Solarforce L2i: Drop in for using 3x AAA
7 posts / 0 new
KDLST
Last seen: 5 years 2 weeks ago
Hi fellow babies,
Ok so i once bought a l2i and modded it to 18650 compatible by changing the switch.
By doing this however the battery carrier for 3x AAA doesn't fit anymore.
That's why i was thinking of buying another one for use with 3AAA, that way i'll have 2 carriers.
What do you guys think about it? Is it even worth running a led light on 3AAA's or should i just leave it as it is.. And invest in something else
IfI sould do it then what seems like a favourable drop in to you guys?
Xpg, mce, xml, ...
Thanks a bunch
Edited by: KDLST on 01/09/2012 - 17:44
Haggai
Last seen: 6 days 19 hours ago
I use L2i 3xAAA with MF XM-L 3-mode and I really enjoy it.
Run time is shorter compared to 18650 and current draw is lower, but for my purposes it's fine, and I don't have to worry about heat (although at 2A the 3xAAA draw the flashlight heats up pretty well, with 3.2A the 18650 draws it would be too much). I need it for only a few minutes every day, so I have to charge it once a week.
And the L2i host is so cheap compared to what it gives you that I think getting another one is in place.
jacktheclipper
jacktheclipper's picture
Last seen: 1 hour 59 min ago
Zhanglu wrote:
I used 220 lumens ZOOMABLE ZOOM 5W CREE Q5 LED bike light FLASHLIGHT 3x AAA S22,  I really enjoy it.
S22 has three modes, high>Mid>Strobe, you could select any lumens between 1 to 220 lumens. It is powered by 3x AAA batteries, and waterproof design to use freely in a rainy day
I could swear I just got a whiff of paisley ...
08CivicSi
Last seen: 3 hours 27 min ago
I have 2 L2i's and use 3xAAA in both.  In one i have this drop in, which is a Solarforce 3 mode .8V-4.2V xp-g r5 and it works great, i usually keep 3 eneloops in it.
The other L2i has this drop in, which is a 1 mode 3V-18V xp-g r5.
both are very bright and i love being able to use AAA instead of 18650 in an emergency situation where i might not have access to 18650's
old4570
Last seen: 1 month 6 days ago
Yeah , mod the carrier !
 File down the back end till it fits in the tailcap , its not a big job and it only needs to sit in enough to contact the tail spring ...
http://budgetlightforum.com/node/1922
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
KDLST
Hm it's no really working for me. It still won't fir and if i force it in the plastic housing of my batteries get scraped off!
old4570
The other option is to stretch the spring carefully ... [ very carefully = in the tailcap ]
If your scrapping the batteries , your going too deep ...
