4k Review - Astrolux EC01 3500 Lumens USB C Rechargeable - Best Value 2019
35 posts / 0 new
vietnamreviews
Last seen: 1 day 12 hours ago
English subtitles are updated shortly. Sorry for the inconvenience.
sb56637
sb56637's picture
Last seen: 1 hour 59 min ago
Nice, thanks for the review!
I agree that it’s a huge value for the money, but in my opinion it’s definitely not the most desirable option of 2019 due to its lack of a NW tint option.
vietnamreviews
You are welcome my friend. Me too, i like 4000k or 5000k. Can replace XHP50.2 with SST40 5000k
mortuus
mortuus's picture
Last seen: 12 hours 25 min ago
great review! i look forward getting mine soon.
Overload
Overload's picture
Last seen: 3 days 14 hours ago
The light performs very well, but mine has some bugs:
-In muggle mode: while ramping it sometimes jumps to a very different level
-When leaving muggle mode(6 clicks), main light flashes 4 times quickly.
After that, the light doesn’t respond on any click.Unscrewing tailcap is the only thing left to do
LTC
Last seen: 8 hours 22 min ago
Calibrate the temperature sensor and test again.
LTC
Nice review… Thanks.
At 1:22 min, you mentioned the switch is not so bright. I guess it comes default at low. Can be set to off, high and blinking, same as other Anduril.
Overload
Overload's picture
Thanx a lot mate, that solved both problems Big Smile Thumbs Up
LTC
You are welcome…
vietnamreviews
Thank you my friend. I’ll try it
scosgt
Last seen: 14 hours 42 min ago
How do you set the switch?
Overload
Overload's picture
7 clicks
scosgt
Overload wrote:
7 clicks
Cool
Thank you.
amishbill
amishbill's picture
Last seen: 1 week 6 days ago
I’ve noticed mine jumping a little. Part of it looks like normal stutter as it passes ramping points, but the really odd one is on ramping down. Sometimes it would ramp down a bit then jump right to Low. It only happened sometimes, and I haven’t figured out the pattern yet.
I have no problems coming out of Muggle mode and haven’t had to unscrew the cap to reset it.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
vietnamreviews
Thank you for the prompt. I will try muggle mode, I have never used it
amishbill
amishbill's picture
amishbill wrote:
… but the really odd one is on ramping down. Sometimes it would ramp down a bit then jump right to Low. It only happened sometimes, and I haven’t figured out the pattern yet….
Wait one — Ramp Down is click, click-hold. The shortcut from Off to min ramp is click-hold. Maybe there’s a timing issue where it recognizes the Ramp Down command, but then thinks the continuing click-hold is a request to drop to min?
I wonder if this is a bug in an Astrolux fork of Anduril or a general Anduril weirdness?
@ToyKeeper – were you involved in the EC01 project or any Anduril customization for it? Is my guess anywhere near logical or possible with Anduril?
stroodl
Hello,
I just received my EC01. Looks great and everything but it was supposed to replace my old Nitecore EA41 with XML2U2 and a direct comparison of these two lights disappointed me Sad
The EA41 on high is much brighter and has a better throw than EC01 on turbo. Besides that – the EC01 gets hot after a couple of seconds while the EA41 remains significantly cooler for a whole minute.
I’m using a brand new and fully charged Samsung 40T 21700 cell.
I do not need more light than my EA41 produces but the EC01 cannot even keep up plus it gets hot and ramps down quickly. But, to be honest, I also looked forward how 3500 lumens look next to 1020 lumens.
Is there anything I can check or is it how it is supposed to work?
Thank you,
Ondra
KevinZA1988
KevinZA1988's picture
Last seen: 32 min 4 sec ago
stroodl wrote:
Hello,
Thank you,
Ondra
The EC01 was not designed to be a thrower. It outperforms the EA41 hands down, except for throw. If you want the EC01 to throw farther than the EA41, change the LED to a SST-40 5000K/6500K. On turbo, you will see a definite increase in throw over the EA41, and around 2100 lumens.
There is no way that the EA41 is brighter than the EC01. It sounds to me you are in muggle mode, or your EC01 is faulty. On max ramp the EC01 will be brighter than the EA41, and on turbo it will simply blow it out of the water.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
amishbill
amishbill's picture
KevinZA1988 wrote:
…. It sounds to me you are in muggle mode, or your EC01 is faulty. On max ramp the EC01 will be brighter than the EA41, and on turbo it will simply blow it out of the water.
That is my guess too.
It’s too late to check, but I’m fairly certain both of my EC01 shipped with MuggleMode ON.
mortuus
mortuus's picture
Nitecore EA41 is a 1000 lumen flashlight? lol no wonder it can run longer but its no way near max turbo.. for me i feel its just as bright on turbo as my convoy l6 cool white which does around 3500 lumens or whatever so it shows its really doing that much lumens the ec01… it getting warm is no suprise because the light is insane cute small…
Nitecore EA41 has a bigger reflector but less lumens, the ec01 reflector isnt really bigger then a convoy c8 or smaller? but since the light does 3500+ lumens u get some decent throw consdiering its a OP reflector…
stroodl
Thank you for the hints. I ordered two EC01’s (one of them as a christmas gift for my father) and both perform the same. Muggle mode is off.
I do not have equipment to measure the output but it seems to me that both EA41 and EC01 produce roughly the same “amount” of light (EC on turbo, EA on highest mode) with EC being more floody (which I actually prefer) and EA giving much more throw.
The thing is that EA stays warm to touch for more than a minute while EC is unconfortable to touch after 20 seconds or so.
I will make a video during the weekend to show you.
I will also try to calibrate the temp sensor.
scosgt
If you don’t have one already, get a Fire Flies E01. Great throw, does not get hot fast.
amishbill
amishbill's picture
What you say some some sense. Both lights light up a spot to the same degree, but the EC lights up a wider spot than the EA. The lumens to light up that additional area have to come from somewhere.
stroodl
No no, the spot of EA is much brighter than the one of EC. You can clearly see EA’s brighter spot when pointing at EC’s spot.. if you know what I mean Smile I’m just guessing that the “amount” of light both lights produce is roughly the same (EA’s narrower but brighter spot vs. EC’s wider but less bright spot).
KevinZA1988
It’s just higher candela, not higher lumens. So easy to think it’s brighter if you don’t know the difference. My 800 lumen OSRAM White flat Convoy C8+ throws much farther than my 6000 lumen BLF Q8.
LTC
Very interesting from your 1st post and this. Maybe something is really wrong somewhere. Hope to see your video soon.
Funtastic
Funtastic's picture
Last seen: 16 hours 48 min ago
Have you confirmed the 40T cells are genuine? I highly doubt there’s something wrong when he says that both are the same
The EA has a more focused center hotspot which makes it appear the same brightness.
The EC has a lot more evenly spread flood (surrounding light) which is producing more lumens
You need to understand the difference between lux and lumens when choosing the right flashlight for you.
Lux – the brightest (most intense) part of the beam
Lumens – overall light output
Texas Ace Lumen Tube calibrated with maukka lights
nuemtol
Last seen: 15 min 8 sec ago
Thank you for the video. The specs on this light look so good: price + charging + lumens. It also looks very good on video reviews. I wish Astrolux had better build quality + support.. s43s & EC01 would then seem like good gifts.
Flashaholics , and d_t_a next to MF01 mini. It looks so bright in the grassy field.
So tempting at $25
This is too technical for me, but is there a chance the problems discussed are related to the MF01 Mini problems of incorrect voltage reading, and temperature calibration?
andygold
Last seen: 1 hour 48 min ago
Battery question...
I'm looking for the "best" 21700 battery for the EC01.
I've seen:
Samsung 50E INR  5000mAh 3.7V High-Drain 10A  $9.50
Samsung 40T INR 4000mAh 3.6V  High-Drain 35A  $7.95
Samsung 30T INR 3000mAh 3.7V  High-Drain 35A  $11.00
Xtar Molicel    INR 4200mAh 3.6V  High-Drain 45A   $8.95
Some are rated at 3.6volt, others 3.7volt.  Does this make a difference?  I do realize that they will be charged to roughly 4.2 volts.
Can the EC01 reach it's max performance with the 10Amp 50E, or is 10A not enough?  I ask as it has the highest capacity of the four.
If the 50E is not sufficient, then the Xtar appears to have the best specs of the remaining three.  Would the Xtar be the best choice for brightness and capacity?
Or, would you suggest the Sammy 40T? (or 30T....although the 30T is more expensive than the 40T for some reason)
Lastly, would an IMR battery have any advantages over INR?  I think I Saw a Liitokala IMR that was up around 4000mAh and 40A.
Surefire 8X, Lummi Wee, Lummi Raw, Tank007 E09, On The Road M3, Nitecore Tube, Nitecore TINI, Utorch UT01 (cool and neutral), 9V Cube Light, various 3xAAA COB lights, Eternalight, Astrolux EC01
Swabs
Last seen: 7 hours 21 min ago
Received my EC01 yesterday, and I am disappointed to see the beam is a very warm color. I ordered the cool white 6000-6500K, but clearly got a 5000k model. The product box has a label that states 6000-6500K, and that label was put on rather sloppy, so I am thinking somebody at the factory was in a hurry and put the wrong label on the box, causing the issue.
I sent a message to the seller on Aliexpress, so I am hopping for a resolution within the next day or two.
My Future's So Bright...well, my flashlights are anyways.
vresto
vresto's picture
Last seen: 2 hours 39 min ago
i see pictures,videos…anyway-is it comfortable as an typical edc or is it too big and heavy?looks so nice..
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
