Convoy S2+ SST20 (biscotti) VS XML2 (7135 X 8 chips)
9 posts / 0 new
korkfoto
Last seen: 11 min 43 sec ago
Both have 7135 × 8 chips.
They have the same price.
I am aware of the advantages of the biscotti driver.
I know that SST20 throws farther.
Which one has:
1. the best thermal management
2. max output (with the same battery)
3. autonomy at max output (with the same battery)?
Thank you!
Yokiamy
Yokiamy's picture
Last seen: 1 hour 49 min ago
1, thermal management, they will both become hot in about the sime time period
2, max output —> SST20
3, autonomy (?) don’t know what you mean, battery life will be about the same since both versions deliver max 2,8 Amps.
  BLF
korkfoto
1. I knew that SST20 geta hot faster.
2.I am asking because I saw ar fasttech that the SST20 variant has 650 lumens max.
3. Set on max mode which one will Haven the longer runtime until it shuts off?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 hours 6 min ago
2 – Yes, SST-20 will get ~700 at max on 2.8A, XM-L2 closer to 900-1000. Very little difference to the eye in reality, except that the SST-20 is much throwier as you already know.
3 – Neither. Both those drivers run at 2.8A max, so the drain over the course of one battery’s charge will be basically the same. The XM-L2 will probably gradually dim sooner due to insufficient cell voltage earlier since it has a higher forward voltage.
ggf31416
Last seen: 2 hours 43 min ago
Only the SST40 version has thermal management. If you plan to run the 2.8A version until it shutdowns it will burn your fingers.
korkfoto
Thank you.
I plan to use the flashlight as a bike light at cool and cold temperatures.
So, the remaining question is: at 2.8A, which one will last longer?
Catnap
Catnap's picture
Last seen: 2 hours 51 min ago
BurningPlayd0h already answered that question, practically the same as both are regulated to 2.8 amps.
I personally prefer the sst-20 version as it throws a lot further.
Scallywag
Scallywag's picture
Last seen: 19 hours 50 min ago
korkfoto wrote:
Thank you.
The SST20 should have lower forward voltage, and therefore will stay in regulation longer… so the runtime at 2.8A will be slightly longer, and the overall runtime will be slightly shorter.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
korkfoto
In conclusion:
SST20 throws farther (not that interested in that aspect), has less lumens than XML2 (700 vs 900-1000), stays a bit longer to max output, but it’s overall runtime is shorter.
I’ll go for the old XML2 (4c variant).
Thank you all!
