Luminus SST-70, a sample tested
50 posts / 0 new
djozz
djozz's picture
Last seen: 4 hours 26 min ago
Thanks to Jacky from LuckySun who got his hands on some samples, and to TheOnlyDocc who negotiated to get one sent to me for testing, I received one Of the new SST-70 leds from Luminus. There is no datasheet yet as far as I know as the SST-70 is at this moment not even listed on the Luminus website yet (it does show up in their design files though).
It is a XM-size (5050) 6V/12V quad die led and is thus a direct replacement for the Cree XHP50. The die size however is smaller, even closer to the XHP35 than the XHP50. Let's see how good it is.
First some comparison pictures, left with Nichia 144A, XHP50.2 and XM-L2, right with XHP50.2 and (a warm) XHP35 hd (the version with a dome):
Beam and tint
I placed two reflectors on top of the led running at 1A and looked at the beam on the ceiling two meters away (the distance is not ideal but it gives a good idea). Left with S2+ reflector (small OP), right with an X6 reflector (bit throwier smooth). In both reflectors the SST-70 produces a fine beam, no donut holes, no Cree rainbow. The photo's are underexposed to show the hotspot well.
 The CCT of my sample is around 6000K (depending on how it is measured, I can not measure integrated tint like maukka can, the hotspot from a reflector is 5900K), and CRI is 67.
Performance
The output test was done like most of my emitter tests over the last years. I described it in detail in my XP-L test (found via my sigline), with the minor difference, that should not matter significantly for the results, that I used my Integrating sphere no. II instead of no. I.
In summary: 1) just one led of each type was tested, reflowed on a DTPcopper board  2) I used my large version II integrating sphere with high quality luxmeter, 3) the output numbers and voltages were measured with the led close to ‘steady state’ for each current, so warmed up and settled (I take a minute before each current increase), you should be able to get these numbers in a well heatsinked flashlight. Mind that these are output numbers of the bare led; in a flashlight there will be losses from light obstructions, lens and optic, 4) output is in ‘djozz-lumen’ defined as 1/550 of the output of my Sunwayman D40A on high setting, which I hope is close to the real lumen (recent comparisons show that it is actually between 7 and 11% high), but at least is consistent over all my previous emitter tests done in integrating spheres, so all my output data over the past years can be directly compared.
I added old data of a Cree XHP50.2 in the graph for comparison. Mind that in the meantime better output bins than J4 are available, KD sells K2 bins of the XHP50.2 atm.
What can be seen?
*this SST-70 led performs similar to a tested J4 bin of the XHP50.2 although at higher currents the output levels out sooner.
*but with its die surface area of (estimated from the pics) only 55%-60% of a XHP50.2, the throw will be significantly better. The throw will not match a XHP35 hi (the domeless led), but my guess is that it is not really far off, and with 80% more output. If one manages to dedome the SST-70 succesfully, the XHP35 will be beaten in throw, and with 50% more output (this is all my guesstimation).
*I stopped the test at 10A where the output was already dropping, to save the led. A few days later I did a quick voltage/output check and the led did not perform less than at the time of the test.
*my performance hotspot for this led would be 6A/4000 lumen.
Conclusion:
Looks like a great led, time will tell if it will deliver what this test promises.
And please Luminus bring us the 3V version!
Edited by: djozz on 09/24/2019 - 06:24
SKV89
Last seen: 5 hours 35 min ago
Man I get some excited every time I see these emitter test post from you or Maukka! This looks promising. Hopefully it performs better than the XHP50.2.
Agro
Agro's picture
Last seen: 3 min 10 sec ago
Great! A serious competition to S2WP? Please Luminus bring us higher CRI version. Smile
djozz
djozz's picture
I would not mind testing a S2WP, do you have a link where I can buy them?
id30209
id30209's picture
Last seen: 44 min 32 sec ago
Wow! Yeah, hi cri is my dream. 3V in a bit warmer colorwould be also nice
WTB Titanium 4sevens Quarks & Jetbeam TCR1
M4D M4X
M4D M4X's picture
Last seen: 38 min 41 sec ago
thanks for the test!
subscribed
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
Th558
Th558's picture
Last seen: 7 hours 23 min ago
Would love to see this in an EC01. Domeless would be even better. Now hurry up Luminus and make a 3V version.
Th558
Th558's picture
Ask Neal from Nealsgadgets. He could probably get you one.
pearlriver
pearlriver's picture
Last seen: 21 hours 21 min ago
good led
Agro
Agro's picture
Djozz, any chance to get raw data behind the chart?
maukka
maukka's picture
Last seen: 19 hours 54 min ago
Thanks, that beam looks really nice! How was the tint (duv) on yours? I take it that you’re not going to sacrifice that in a dedoming experiment? Smile
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 27 min ago
Thanks for the testing djozz.
I wonder how it dedomes also but its always a risk.
Barkuti
Barkuti's picture
Last seen: 4 hours 29 min ago
pearlriver wrote:
good led
Looks like a huge quad reflector. Would you mind sharing some build tidbits?
Thanks.
The Light Innocent I am
Lexel
Lexel's picture
Last seen: 21 hours 55 min ago
Barkuti wrote:
pearlriver wrote:
good led
Thanks.
Looks like TN40S or Jetbeam T6
pearlriver
Lexel wrote:
Barkuti wrote:
pearlriver wrote:
good led
Thanks.
Another leaked photo from haikelite.
Barkuti
Barkuti's picture
maukka wrote:
… I take it that you're not going to sacrifice that in a dedoming experiment? Smile
With a feeler gauge set plus dremel type multitool with dedicated locator accessory, dedoming can be made easy (check this).
Of course, it is first required to know how low can you go. Wink
Barkuti
Barkuti's picture
pearlriver, it would be nice if you could edit your previous posts' images (#9#15) and set their relative width to 100% max. Attach a {width:100%} string between the first exclamation mark and the image url:
!https://ftp.bmp.ovh/imgs/2019/09/ca970f7aab5a093e.jpg! becomes
!{width:100%}https://ftp.bmp.ovh/imgs/2019/09/ca970f7aab5a093e.jpg!
!https://ftp.bmp.ovh/imgs/2019/09/093563c9e9fca947.jpg! turns into
!{width:100%}https://ftp.bmp.ovh/imgs/2019/09/093563c9e9fca947.jpg!
djozz
djozz's picture
I never was very good in dedoming a SST-40 so the chances would not be good, and I would not have a suitable host for the dedomed SST-70 anyway (you want 6V 6A and a big smooth reflector for a proper dedomed SST-70 build).
The tint is plain cool white, seems no different than the cool white SST-40 tint, but if you measure it, it is quite a bit above the BBL. Here’s the center of the hotspot from a S2+ reflector, with the led at 1A (CRI=67.3,R9=-40)
djozz
djozz's picture
Sure. The numbers are convenient to have but also they suggest an accuracy that is not there. That is why I usually just post charts, it removes the false preciseness from the numbers.
maukka
maukka's picture
Yeah, looks very similar. On such high color temps I don’t find some green so objectionable, even though +0.006 is quite a lot. As is, I probably wouldn’t find any practical uses for the emitter though.
Barkuti
Barkuti's picture
Dedoming it would likely fix the high Duv, doesn't it?
Agro
Agro's picture
Thanks djozz. Smile
Seeing the numbers I’m not sure it will outthrow XHP35 HI E2. I’m seeing 160 djozz-cd/mm² with 20% dedoming losses while XHP35 got 172 koef3-cd/mm².
Now…koef3 got better cooling and your lm are known to be a little high (though his might be as well).
So…seems like the same ballpark to me when it comes to throw.
Efficiency is within error margin as well (comparing at the same luminosity).
So…it’s much like a bigger XHP35 with dome and CRI70-only.
GXB172 would be great for it. It’s sad how this driver is still not easily available.
Barkuti
Barkuti's picture
Thanks to the existence of “XHP70 drivers” it is possible to get some stock drivers configured for up to 4.8 - 5A driving current in ∅22mm size. User Windforce did some testing over a Manta Ray XHP70 driver bought from AliExpress, see Testing boost drivers' thread.
Of course Wink I found rock-bottom price seller for the Manta Ray XHP50/XHP70 drivers:
  1. ∅22mm “XHP50” max 3A 5-mode unit.
  2. ∅22mm “XHP70” max 4.8A 6-mode unit.
Drivers look the  same, only different firmware I'd say.
djozz
djozz's picture
Agro wrote:
Thanks djozz. Smile
My guess was based on very rough eye-balling, so I’m sure your calculations tell the better story Smile
KevinZA1988
KevinZA1988's picture
I’m in progress of building a Manta Ray C8.2 2S with LD-B4HV driver and XHP50.2. I would love to try this LED out for increased throw….
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
djozz
djozz's picture
KD says in stock for a 7500K emitter, $6.80 sounds pretty ok.
link
KevinZA1988
djozz wrote:
KD says in stock for a 7500K emitter, $6.80 sounds pretty ok. link
It’s a pity it’s 7500K. I’ll probably buy one and test it anyway…
BlueSwordM
BlueSwordM's picture
Last seen: 5 hours 27 min ago
Uh 7500k…
It’s really easy to see that the SST-70 is a very new LED, meaning to achieve high brightness bins, you need a high CCT to achieve them.
id30209
id30209's picture
No go for me with that color Sad
DavidEF
DavidEF's picture
Last seen: 6 hours 16 min ago
djozz thanks for the testing. Since the die is closer in size to XHP-35, it would be nice to see testing at 12V, with a chart comparing XHP-50.2 also at 12V, and XHP-35, which is only available in 12V. That way, we could see where the SST-70 really falls between those two regarding output, voltage, and current. Is there any chance of that happening? Innocent
- The YKK Philosophy
djozz
djozz's picture
No Innocent
I do not have enough energy/time/dedication etc. to do all that. Even if I would promise it I will probably keep doing fun stuff first and this will end up nowhere (I have broken a few promises in the past, could not get myself doing it).
We need a HKJ of led testing for that, who is never tired of doing vast amounts of tests. Me I just pick out a promising led every now and then.
