Alibaba GT-FC40 tested (a 5000K 95CRI 12V domeless XHP70 replacement, supplied by rngwn)
16 posts / 0 new
djozz
djozz's picture
Last seen: 4 hours 50 min ago
BLF member rngwn sent me two of these interesting 7070 leds for testing. He found them on alibaba and asked for a few very high CRI samples. Depending on the performance he will order a batch of these and sell them to BLF members.
I did not get the manufacturer's name, or a datasheet, just the typenr GT-FC40, and that they are 12V, 5000K, and very high CRI.
Appearance
First how does the led look? It is clearly a 16 die led (4 strings parallel of 4 dies in series, I assume), but very tightly packed so it may produce a good beam in smooth optics, just like the XHP35.Here is a picture at 1 mA, to show the emitting area.
Not all dies show the exact same emitting colour. This is not because of the very low current, at 1A the same colour variation can be seen. Also, see the top pictures, there are some specs of dirt in the led, they are not on top but mixed in the phosfor. I hope that production batches do not have that, but at least the performance does not seem to suffer, as seen below. All in all production control seems not perfect.
Tint
I measured the tint of both samples at 1A, straight above the led, and at 60 degrees. Then I placed a small smooth reflector on top of led nr. 2 and measured 3 positions in the beam: middle of the hotspot, the corona, and the spill. Here is the tint data of the hotspot from the smooth reflector:
The beam looks really good by the way. No obvious ugly tint shifts, just a mild peachy corona. Here's the beam of led nr2 at 1A through the smooth reflector, projected on the ceiling, underexposed to show the profile best. That looks very pretty I think!
7 measurements is too many to show all the graphs, so here is a summary of the tint data in table-form.
  CCT CRI R9 duv
led 1 bare, straight above LES 5340 95.5 93.8 -0.0035
led 1 bare, at 60 degrees 5080 94.6 85.2 -0.0007
led 2 bare, straight above LES 5410 95.6 97.8 -0.0049
led 2 bare, at 60 degrees 5150 95.1 90.6 -0.0023
led 2 in smooth reflector, center hotpot 6220 94.9 92.4 -0.0023
led 2 in smooth reflector, corona 4780 95.6 90.6 -0.0018
led 2 in smooth reflector, spill 5248 95.6 93.7 -0.0035
Now that looks like the manufacturer delivered what was asked for, a solid 95 CRI in both leds at various circumstances, and everything close to but below the BBL. No complaining here.
Output performance
This is a 12V led, but the best comparison is with a XHP70, with dome ibtact, it more or less shares the same die-area.
So in the graph I added my only, pretty old, test data of a XHP70 led, a N2 bin led while a modern XHP70.2 led is at bin P2 which is 3 bins more output. Nevertheles it will give an impression where this led fits in. Mind the voltages btw, the tested XHP70 is a 6V led so not 1 to 1 comparable that to the 12V FC40.
It looks like the FC40 leds perform similar to the old XHP70 at  the same current, but at double the voltage, so almost twice the wattage / (a bit more than) half the efficiency. The lower efficiency is normal from a 95 CRI led, but I am pleasantly surprised by the power handling of this led (at 7A it ran at 92W for a few minutes), and the top output of over 4500 lumen (although I would drive this led at maximum 4.5 A / 3500 lumen)
Conclusion
I like this led, it looks good, gives a good beam, has great CRI and has ok efficiency for this great tint..But it is 12V, so not easy to drive. A 4A 12V driver is not common, big and also expensive, so it is a bit exclusive to use this led in a flashlight build. I hope that rngwn manages to have the manufacturer a 6V version built, or even 3V !
Edited by: djozz on 09/07/2019 - 19:08
SKV89
Last seen: 28 min 15 sec ago
The tint seems amazing. I hope the warmer temps will have similar DUV values. Would love to buy several of these on 16-18mm mcpcb to go inside the Thrunite T1 that comes with a very nice 12V driver.
If this can be made in 3V and 6V would make this much more practical. Maybe rngwn can send this test report to the manufacturer.
rngwn
rngwn's picture
Last seen: 5 hours 52 min ago
Thanks djozz for testing these!
Searching for High CRI leds since 2010...
Has finally gotten to the bottom after 10 years of delving deep into that rabbit hole of them high CRI lights...
High CRI, high quality lights doesn't need to be expensive, or is it?
Texas_Ace
Texas_Ace's picture
Last seen: 15 hours 8 min ago
Very interesting LED.
It is interesting that all the tints look good except the hotspot in the reflector being 6200k.
On paper it has a lot of tint shift in a reflector, is it noticeable in real life?
Besides that and the low efficiency it looks really nice.
I agree, a 3V version would be amazing.
finges
Last seen: 3 hours 53 min ago
Thanks for testing, interesting for sure!
Can you desolder one and give us a look at the footprint of the led?
MRsDNF
MRsDNF's picture
Last seen: 55 min 27 sec ago
Thanks to rngwn for supplying djozz with these leds to test and to djozz for doing the testing. I still use your charts djozz for comparing leds. Thumbs Up
djozz
djozz's picture
Thanks all of you for the appreciation! And nice to see you are still around Steve Smile
Tally-ho
Tally-ho's picture
Last seen: 13 min 37 sec ago
Thank you for the tests djozz.
Nice CRI and Duv but they should improve the manufacturing process.
Agro
Agro's picture
Last seen: 3 min 12 sec ago
Thanks djozz, looks like a winner. Smile
This led is made by Getian. I wonder how it throws…it’s probably flip-chip so may be worse than wecould hope for.
Looks like a great use for the loneoceans 100w boost driver. Smile
I also wonder about the performance of lowers CRI variants….
rngwn
rngwn's picture
The 70 CRI 8000-9000k is quoted nominally (at 3A) at 3000-4000lm. That should translate to 3500-4500lm at 5000-6000k CCT.
The one Djozz tested is quoted at 3000-3200lm @3A.
KevinZA1988
KevinZA1988's picture
Last seen: 17 hours 30 min ago
With Simon’s 12V driver it should yield more than 2000 high CRI lumens on turbo. I’d be satisfied with that for now until something better comes along. Thank you for the test, djozz!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
DB Custom
DB Custom's picture
Last seen: 3 weeks 9 hours ago
Good work Jos… Wink
Steve’s waiting around for you to finish the flashlight so he can provide his address… Silly
MRsDNF
MRsDNF's picture
Silly
djozz
djozz's picture
If this led was in 3V I would have many ideas for it and probably the first flashlight already built.
Edit: it is at least not a design problem, looking at how the led is build up for 12V, a 3V version would simply look like this:
djozz
djozz's picture
I unsoldered the led to have a look at the footprint. It looks like it uses a board made for XHP70 in 12V configuration. I checked continuity of the thermal pad and the core and there is, so the board is DTP: the entire thermal pad seems one with the core.
rngwn
rngwn's picture
The footprint looks like its for 12v only. But at least you can swap the MCPCB size.
