current, not a variety of low, medium, turbo, etc. modes.
If I were building the light Id use a 4000K LH351D and a FET driver from MTN Electronics like the MTN-20DDm. Still easily past 1000lm, great tint, balanced beam and manageable heat with a driver that has tons of options (with Bistro or guppy3drv for the firmware).
XHP35 are great but both that and drivers for them are expensive and options are limited. Some of the boost drivers available right now have been tested to be kind of lacking lately too.
KnHawke
KnHawke's picture
Yeah. I guess I’m looking for something with a decent mix of throw and flood, since I usually use my lights fairly close and focused, sometimes have to light a good sized area at maybe a dozen or so yards away.
Haven’t really given much thought about optics TBH at this point.
Also yeap, I’m leaning away from boost drivers for the same reasons: lack of testing, availability and sometimes cost.
Lightbringer
Lightbringer's picture
Last seen: 10 hours 50 min ago
That’s one of the innate problems with picking A Light, that it’d likely be a compromise. I don’t believe there’s any such thing as “good balance between flood and throw”, because cranking it up to get good throw in the hotspot will make the foreground right in front of you annoyingly bright and wash out what you’re throwing at. Unless you’ve got a deep reflector like the HS-801, which pushes out the spill way out in front.
Close-in, you will want a flooder, else it’ll be like lighting up things with a laser-pointer. But throw will absolutely suck even at 2k lemons.
Farther-out, you’ll want a throwier light, but then close-in, laser-pointer again.
I have issues choosing between my MH20 and MH20GT for precisely this difference, yet they’re almost identical other than the beam profile.
So, I often carry more’n 1 light, ’20 in my pocket, others in my bag. Right tool for the job…
gchart
gchart's picture
Last seen: 37 min 50 sec ago
Might be worth looking at the JKK21700 (Kaidomain, AliExpress, Banggood, etc) or Astrolux EC01 (Banggood).
Oh, and welcome aboard!
Edit: I read too fast… just noticed that you want to construct your own light. That’s awesome, and kinda invalidates my recommendations. My apologies! Carry on…
e1000
Last seen: 1 hour 26 min ago
heat is always the enemy
texas shooter
Last seen: 8 hours 41 min ago
I went with the XHP50.2 3 volt. At 4.56 amps (12-7138 chips) I get 1790 lumen with no fear of cooking the LED. This driver https://www.aliexpress.com/item/33024201368.html?spm=2114.12010612.81483... was built for the host you picked. At 6 amps probable just over your target brightness at 2300 lumens with a J4 bin. Not exceeding Cree’s current recommended max. which happens to be 6 amps.
KnHawke
KnHawke's picture
Oh yes! That’s why I’m thinking of a 21700 host. Got more meat and surface area to dissipate heat.
Thanks! I looked at that awhile ago, spec wise, almost exactly the same as my Sofirn SP31v2 but with a bigger battery, and a bigger head on it.
Well I’ll be…
I was just eyeballing that exact driver earlier, but for the SST40, not the XHP50.2-3V. There’s an idea.
Hell… I won’t be going turbo often enough to truly worry about it, certainly good for the occasional giggle Wink
KnHawke
KnHawke's picture
Ya make good points there. I’ll be looking more into flooder type reflectors and all that.
Lightbringer
My second pocket-light is a Xeno E03 in WW. A little floodier, but some diffusion film on the front glass would make it a hella nice flooder. How diffusey the film would determine the ultimate beam profile.
Some DFs are plain, and you’d have to open up the light and sandwich it between glass and reflector, while others have adhesive and can be stuck on (and peeled off, even repeatedly), so you can swap different types of DF, or none at all.
e1000
The question will be if you want a specific CCT/CRI.
At 3V, any of the larger die emitters (SST-40, XHP 50.2 3V) are going to have limited CCT options, namely +5000K and poor CRI. The largest selection of emitters and drivers will be a 3V, smaller die (XP size, or 3535), paired with an appropriate driver.
At 6V your options are much better, but you’ll need to find a boost driver. H1-A is a cheap, readily available option, the two drawbacks are limited modes (simple 4-mode) and recently it looks like they’ve downgraded some of the components for it to be less efficient.
12V (XHP-35 HI) is really more of a pain than it’s worth IMO.
Pre-made SST-40 S21-A’s are available at the Convoy store, just plug in a battery and go
Marc E
Last seen: 1 hour 58 min ago
Not in my experience, the drivers can have up to 5 modes + moonlight (with a choice of 3 moonlight levels), max can be switched between constant current and direct drive, max constant current mode is adjustable and the modes will alter as percentage of the max current chosen, and you can choose between 4 drivers which deliver max current between 2-3A, 4-8A, 7-9A and 8-12A.
Sooo, what did you mean by a very limited range of current?
Marc E
In response to your clean, white light requirement, i’ve not seen one in action myself but the Luxeon V is meant to have minimal tint shift across the beam, the XHP50.2 will be a bit multi-coloured as it transitions from hot-spot to spill. The SST-40’s not too bad though.
KnHawke
KnHawke's picture
I guess I should have clarified a little better Smile
Meant from Low Power to Medium to High to Turbo Mode power levels. So long as I get a decent sized, wide hot spot, or none at all if a dedicated flooder, I’ll be happy with it.
My steadfast requirement is that this thing needs to be pocketable without it being overly huge.
Was very tempted with the Convoy SST40 prebuilt light, but the review on it said that it heats up so fast that as soon as ya flip on turbo, it starts stepping down.
So right now, thinking about the LED4Power 6A board with the remote FET and XHP50.2-3V.
Yokiamy
Yokiamy's picture
Last seen: 2 hours 23 min ago
Convoy L21a with XHP35 hi
WTS BLF GT
KnHawke
KnHawke's picture
Coolness Smile The output would put me on the lower end of my target, but this would be more ideal.
But the problem is the driver, aside from the GXB172, what would you suggest for this particular LED?
Yokiamy
Yokiamy's picture
I don’t know what you mean, it’s stock 12V 2,3A which is the sweet spot for XHP35
See TA’s test here
Here’s a link to the light
WTS BLF GT
Lightbringer
Wellp, that’s normally what you get when the light’s small enough to be pocketable. Not much thermal mass to soak up heat before everything else gets hot, few if any cooling fins to help dissipate heat, etc.
KnHawke
KnHawke's picture
Yeeeeeap. Nature of the Beast.
But the SST40 is known to not be the most thermally friendly if memory serves.
Macka17
Last seen: 1 day 9 hours ago
Oh.
And don’t be tooooo disappointed if your first 20 or 30 don’t give you “exactly”,
what you wanting .
There’s LOTSA blokes on here been looking and experimenting for yrs.
And still looking. Chuckle.
Enjoy the life mate. it’s very diverse. and often frustrating.
BurningPlayd0h
XHP 50B 3V is only available in cool white, which is a huge factor in deciding.
The 5000K SST-40 beamshots I have seen look very nice. Throwier to get a bit more range, less tint shift, neutral temp and just a slight loss in output vs XHP 50. Either emitter will get a light HOT at max output and step down quickly anyway.
Not in my experience, the drivers can have up to 5 modes + moonlight (with a choice of 3 moonlight levels), max can be switched between constant current and direct drive, max constant current mode is adjustable and the modes will alter as percentage of the max current chosen, and you can choose between 4 drivers which deliver max current between 2-3A, 4-8A, 7-9A and 8-12A. Sooo, what did you mean by a very limited range of current?
Unless I’m completely misinterpreting what their product page says…
Quote:
0.125Amp steps (3A version) down to 2A
0.250Amp steps (6A and 9A version) down to 4A (6A version)
7A (9A version):0.500Amp steps (12A version) down to 8A
Output current: 2-12 Amperes (3A,6A,9A,12A default options)
that’s only a max range of 4A or less depending on which mode it is set to. So you get moonlight, whatever small amperage range, and optionally a direct-drive mode if you install the external FET. Am I wrong in understanding it that way? That seems far more restrictive vs a PWM’ed FET+7135 driver or similar option with output ranging from moonlight to direct-drive and including everything in between.
e1000
I’ll be honest and say I’ve never actually used the LD-4x, but from the datasheet, how I read it is that’s the setting for MAX amps. The mode mode groups then give you the tiers and are a percentage of that MAX. For example, if you set it to 3A, you can have up to a 5 mode group, and it’ll be a percentage of that 3A.
Alternatively, the datasheet says you can uncap it all and just go direct drive for the uppermost level as well.
That’s how I read it
BurningPlayd0h
I don’t think that’s the case because for each max amperage setting they also list an associated “down to” minimum current. All the reviews I’ve seen of their drivers explain it as working that way as well.
KnHawke
KnHawke's picture
Macka17 wrote:
Oh.
what you wanting .
Ooooh! I know that feeling all to well! Smile
Since this is going to be my first actual build, I know that I will at least learn something from this.
‘Least till I get the itch to do something crazier later, like the GXP172, XHP70.2 in an M3 host or something hehe
g_damian
g_damian's picture
Last seen: 2 hours 33 min ago
Max is maximum regulated current. It can be set to anything between 4-6A (in case of 4-6A driver). Number of modes can be configured, each is the percentage of max current. E.g. one of modes will be 30% of 4A or 30% of 4.5A or whatever configured. Furthermore the highest mode can be direct drive, but each of lower modes is still the percentage of the maximum configured current (i.e. 30% of 4.5A in my example)
BurningPlayd0h
Then what is the “down to” current they list for each amperage setting?
KnHawke
KnHawke's picture
Okay then!
Thanks to all the input, I think I finally nailed down what I’d like for my first build in the Convoy S21 Host:
XHP50.2 6V 6500K
Kaidomain H-1A 6V Boost Driver
Not exactly what I would hope for initially, but this is a start! Ya never know that I could be happy with this Smile
Soon as I get off my ass to go through the BoM of the GB202 and the Switch assembly, I can work with my boss on putting together kits at I hope a reasonable price.
THAT would be my ideal toy to play around with hehe Big Smile
Thanks again guys!
(FYI, I’m a Senior Supervisory Tech at a Prototype SMT Shop with access to all sorts of goodies for low volume production Wink )
e1000
FYI, if you want to spice up the build a little bit, you can try to overclock the H1-A
http://budgetlightforum.com/node/54900
KnHawke
KnHawke's picture
Neat! Something to tinker with later!
Thanks man!
