Today I have Jetbeams’ first attempt at a pistol light, the Jet-T2. Thanks to Jetbeam for sending this one to me early to check out. An excuse to go to the range to test a light is always a good one.
!https://i.imgur.com/HOWx32e.jpg !
Full Image Gallery: Jetbeam - Jet T2 Review - Album on Imgur
Join my channels Facebook Page: Liquidretro Gear & Reviews
YouTube Version of this Review:
Packaging
Packaging on this light is a clear hanging retail box with the light prominently displayed in the middle. Some limited information is on the back. Accessories are pretty limited as well, you get the included Jetbeam branded 700mAh USB rechargeable 16340 battery, and a MicroUSB cable to charge the battery directly, and some paperwork such as the manual, warranty card, etc.
Construction
The light is made from anodized aluminum and is generally rectangular in shape but it has been lightened where possible. The sides have a deep milled area in the sides, and the bottom the corners are well rounded. Starting at the head it features a double anti reflective coated lens, with a smooth fairly deep reflector. The head has small scallops for style and grip. The head is removable for battery recharging and replacement. There are springs at each end of the light. Inside there is a dual wall construction so unfortunately a battery larger then a 16340 like an 18350 won’t fit in this light.
On the bottom of the light there is the electronic switched used to lock out the light. It’s large but out of the way and pretty flat. On the back of the light there is a plastic and rubber molded piece that has the switches. It’s almost a different shade of black then the aluminum and not a great match at least on my example. There are switches on either the left or the right side. They only work under the molded rubber bar which took some getting used to and isn’t my favorite design.
The mount features a insert with 4 slots to allow the universal rail section fit your firearm. The key I had no trouble fitting in a Glock rail or standard 1913 rail. For my Glocks (19 being the smallest) it fit best for me in the furthers forward position. This unfortunately isn’t enough travel for my S&W Shield but I didn’t really expect it to fit here either. The screw used to tighten it down on your firearm is silver in color unfortunately, I really wish it was black instead to blend in better. It has a large straight slot to allow you to tighten it down with a coin. I miss the Olight Quick detach system that I have gotten used to on their weapon lights here.
Size/Weight & Competition
Length is about 65 mm, Width is 29mm, Height is 36mm. Weight with battery came in at 92.8g
While similar to the original Olight PL Valkyrie I in layout, I compared the light to the Olight PL Pro because size wise it’s somewhat close. The Jetbeam T2 probably compares best to some of the smaller Streamlight’s like the TLR-7 but I don’t have one here to compare it to. Anyways it’s a medium sized weapon light, larger then the Olight PL-Mini but operates more like a full size light in a medium packaged size.
It fit’s fine on my Glock 19 and 22, but even with the adjustable mount it doesn’t fit on my S&W Shield with the rail attachment.
LED | Beamshots | Runtime
The LED being used here is the Cree XPL-HI in cool white. The reflector is decently deep and smooth so for what it is it has a good amount of throw. It’s rated for 120 meters and I found this to be pretty accurate. Beam profile is a fairly hot center and a good amount of lighter spill, a good profile for a pistol light in my opinion.
Runtimes on this light were a little disappointing, at least for high. In high mode it’s good for 520 lumens, and runtime is about 3-4 minutes before it steps down over the next 7 minutes to about 70% relative output. This decline is slow so you don’t notice the sudden dip. The next 10 minutes is pretty stable. The light then flashes a bit to let you know power is lower, and then steps up a decent amount before running till LVP kicks in on the battery. The battery didn’t want to give me a voltage at the LVP cut off point till I charged it a bit.
Low mode is good for 160 lumens, and runtime is about 105 minutes. This is an odd graph as well, because the light actually increases slightly in output over the first 50 minutes, before stepping back down and then slowly increasing till LVP kicks in. Output till the end gets a bit unstable.
UI
The light has buttons on the left and right, These are button pads that look longer then they really are, you have to get right up under the bar to make them function. A quick press of either button gives you a constant on mode, a longer press give you a momentary mode, Jetbeam calls this tactical mode. To access strobe, double click other buttons.
The light has 2 modes, a high and low, 520 or 120 lumens respectively. To switch between them, just long press both side buttons together and the light will come on and adjust it’s output. This setting is memorized. In my experience I had better luck if I pressed and held one button and then the other quickly vs at the same time. Having the light on makes it easier.
The light also has an on/off switch on the bottom that is it’s lock mechanism. To set the lock, long press on the bottom button, and the light will slow flash 3 times. To unlock long press on the bottom button and the light will slow flash 2 times.
Recharging
Recharging is accomplished on the included Jetbeam 700mAh 16340 battery via the USB port on the side of the battery. This is the same battery we saw on the Jetbeam RRT-01 Review I did earlier in the year (Great light if you have not seen it). It has 2 LED indicators on top, red when charging, green when charged. Charging speed was very conservative at 0.4A meaning charing a low battery to full (4.17V) took 2 hours, 5 minutes.
Conclusion
The Jetbeam T2 is Jetbeams first Pistol light that I can find and it’s pretty good for a first go at it. For me the output should be a bit more smooth and regulated, with more emphasis on the high output without step down. The buttons on the sides should have a larger area to enable them to be used more easily. I don’t find the switch on the bottom that useful for lockout because of the UI that takes too long. I would much rather have a simple mechanical lockout via a ¼ turn of the bezel because it’s simpler and faster.
That said I like the shapes here, and so far this has proven to work pretty well. Even though the mount isn’t a tool less design it works well and should adapt to most full size and sub compact model pistols. The XP-L high is a good emitter choice here and the results are alight that throws pretty well which is important for a pistol light. Overall it’s a good first design with room for improvement in the future.
