Convoy L6 question
10 posts / 0 new
QMT93
Last seen: 3 weeks 16 hours ago
Convoy L6 question
Hi,
As I understand, there are currently two versions of the Convoy L6: the XHP70 (3800 lumens max)+ OP (orange peel reflector), and the XHP70.2 (4300 lumens max) + SMO (smooth reflector)
Correct me if I’m wring, OP produces a nicer beam, while SMO allows some throw with a hot spot, spill, and likely a donut hole artifact.
My questions are:
1) Is it beneficial to bump the lumens to 4300? As far as I know, it requires 4 times the lumens for us to see twice the brightness. Are we wasting energy producing heat in this case?
2) Is it possible, and beneficial, to replace the OP in the XHP70 with an SMO? On the other hand, is it possible, and beneficial, to replace the SMO on the XHP70.2 with an OP?
If this has been covered, please direct me to where I should read.
Hope to hear from you soon.
BlueSwordM
BlueSwordM's picture
Last seen: 8 hours 43 min ago
1) No, you’re not wasting energy. The XHP70.2 is just more efficient. That actually means less heat, more lumens at the same power level.
For max throw, just get the SMO. For a bit less throw with a better beam, get the OP reflector.
KevinZA1988
KevinZA1988's picture
Last seen: 3 min 51 sec ago
Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
QMT93
@BlueSwordM: thanks for clearing that up for me!
@KevinZA1988: that’s what I’ve been reading, although more slowly than I’d like. Thanks anyway!
scosgt
Last seen: 9 hours 34 min ago
The TrustFire S70S is similar but superior IMHO, because of the standby mode in the side switch.
It comes with an OP reflector, however the SMO reflector from the L6 works perfectly and gives great throw. Intestingly, the same L6 SMO does not work properly in an L6 without modification.
I prefer CW, so I reflowed a 6500K 70.2 into my S70S. Very happy with it.
QMT93
Is it Thorfire or Trustfire, as I can only find a Thorfire S70S?
scosgt
You are correct.
They are available on Amazon
There is a $4 coupon and I had $8 in reward points.
So it cost me $44
Well worth it, especially with the other reflector on it.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 49 min ago
The Sofirn SP70 will give even more stock Lumens
WTS BLF GT
QMT93
Nice! Thanks guys! I’ll have to do some more reading.
Funtastic
Funtastic's picture
Last seen: 19 hours 34 min ago
No donut hole with the new 70.2 version
Texas Ace Lumen Tube calibrated with maukka lights
