[Yuji's warm white 5mm substitute!] WTS: 3400k 5mm LED 95+ CRI
171 posts / 0 new
Unheard
Last seen: 2 min 11 sec ago
iamlucky13 wrote:
The 45 lumen stock rating strikes me as extremely unlikely.
Hey, thanks. Yes, that’s what I was thinking, but you never know.
DavidEF
DavidEF's picture
Last seen: 2 min 22 sec ago
Even the “half watt” LEDs can’t reach 45 lumen output. They are generally only rated up to 100mA @ 3.4V, which would translate to 0.34W of power. To get 45lm out of that, you would have to be getting over 130 lm/w efficiency, which none of these LEDs have. The cheap LEDs in this format are only good for 20mA current. Perhaps they meant 4.5 lumens? That would actually be the likely output of standard LEDs in this format.
- The YKK Philosophy
Barkuti
Barkuti's picture
Last seen: 3 hours 38 min ago
DavidEF wrote:
… The cheap LEDs in this format are only good for 20mA current. …
Well, that usually is their rating. Months ago I did some testing on a bunch of 5mm and 10mm leds I had lying around, bought in 2006 or so. The 5mm ones would start dieing at 140+mA, and the 10mm ones slightly higher at 180+mA if I recall right.
So, they could be hard driven to some extent (100+mA pulse driven successfully).
djozz
djozz's picture
Last seen: 18 min 7 sec ago
It is the same keychain light as the Astrolux TB01, that had a bit different type of 5mm led than usual, with extra thick leads. I never measured the output before modding it but it could have been 45 lumen (so maybe 120mA).
Pwsmith
Last seen: 1 day 17 hours ago
I would like to get some of these LEDs when you get them restocked. Thanks.
DavidEF
DavidEF's picture
So, Barkuti and djozz, are you guys implying that the light in question is actually using a “half watt” LED and overdriving it, in order to get 45 lumens out of it? That would be a strange thing to see. Can somebody test one to find out what the output really is? I’m really curious now.
Barkuti
Barkuti's picture
45 lumens from a 5mm led when driven by 3x LR41 cells? LR41 alkaline cells have very high internal resistance. An alkaline AAA with close to 1000mAh features ≈0.22Ω of IR with little use (Duracell Plus Power AAA at the ≈150mA x-axis point, 0.5 - 1A discharge curves). A cell with less than 1/30th of such capacity would have 7+Ω of internal resistance in the same conditions, which at 100mA of drain/driving current is a drop of 0.7+V for a single cell and 2.1+V for 3 cells in series, this means no chance of hard driving the emitter even with fairly new cells. According to these figures, those 45 lumens are a blatant exaggeration or typical false advertising.
Thu, 09/19/2019 - 23:42; Fri, 09/20/2019 - 15:30; edited for clarifications.
Unheard
Barkuti wrote:
If you need ‘em cheap, check this ad for example: https://www.ebay.com/itm/10PCS-1-5V-AG3-LR41-392-SR41-192-Alkaline-Button-Coin-Cells-Watch-Battery-Sturdy/382209158751 Smile
Won’t ship to Germany but thank you :-).
Barkuti
Barkuti's picture
Unheard
rngwn
rngwn's picture
Last seen: 20 min 42 sec ago
Update: The next shipment is said “out of delivery”, but this is very late in the day where I live and the courier has not arrived.
I will put the worst-case scenario that the next shipment will arrive on Monday.
Check out my inventory
[WTS] 95 CRI COBs
Phosphor22
Last seen: 2 hours 38 min ago
i would be interested in a pack of these LED’s when you restock them — thank you.
iamlucky13
Last seen: 9 hours 59 min ago
Some additional potential host options.
The Red Cross Blackout Buddy emergency light (link to confirmation of modification), so you can have a warm white auto-on power outage light. Takes 3 emitters, I think.
The Red Cross Clipray is similar, but instead of a power outage light, it is a handcrank one that can run either lights, or supposedly charge USB devices (slowly).
The Coghlans dynamo flashlight is a very small crank light with 2 emitters. It seems like a good kids flashlight if it can hold up.
SKV89
Last seen: 6 hours 35 min ago
I would love to participate but don’t know how to use these emitters. Do they require soldering? Also which flashlight host can these go into?
rngwn
rngwn's picture
^soldering is required. You will find LED similar to these on keychain lights, or some other flashlights discussed earlier in this thread.
There is also an interest list by Djozz for C01 host, but I’m not sure if its ever going to happen.
[WTS] 95 CRI COBs
Barkuti
Barkuti's picture
SKV89 wrote:
… these emitters. Do they require soldering? Also which flashlight host can these go into?
Which not?
There have been some mentions here:
rngwn
rngwn's picture
Round 2 shipped:
[WTS] 95 CRI COBs
shirnask
shirnask's picture
Last seen: 3 hours 36 min ago
Thumbs Up
Slayer1
Slayer1's picture
Last seen: 10 hours 40 min ago
Thumbs Up Beer
rngwn
rngwn's picture
I have got a phone call from the shipping comany about the import charges and that the shipment will arrive soon.
I can wrap up to about 10 packs today. Book & Pay before 21:00hrs 22:00hrs GMT+7 for the 3rd round.
[WTS] 95 CRI COBs
rngwn
rngwn's picture
Reinforcement Lot no. 2 has arrived!
[WTS] 95 CRI COBs
rngwn
rngwn's picture
Round 3: Shipped
Chatika vas Paus – RR146459745TH
[WTS] 95 CRI COBs
rngwn
rngwn's picture
I pulled 3 random LEDs from the 2nd batch for spot-check.
Here’s the light (appearance) test on 5500k WB and 2800k WB
https://imgur.com/a/5P4iLzH
[WTS] 95 CRI COBs
rngwn
rngwn's picture
Tracking numbers update:
Phosphor22 – LX054010845TH
e1000 – LX054010831TH
Kame Sennin – RR146459793TH
[WTS] 95 CRI COBs
djozz
djozz's picture
Received the package of 100.
There will not be a proper review until next tuesday (I will have enough forum chat time but there will be no hands-on cave time possible).
Quick first impression of one random led from the package:
*plenty bright
*very pleasant tint to look at
*very smooth broad beam (60 degrees from specs seem correct)
*edge of the beam a bit warmer than the rest (found it not disturbing)
*at ~20mA, middle of hotspot: 3325K, duv -0.0039, CRI=97.4, R9=88.
Summary so far: great led Thumbs Up
SKV89
Wow! Sofirn should get some of these.
Barkuti
Barkuti's picture
Many will be waiting for the review djozz. Thanks.
Any 7x emitter honeycomb arrangement host or flashlight out there for these? Hexagonal/honeycomb is the most dense arrangement, I wonder why it doesn't seems to be widely used.
rngwn
rngwn's picture
How about this as a host? It’s 0.5w though, so I don’t know if my LEDs would survive that.
https://www.aliexpress.com/item/32833777655.html?spm=2114.12010612.81483...
[WTS] 95 CRI COBs
1stein
1stein's picture
Last seen: 36 min 54 sec ago
Received! Many thanks.
DavidEF
DavidEF's picture
*plenty bright
GREAT! Crown Thumbs Up
I’m really looking forward to seeing the results of your testing. Big Smile
