lumintop SD Mini - fully charged 18650 battery drains within 24 hrs
7 posts / 0 new
KKG
Hi fellas
Am new here, got a Lumintop SD mini in July last year and it worked fine until last week. Once I charged it to full capacity, it’s power drains off in 24 hours time. Tried it again yesterday and the same happened.
Any ideas? Remedy?
Thank you.
Cheers
Kumar
Edited by: KKG on 09/21/2019 - 05:14
Cereal_killer
Cereal_killer's picture
Last seen: 4 hours 13 min ago
What battery and charger? Did you confirm it was actually charged with a DMM?
Not saying it’s not possible but I’d suspect the battery / charger before the Olight.
KKG
Hello, battery is a local OEM, the Lumintop SD mini has a USB charging port.
It just occurred to me that I should also mention that in the said period, I only charged the battery 3 times.
djozz
djozz's picture
Last seen: 1 hour 35 min ago
There was a SD mini that I gave to a friend, worked fine for months and then came back with a completely dead battery, 0 V (an LG). I gave him a new battery with the advise to lockout the light after use by twisting the tail off a bit. I never investigated what precisely happened but it could be the same thing.
Terry Oregon
Terry Oregon's picture
Last seen: 5 hours 49 min ago
Do you, or someone you know, have a DMM that can measure down to micro amps? Off current (parasitic drain) is pretty easy to measure if you have a meter and know how to use it. I suspect the results would be enlightening.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK.
KKG
Terry Oregon wrote:
Do you, or someone you know, have a DMM that can measure down to micro amps? Off current (parasitic drain) is pretty easy to measure if you have a meter a anyone who hasnd know how to use it. I suspect the results would be enlightening.
Hello
I don’t have a DMM nor do I know anyone who may have one.
Currently I am using the lockout method and making do.
Thanks one & all.
Old Mate
Last seen: 3 days 21 hours ago
Grab a couple of cr123a cells and try. If they go flat at least you know its not your battery and you indeed have a parasitic drain problem.
Old Mate
