Test/review of GTF NCR18650B 3400mAh (Green)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 37 min 45 sec ago
DSC_6804
Official specifications:
  • Cell Type: Li-ion
  • Battery type: NCR18650B
  • Capacity: 3100-3400 mAh
  • Voltage: 3.7V
  • Size: Ø18mm x 65 mm
  • Weight: About 48g
GTF%20NCR18650B%203400mAh%20(Green)-info
This 18650 battery uses a type number and wrap color for a Panasonic 18650 3400mAh battery.
DSC_6803
DSC_6805 DSC_6806
DSC_6807
DSC_6808
DSC_6809
GTF%20NCR18650B%203400mAh%20(Green)-Capacity
The two cells do not have the same capacity, it is not that surprising when the specifications says 3100-3400mAh. The can deliver 5 to 7A
GTF%20NCR18650B%203400mAh%20(Green)-Temp-5.0
GTF%20NCR18650B%203400mAh%20(Green)-Temp-7.0
GTF%20NCR18650B%203400mAh%20(Green)-Temp-10.0
GTF%20NCR18650B%203400mAh%20(Green)-CapacityTimeHours
GTF%20NCR18650B%203400mAh%20(Green)-Energy
GTF%20NCR18650B%203400mAh%20(Green)-PowerLoadTime
GTF%20NCR18650B%203400mAh%20(Green)-TripCurrent
GTF%20NCR18650B%203400mAh%20(Green)-Charge
GTF%20NCR18650B%203400mAh%20%28Green%29-Pulse-1A-10-10-2.5V-IR
Conclusion
The cells are not bad cells, but due to the mismatch I will not recommend using them in series.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
toobadorz
toobadorz's picture
Last seen: 2 weeks 2 days ago
Interesting, these are some China cells wrapped with Panasonic-like shrinking skins. They are not really bad, however they are not Panasonic cells either. You can even buy some exactly the same skins and make your own Big Smile
DominikM
Last seen: 7 hours 18 min ago
LitoKala NCR18650B were the same last year. Now they are closer to 3,0Ah Silly
Enlightened member of pl.rec.rowery
Light-Test.info – bike light’s & Headlamps comparison site. – In polish but picture says everything
DavidEF
DavidEF's picture
Last seen: 12 hours 53 min ago
Well, according to the comparator, they seem to outperform Panasonic NCR18650B by a small amount. It’s a shame the tested cells above had a mismatch. Otherwise, they seem to be a decent cell from a manufacturer I hadn’t heard of.
- The YKK Philosophy
Barkuti
Barkuti's picture
Last seen: 8 hours 46 min ago
From the perspective of someone which at times builds some battery pack, seeing so large cell differences sort of gives me the creeps.
The above penta-leg cell top is afaik used by BAK.
I think such large differences among cells are due to rewrapper's bad business practices. They may have cells in stock from different manufacturing batches or even slightly different models. What a bunch of bunglers…
Superstocker
Superstocker's picture
Last seen: 39 min 32 sec ago
Thanks HKJ! Stuff like this is always very helpful to know.
DavidEF
DavidEF's picture
Well, I don't know, because I'm not very well educated about different cells. But take the fact that the cells are mismatched even a little, along with the fact that they used a Panasonic-esque wrapper, and I'm probably never going to buy these cells. I can't trust them a little, so I won't trust them at all. But, as I said above, it's a shame really. They really look like decent cells in the testing. And in the comparator, they actually seem to outperform the Panasonics by a little.
