Looking for headlamp. Regulated, moddable, inexpensive
Your help would be greatly appreciated. Need to find a good home FOR my LH351D 3500K.
I’m searching for appropriate candidate, but it turns out to be not that obvious.
Boxes to be ticked:
-regulated current
-easy moddable
-up to $40
-currently available
–800+ lumens
–3535 LED size or round 16mm mcpcb
If you come up with anything… I’m all ears.
Skilhunt H03 , Nitecore HC30, Wowtac A2.
Thanks.
H03 is very well known to me, but this will be my last choice.
HC30 is too expensive, Wowtac is advertised only 550lm
Wowtac a2s or Sofirn sp40
Sofirn SP40 has no constant current. Performance drops as the voltage in cell drops.
Did not know that, thanks.
This wowtac A2s caught my eye. Does anybody know if it’s constant current? The graph in the review is not available for me.
Jaxman E1
Right, I was considering this one. But Jaxman claims it has no temperature sensor. So either it does something I don’t know to regulate the current, or high mode is time driven. Still holding until this is revealed.
H03 /HC30 are cheapest(25-30$/33-35$)headlamp with buck drivers. If you want more cheap you can buy headlamp without stabilization( sofirn, conwoy…) and change driver to linear one.
HC30 has 5050 led and (how can it be?) no low voltage protection?
I still searching for headlamp too and same as you want. High cri headlamp. Hopefully you will suceeded.
Kaidomain KdlitkerHL-10
Wowtec A2s is not regulated either.
Is the Skilhunt H03 the only option? Please… prove me wrong.
For buck driver lvp is not required.
Noctigon Xp16 for example is suitable for Hc30 after 5 min work.
H03 is most mod friendly host with good enough stock driver.
Build quality is much higher than new 20-25$ l-shaped flashlights. And last but not least H03 is lightweight it is important for headlamp.
How about the Acebeam H40 It’s small (14500) so it can’t sustain the turbo output for longer than a minute, but it seems to tick your other boxes.
About the Jaxman, if you’re willing to use it as headlamp, please note what is written in the AGAIN part :
Yeah, quite funny. Forbidden to use as headlamp?
Thanks, this is tempting, but I would stay with stock high CRI sst-20. Anyway it’s a great headlight, I know.
You can find it for 8$ or so
Thanks, will consider although already ordered H03F. Unfortunately both are 5050 footprint.
