Flashlight compatible with Carclo 10622/10623/10624 (24mm)
12 posts / 0 new
1stein
1stein's picture
Last seen: 2 weeks 3 days ago
Your help would help a lot.
I’m searching for lights (hosts/flashlights) compatible with Carclo 1062x optics.
Emisar D4 and Astrolux S4x are well known exaples but my list ended up with these.
Do you know any other currently available?
Related info:
Suitable hosts for 24mm quad optics
Host and optics options for quads
Edited by: 1stein on 09/09/2019 - 04:01
kiriba-ru
kiriba-ru's picture
Last seen: 3 hours 4 min ago
Astrolux S4x use chinese 22mm quad optics and dont fit carclo quad.
1stein
1stein's picture
Thanks, I wasn’t sure since I managed to check only one S4x. Now I know it applies to the whole line. Thanks Kariba.
Anyway, your input will be much appreciated.
If you are aware of any adapted projects – this would help too. I just have an interesting 4xOptisolis 20mm MCPCB and some optics and I want to make good use of it.
kiriba-ru
kiriba-ru's picture
I dont like when optics outer edge is hidden by bezel, so I would check flashlights with 24mm or bigger bezel inner diameter. But light losses (under bezel) are not critical with quad optics, so in most cases you can use any flashlight with glass bigger than 24mm.
Yes I made parts for dozen different quad mods. Cu X5, manker u11, convoy M1/M2/S11, 3 versions VG10, hundreds of P60 shells. Most of this hosts (except first two) are way bigger than S4x. Copper spacer adds near 50gr of weight to the head – many people like extra heat capacitor but sometimes it comes too heavy for edc.
1stein
1stein's picture
This is what I’m doing ATM. it’s rarely listed parameter, so I just hope somebody had already gone this path.
Cereal_killer
Cereal_killer's picture
Last seen: 6 months 1 week ago
Amutorch AX*3* and AT40. I’ve built both as quads. You do need to build a 20mm x 2mm spacer but that’s pretty easy to cut out of Cu sheets and stack them to the necessary thickness.
Buy the reflector version of them so it includes a glass lens (the mule versions come with a plastic lens).
1stein
1stein's picture
Cereal_killer wrote:
Amutorch AX2 and AT40. I’ve built both as quads. You do need to build a 20mm x 2mm spacer but that’s pretty easy to cut out of Cu sheets and stack them to the necessary thickness.
Beer Great candidates. I like amutorch design.
Cereal_killer
Correction, AX3 (AX2 is a single reflector light and probably not 24mmø)
1stein
1stein's picture
I’ve found AX3 on AE, but it has 2 leds… And a side switch. Do you know how many Aps it pulls originally? I’m going to put there 4x Optisolis
Found your review, 6,78A. Awesome.
kiriba-ru
kiriba-ru's picture
1stein wrote:
how many Aps it pulls originally ? I’m going to put there 4x Optisolis
6,78A. Awesome.
FET is not driver. You can not compare currents measured with different setups.
Also, you need to check this: http://budgetlightforum.com/node/61130
In few words, you cant get more than 6amps from 4 leds (even without driver) if you use single cell. And big lumen drop while battery is discharging.
1stein
1stein's picture
I intend to drive 1A each led, so 4A driver would be just perfect. Since I don’t have experience with e-switches I think I have to stick to the original driver. I’d rather it was CC driver, but as said above : don’t want to screw it.
1stein
1stein's picture
The only version of AX3 is the titanium version on Ali. I’m not very fond of titanium flashlight due to poor heat dissipation. And it’s not very cheap, around $40.
Are there any cheaper flashlights compatible with Carclo 10622-10624?
