The Flashlight for the Ultimate Flashaholic
Woot One Day Sale has this light on Sale "Today Only"
MII Flashcam Tactical Flashlight
with Built-in Video Recorder & Night Vision
$99 + $5.00 shipping
Warranty: 90 Day Northcrest Security Technologies
Condition: New
Features:
  • World’s first tactical flashlight featuring a video camera system and night vision technology with audio recording all-in-one convenient unit
  • Boasts an 85,000 Candlepower LED flashlight with approximately 3.5 hours of continuous operation
  • Manual brightness control, water resistance, and shock resistant design, this flashlight will get the job done
  • Powerful, 880 nanometer infrared illumination for complete covert viewing
  • Record up to 60 minutes of crystal clear covert night vision surveillance (video and audio)
  • Water resistant aircraft aluminum body
  • Capture the events happening in its view with a Hi-resolution Sony Color Video Camera System
  • 1.5” TFT-LCD color monitor helps you keep track of what is being recorded, and makes playback easy
  • 1 Gigabyte RAM stores 60 minutes of high quality video means you have sufficient capacity to record
  • Included Nickel Metal Hydride 12-Volt, 2.4 amp hour rechargeable battery pack will recharge up to 1,000 times. Also runs on 4 "D" size batteries (Not Included)
  • When returned to the charger, the MII is ready to download its video and audio memory. The convenient “Download” button is located on the MII Charger/Data Docking Station
Additional Photos:
Specifications:
Normal Illumination: Three 5 Watt, Hi-Flux LEDs
75 Lumens (cool white light) 85,000 Total Maximum Candlepower
Brightness Control Button
LED Lamp Life (white): Unbreakable LEDs provide more than 100,000 Hours of Trouble Free Life
Infrared Illumination: 880 Nanometer, Covert Infrared Illumination (Non-visible to the Human Eye)
Camera Specifications: Image Sensor: 1/3" CMOS - Color/Black and White Camera
Minimum Illumination: 0.008 Lux
Sync System: Internal/External
Resolution: 480 TV Lines Day and Night (hi-res 640x480 - low-res 320x240) Snapshots - 3 Megapixel
Number of Pixels: 768(H) x 494(V)
Lens: 5.0mm
Structural Design: Aircraft Aluminum 6061 T-6
Anti-corrosion interior and exterior
Polycarbonate lens
Waterproof and Shockproof
Color: Black Matte (Non-glare)
Battery: Nickel Metal Hydride 12-Volt, 2.4 amp hour
Rechargeable up to 1,000 times
Battery Run Time: 4.5 Hours Flashlight Only
3.5 Hours (Camera and Flashlight)
Charger: 12-Volt Vehicle Charger
110 Volt AC Charger
Docking Station
Power Supply: 12V
Dimensions: 17" Long
Weight: 2.2 lbs
In the box:
  • Northcrest Security Technologies MII Flashcam
  • Nickel Metal Hydride 12-Volt Rechargeable Battery
  • Docking Station
  • USB Cable
  • AV Cable
  • AC Adapter
  • DC Vehicle Adapter
  • Storage Case
  • Software CD
  • Quick Start Guide
  • User Manual
Thats a really interesting "flash"light"...thing
it used to be really expensive (I mean $1000+ after googling)
That is pretty cool. I wonder if you could mod it and put some XR-E's in it, or better?
Too bad the flashlight portion is so anemic. I mean, how can three 5-Watt LEDS only crank out 75 lumens?!? Sounds like 5 milliWatt LEDS more likely.
One could easily run 3 neutral-white or warm-white XP-Es instead. Running each one at even 500 mA would put out 75 lumens each, with very little heat dissipation required.
It looks like 3 XR-Es in there already.....
That looks like a really nice light actually...
The night vision function really caught my eye.....
Got a bridge I'll sell ya...
If I had a c-note burning a hole in my pocket I might hit the buy button, just for the novelty.
probably under driven because heat would destroy video components.
the only use I can think of (for myself) would be to add to a gun, but it wouldn't be bright enough, and I doubt the cam would withstand recoil beyond rimfires.
fail
epicFoy
