E21A Color Test with surprising result
42 posts / 0 new
Joshk
Joshk's picture
Last seen: 1 hour 56 min ago
I bought some E21 quads from Virence in June, and today I got to test them with a spectrometer.
Specifically, they are a star with (4) NVSWE21AT 5000K sm503-D240-M1-R9080 wired for 12v.
And when I asked Clemence what power they could handle on a CPU cooler, he said “For reliable long life 2A is the max. You can temporarily boost it to 2,5A/LED”. So I use 2 amps.
So I measured at a distance of 1 foot with no optics:
—0 Degree—
CCT: 6134K
Duv: -0.0088
Ra (aka CRI): 93.6
X,Y: 0.3210, 0.3144
—45 Degree—
CCT: 5802K
Duv: -0.0070
Ra (aka CRI): 94.7
X,Y: 0.3264, 0.3226
So yea, that surprisingly high CCT explains why I thought things looked odd, but the camera seemed to adjust it out if it was the only lighting source.
Edited by: Joshk on 09/13/2019 - 19:03
Joshk
Joshk's picture
So some DC Fix or a reflector should warm it up, no?
The CCT measurement near 90 deg is 4700K.
DavidEF
DavidEF's picture
Last seen: 5 days 17 hours ago
DC-Fix will blend it into an average CCT. Crown Thumbs Up
- The YKK Philosophy
clemence
clemence's picture
Last seen: 3 hours 45 min ago
Your result is way cooler than Maukka’s test. For bare LED without optic the CCT should be very close 5000-5500K and stays close to the BBL. SKV89 also tested almost all of my E21A and agreed to Maukka’s result (He also use the same Sekonic as yours). Please check your calibration.
Your duv number seems very negative. In real world such number will result in extremely magenta tint (which is not the case)
[Clemence]
iamlucky13
Last seen: 59 min 45 sec ago
Did you have thermal paste between the star and the heat sink? Tint can do funny things when emitters get hot.
clemence
clemence's picture
Joshk
Joshk's picture
I ran a dark calibration just now and re-tested. The results are identical.
For reference, the 5pm sun a few days ago read 4919K and just now (8am) it reads 4670K. And yes, the appearance of the E21s is way WAY cooler than the daylight right now. I don’t doubt the meter.
My profile pic is of the E21s.
Joshk
Joshk's picture
yep, there is thermal paste under there. If you look close it is oozing out of many places in pic#2.
Joshk
Joshk's picture
Also, these screwy looking E21s were one of the main reasons I paid $1700 for a meter. The meter only confirmed what I believed about the E21s.
twisted raven
Last seen: 4 hours 18 min ago
I always thought Maukka’s CCT numbers were a bit low compared to reality. For example his test of the 219B SW45K leds showed them to be around 4200k, but they look more like 4700k.
Ryzbor
Ryzbor's picture
Last seen: 1 hour 42 min ago
Nice package, very efficient and trendy ^^
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K to be modded with FA3 SST20, super rosy 3000K E21A Tiara and super warm 2000K Wizard Pro on it's way
Joshk
Joshk's picture
clemence wrote:
such number will result in extremely magenta tint [Clemence]
Actually, from the diagram negative duv at such a high CCT is more blue that magenta as seen in in the CIE diagram. This perfectly explains the observation I posted here back in July about these E21s making plants look blue, not green at all.
Quote from July:
Joshk wrote:
So I finished this E21 build tonight and took it out back. I was shocked how blue my wife’s cucumber plant was under the E21 5000k light. I dug up a Nichia 219b 4000k tripple and tried that, and voila, it looked like a healthy plant again. I tried to capture two pictures to discuss on BLF, but when I did that the results both looked decent and about the same! The difference in CCT doesn’t account for this in my mind.
Idk. Thoughts?
Suddenly everything is making more sense now that I have the data to back up my observations.
contactcr
Last seen: 1 hour 31 min ago
Your test of what I assume is a bare LED vs his test of integrated light is not comparable. You should throw a XML sized frosted or beaded TIR optic on top and see what you get
Joshk
Joshk's picture
Yea I agree contactcr, that’s why last night I ordered some D-C-Fix to try and mitigate the issue. I don’t have a TIR optic to test with.
contactcr
DC fix wont bring the light from the sides of the LED to the front like a TIR or reflector would though. A reflector with DC fix might be a good test
Joshk
Joshk's picture
Well I can’t have a lens or reflector for normal use, I need a even light on the whole wall.
contactcr
DC fix will probably work well enough for that if you are measuring a few feet away at least
Joshk
Joshk's picture
Yea and if I get the D-C-Fix as close as possible to the emitter I should be capturing that side light, as well as scattering the center light.
contactcr
A solid plan I think, like a photography light
clemence
clemence's picture
This is weird. I’ve tested many E21A (photo comparisons etc…) and have been using them until today, none deviates that much from those in the data sheet. And many people also satisfied with them. To my eyes, 5000K and 5700K are two CCTs most resemble daylight. Only 6500K appears “too blue”. I said this not because I sell these LEDs, but E21A is very popular for reasons.
In my opinion, your profile picture looks way too cool if they’re 5000K E21A. Too warm WB perhaps? You can check my beam and tint shots for comparison.
[Clemence]
Bob_McBob
Last seen: 17 hours 37 min ago
I’ve used probably 7-8 different reels of sw45k and they’ve measured anywhere from 4200K-4700K in a reflector, so I wouldn’t read into that too much. Plus bare LEDs, integrated LEDs, optics, and reflectors will all produce different results.
Joshk
Joshk's picture
I trust what you are saying Clemence. But something is definitely up. Could there have been a mixup with some higher CCT ones in the same drawer when they were built, or just a different bin/batch?
BTW, both my quads perform same.
As for the profile pic, I believe the camera was set to 5000K as it should have been, but I can’t be sure anymore.
Bob_McBob
My sm653 Wizard has a much higher CCT with the bare LEDs measured head on than it does with an optic.
Turbo 2
CCT = 8792K (Duv -0.0082)
Color Rendering Index (Ra) = 93.4 [ R9 = 78.4 ]
Main 3
CCT = 7950K (Duv -0.0031)
Color Rendering Index (Ra) = 95.8 [ R9 = 87.2 ]
With the optic, the hotspot is 7301K and 6819K on the same levels, respectively. Sounds like your LEDs are behaving normally.
clemence
clemence's picture
Forgot Joshk tested the LED at max 2A. That’s beyond the 1400mA limit for E21A. So, that’s normal. Maukka tested the LED according to Nichia’s binning current at 700mA.
[Clemence]
Joshk
Joshk's picture
I got the Fluke out and perfected the Amps at 700 and ran the test again. Then graphed it all together.
—0 Degree 700ma—
CCT: 5949
Duv: -0.0058
—45 Degree 700ma—
CCT: 5390
Duv: -0.0017
Bob_McBob
When you put that in an optic or reflector or integrate the measurement it will probably end up being about 5000K.
Joshk
Joshk's picture
I sure hope so. I’m learning as I go. Thanks to everyone for the help.
To be continued…
staticx57
Last seen: 7 hours 16 min ago
Would like to see the 90 degree measurement. In order to average to 5000k somewhere else in the beam would have to be less than 5000k.
Joshk
Joshk's picture
The CCT measurement near 90 deg is 4700K, but it’s not all that bright out there.
WTF
Last seen: 1 day 9 hours ago
[Clemence]
Does this mean Fet drivers are a bad choice or is 1400ma average current OK?
staticx57
WTF wrote:
[Clemence]
Depends, what cell are you using? Quad E21A behind a 10440 would be fine. Behind a high drain 18650 with springs and all bypassed might not.
